Aftermarket OEM hybrid lights?
02-20-2012, 06:36 PM | #1 |
40
Rep 1,021
Drives: F11 530d M-Sport
I had a thought. I'm keen to retrofit xenons to my car but it's the cost that's the most prohibitive part.
I was thinking, could I buy oem xenon housings that don't come with ballasts or bulbs, making them cheaper and then fit an aftermarket D2S HID kit? Something like this? http://www.hidorigin.com/philips-oem...rsion-kit.html Anyone got any thoughts? I'd imagine it'd still need coded.
MY14 Space Grey F11 530d M-Sport
02-20-2012, 07:06 PM | #2 |
40
Rep 1,021
Added: I see that oem xenons use D1S bulbs.
Pretend the above kit is a D1S kit. Would this work? What about the angel eyes?
02-21-2012, 01:40 AM | #3 |
886
Rep 9,097
Think about adding lamp washers into your budget as well.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
02-21-2012, 02:10 AM | #4 |
1397
Rep 8,083
Yes without washers and self-levelling, you'd have to remove all this stuff every MOT time.
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
02-21-2012, 02:48 AM | #5 | |
1545
Rep 8,970
New front bumper too New washers, pump, plumbing etc Front & rear ride height transducers, brackets, linkages etc New / modded wiring harness New headlight control harness etc Coding of footwell module? a bit of a job then eh? |
02-21-2012, 04:04 AM | #6 |
40
Rep 1,021
Well I've got a 330 so I've already got washers.
I understand the rest of the retrofitting required and already have the parts for the levelling. I was looking for advice on if aftermarket ballasts and D1S bulbs would fit in oem housings as they can be bought significantly cheaper this way.
02-21-2012, 04:11 AM | #7 |
47
Rep 791
I see no reason the bulb wouldn't fit - a D1S is a D1S. Your problem would likely be in mounting the ballast, but I'm sure that could be overcome...
2019 VW Golf GTI Performance | H&R rear ARB
Previously 2007 E92 335i SE auto | Quaife LSD | Birds B3 ARBs | Evolve Stage 1 |
02-21-2012, 05:45 AM | #8 |
40
Rep 1,021
That's what I was thinking. What about wiring? Not sure if the input to the OEM ballast would fit an aftermarket one? It'd be really easy if I had bought the lights, but I want to check and see how feasible this is before going ahead. That said, I've heard of people replacing broken OEM ballasts with aftermarket ones without any dramas so..
02-21-2012, 05:56 AM | #9 |
1397
Rep 8,083
I don't think you'll have a problem.
Ian
02-21-2012, 09:03 AM | #11 |
40
Rep 1,021
No. But they plug in through the same place as the ABS / brake pad wear sensor.
It's not an easy retrofit, but I'm a lot happier doing the arms for the level sensors and the wiring than I would be having to do the washers too. The BMW retrofit instruction looks reasonably straight forward. My Indy reckons that I won't need a new light switch as I can just disconnect the wires for the headlamp adjustment thumb wheel. I *might* need a new footwell module though but won't know until it's time to code in the levelling. I think the difficult part will be the adaptive lights. I think it'd be easier to get a set of non adaptive lights. I hear that to retrofit adaptive you need steering wheel position sensors and all sorts! Not sure how easy it'd be to put adaptive lights in but with the adaptive bit disabled. Might be difficult to ensure they are pointing forwards?
02-22-2012, 01:42 AM | #12 |
1397
Rep 8,083
Adaptive lights take a feed from the steering position sensor (which you might already have), the front and rear levelling potentiometers (which you will have once you've fitted them) and the prism sensor located in the rear-view mirror stem (not the same sensor as used for mirror dipping). It might be easier to forget trying to get adaptive to work but whatever you do it will be nice to see some photos and updates from a proper HID retrofit. Good Luck
Ian
