new exhaust boot floor upgrade needed!!
02-14-2012, 04:21 PM | #1 |
Rep 23
hi i am fitting a 335 exhaust to my e90 saloon and i was wondering where i could get a boot floor upgrade as my car has a small well in it and that would restrict fitting does anybody know what model will have a flat type floor that i could get or a part number for one thanks
02-16-2012, 04:43 AM | #3 |
118
Rep 2,216
Drives: E91 330d M Sport
Looking on RealOEM, the pictures of the boot insert for the single exhaust and twin exhaust systems look very similar, but they have different part numbers and the 335 insert costs twice as much...
I wonder if the 335 one comes with heat shielding etc to make it safe to run the exhaust?
Just how many Yorkshire sheep can you fit inside one exhaust?
02-19-2012, 12:38 PM | #4 |
Rep 23
this is not a genuine back box its been made at an exhaust company and is one long silencer with two pipes coming out of it not two seperate boxes like the oem ones! mite have to modify the the boot floor
02-19-2012, 01:15 PM | #5 |
Zummerzet Zyder Drinker!
112
Rep 5,541
Drives: '06 330D Le Mans Blue
"Do not like"
02-20-2012, 02:32 AM | #7 |
1545
Rep 8,970
The 335i boot floor is fully heatshielded underneath and it has a much smaller cubby hole under the floor.
This is to allow the cross link pipe between the standard backboxes., although the realoem pictures look the same they are not. If you check the car specs, 335i/d have 10 litres less official bootspace than all other models, they must count the cubby hole in the total volume. Last edited by doughboy; 02-20-2012 at 02:39 AM.. |
02-20-2012, 04:49 AM | #8 | |
LSD - No, you're not seeing things
72
Rep 3,302
You just made a LOT of new friends on here.
02-20-2012, 05:51 AM | #9 |
111
Rep 1,487
I have to agree, modifying a car just to fit an exhaust not intended to fit it is a daft idea, you could cause no end of issues for yourself. Try two separate silencers instead, will save you a headache in the long run I imagine. |
02-20-2012, 07:44 AM | #10 |
15
Rep 365
Drives: F32 435dx ms, E90 330d ms
Fit the exhaust to the car...Not the car to the exhaust.
If the company making the exhaust can't do the job right then don't use them!!! Or...Just stick to a single exhaust. |
02-20-2012, 04:37 PM | #11 |
Rep 23
an not arsed about making friends i have enough of them its just a little info am after! and i love a challenge if people dont try n make thing fit thing that arnt suppose to be there the world wud be a very boring place and peoples cars would be all the same and look shit! csl wheels srnt suppose to got on anything other than a csl but look how many other cars there on!
02-21-2012, 01:31 AM | #13 |
15
Rep 365
It's fairly important to get on the good side of people if you want good advice.
I would try and stick to the BMW design as much as possible. Apparently there is now a BMW performance exhaust available which may suit your needs. Or you could just copy the layout. |
