Best Place To Get Waterpump Replaced For E92?
02-16-2012, 03:37 PM | #2 |
The Blue Beast
142
Rep 5,665
got mine changed under warranty at bmw. no sure of a reputable indy shop in queens for bmws.
Cobb AP Stage 2+ | BMS DCI | UR Catless DP | UR Chargepipe | Tial BV 50mm | BSH OCC | ETS FMIC | Eisenmann Race Exhaust | KWv1 Coilovers | Volk TE37 TC Kline Ed. |
02-16-2012, 10:42 PM | #4 | |
The Blue Beast
142
Rep 5,665
02-17-2012, 12:46 AM | #5 |
Master Tire Installer
Rep 94
Replaced my waterpump on my 08 335i e92 in the garage on a floor jack and jack stands. Not fun. Undertray needs to come out, sway bar (drops and hangs out of way). Power steering line moved off to the side and radiator fan removed.
Remove pipes/hoses off from waterpump+thermo. Replace. Drain coolant. Tighten up, grab new coolant, mix 50/50 with distilled water. Battery charger, bleed air out (via pump). Best price on the pump/thermo I found was over @ Tischer. Need new set of alum bolts too. PM me if you're interested in doing it yourself, I'd be more than happy to provide a detailed step by step with a few pics. If its under warranty bring it back to dealership. **Pull codes first. 2E81, 2E82 & 2E83 are all indicative of pump. Did you overheat? Yellow or red? Radiator fan on blast upon start-up?
Daily Driver:08' E92 335i 6MT Montego Blue Style 189 Rims In the garage: 2008 E90 328xi Barbara Red & 2007 E90 328i Montego Blue |
02-17-2012, 02:04 AM | #6 |
Rep 198
AUTOcotoure Motoring...
They're in Fairlawn NJ, probably a 45 minute drive from queens (off peak hours that is) I would trust those guys to do anything. |
02-17-2012, 09:01 AM | #7 |
95
Rep 338
02-17-2012, 09:02 AM | #8 |
Rep 175
Matt did the work, it was his last week.
2007 335i e92 /// JB3 /// BMS DCI /// H&R Sport Springs
02-20-2012, 08:56 AM | #12 |
126
Rep 993
Drives: F85
My fan goes full blast on startup. Been doing that for a few months now. No other problems with overheating or anything.... Waterpump??
02-20-2012, 09:06 AM | #13 | |
83
Rep 2,132
Drives: FBO+ N54xi
So now i'm going where i installed all my mods and the dude is good a bit out of my way since i'm in queens but he does his job good, and works for me since he does afterhours and weekends, i posted my mechanics info on the Recommended shops in the Sticky!..
JB4+usb | P3 Vent Boost Gauge v2 | BMS OCC | BMS DCI | AMS FMIC | AR xi CL DP's | BT Tool | Edibias/NCSExpert/INPA BMW Coding | Cyba Quad Exhaust tips | M-Tech Rear & M3 Front Bumper | Red Cyba Air Scoops | Blacklines | Vinyl Overlays | ACS Roof Spoiler | Matte Black Grilles | LED Side Mirrors | Rear Euro Fogs | etc..
02-20-2012, 09:32 AM | #14 | |
Rep 94
02-22-2012, 04:54 PM | #15 |
Rep 15
[QUOTE=e92er;11381828]My fan goes full blast on startup. Been doing that for a few months now. No other problems with overheating or anything.... Waterpump??[/QUOTe
same thing was happening to my car and water pump blew eventually. as i posted here in search of good place to get water pump replaced. i decided to take it to this guy in Brooklyn called BJK Auto repair. he diagnosed and replaced water pump and thermostat in few hour at very reasonable price. my car runs perfectly now . jay |
06-19-2012, 10:01 AM | #16 |
19
Rep 379
i just replaced pump on my car (335i 08) and it is not easy but is straight forward. Only advice I will give you if you are doing it yourself that try to get as much ground clearance as possible.. also replace the bolt DO NOT reuse the same bolts again they are literally one-time bolts.
********** 2008 BMW 335i TT******
