BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Suspension | Brakes | Chassis
BPM
      06-01-2007, 01:57 PM   #1
1198r
34
Drives: E92 M3
2007 E92 M3  [0.00]
Brake info from UK M3 sales brochure
Managed to get a sales brochure last weekend and reading through info it details the following information under safety and control and wanted to know if this is new for E92 M3 or not. Word for word from brochure:
"Dynamic Stability Control Plus(DSC+) comprising: Anti-lock braking system (ABS), Automatic Stability Control (ASC), brake drying, brake fade compensation, brake pre-tensioning, cornering brake control (CBC), dynamic traction control (DTC), electronic brake force distribution (EBD), engine drag torque control (MSR), hill start assistant, soft stop"
Any of this on the E46?
      06-01-2007, 02:20 PM   #2
JEllis
JEllis's Avatar
531
Drives: E36 M3, E92 M3
My E36 has ABS and ASC. EBD sounds new and similar to equipment available to Porsche owners.
Jason
http://www.m3post.com/forums/signaturepics/sigpic14547_7.gif
Instagram: jellismotorwerks
      06-01-2007, 04:27 PM   #3
M3_2010
M3_2010's Avatar
Drives: M3 CiC
E46 has ASC, ABS, DTC, EBD.....
Soft stop can't be any good..... I like to stop my own car.
      06-01-2007, 10:56 PM   #4
GregW / Oregon
Commander-In-Chief
2101
Drives: 2023 M2 Coupe, 2020 GLE 450
E46 also has CBC. Brake drying, hill start assistant, soft stop & MSR are new, I believe. Agree on soft stop, whatever that is. I think I can modulate my stops just fine so my passengers' heads don't bob.
Greg Lake Oswego, Oregon, USA
2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450
      06-02-2007, 12:49 AM   #5
E36325is
Hong Kong
18
Drives: 1M coupe
Yes just got my 335 coupe, soft stop is absolutely awful, makes it harder to modulate the brakes, need to find a way to turn it off if possible!
      06-02-2007, 01:37 AM   #6
lucid
lucid's Avatar
374
Drives: E30 M3; Expedition
Does someone have the exact technical specs on this soft stop thing? I can guess what it is trying to accomplish, but I want to know exactly how it is implimented. If it is what I am thinking, it sounds horrible.
      06-02-2007, 02:55 AM   #7
E90Fleet
South Africa
1311
Drives: BMW
It works great
Some just need to get used to it
As you are about to stop, it slightly releaves the pressure on the rear brake pads and stops the car more gently.
Its designed to take 50% of the modulation needed away ( so if you dont modulate slightly, peoples heads wil still "bob" slightly )
Most E9x have it, and most E6x
BMW if you are reading, I need a job, Please.
      06-02-2007, 03:02 AM   #8
13eastie
13eastie's Avatar
35
Drives: 2007 E92 M3
Originally Posted by E90Fleet View Post
It works great
Thanks for the explanation.
While I will leave to my passengers to comment as whether I might benefit from the "soft-stop", I think it sounds a million miles away from the "Ultimate Driving Machine". More like technology for its own sake.
      06-02-2007, 03:22 AM   #9
E90Fleet
South Africa
1311
Drives: BMW
Its a standard feature on almost all BMW DSC systems since 2005.
It makes it a better drive for a huge amount of drivers that cant modulate properly
      06-02-2007, 03:41 AM   #10
lucid
lucid's Avatar
374
I don't mind the DSC. Actually, it might have saved my ass once. With regards to the soft stop thing: all I can say is that I hope there is way to turn it off on the M3.
      06-02-2007, 07:00 AM   #11
E36325is
Hong Kong
18
Drives: 1M coupe
I wonder if I change to an aftermarket brake set like Brembo or AP will it disable this awful soft stop thing?
      06-02-2007, 10:40 AM   #12
replicat
23
Drives: 40MPG
Most likely not, because that system is probably control in the BCM (Braking Control Module) And works throught the hydraulics...a set of Gran Turismos won't fix it..
I will be a Master Tech for BMW when this car is out, so I'll figure a way to get it controlled or overridden.
      06-02-2007, 11:06 AM   #13
00o00
00o00's Avatar
15
Drives: its comming...
why in hell would they fit a break modulation system on a car that is suppost to be designed for proformance driving im talking about soft stop, i don't see the reasoning behind this, we have gotten along fine for years without it, now i can understand it on the normal 3 series, but an ///M thats just dumb
does the M5 have this?
      06-04-2007, 10:52 AM   #14
mofomat
mofomat's Avatar
792
Drives: Audi R8 V10, BMW 330e Touring
People are getting their knickers in a twist about something which is hardly even noticeable. I have it in my E90. I didn't have it in my E46 M3. I never even notice it to be honest.
      06-04-2007, 11:02 AM   #15
lucid
lucid's Avatar
374
If it is not something that is noticed, than why the hell is there? The whole point of the system is to make a difference in how the car comes to a stop, and that should be noticable. So, I have to question your perception. Or, maybe it has to do with the way you drive--maybe you like soft stops to begin with...
      06-04-2007, 11:42 AM   #16
mofomat
mofomat's Avatar
792
I can assure you that my perception is fine.
Maybe when something does it's job properly you don't notice it. How about a referee in a sports game? You only notice them when they make a mistake.
Basically, if you don't try to modulate the brake when you come to a stop, then you will notice it. If you do, and just drive normally, then you don't need it to take over for you.
      06-04-2007, 11:44 AM   #17
seven_227
seven_227's Avatar
United Arab Emirates
57
Drives: AW e92 335i
In my e92 335i when im in stop and go traffic the brakes are so jerky !
      06-04-2007, 12:04 PM   #18
lucid
lucid's Avatar
374
Sorry, I don't buy the anology. A better anology might be with ABS or something. And when ABS kicks in, I notice it. When any electromechanical system interferes with handling, I notice it, and so should you if you are somewhat in touch with what the car is doing is my point.
      06-04-2007, 12:13 PM   #19
mofomat
mofomat's Avatar
792
ABS has a much more aggressive intervention. Of course you're going to notice that, like I do.
However, you don't notice soft stop unless you drive in a particular way. So if you don't attempt to stop the car smoothly, then you will notice it. If you drive normally, and try to drive smoothly, then you will not notice soft stop because it won't need to intervene.
However, the brake assist can be annoying. If you tap the breaks quickly but with little force, it can confuse the system and 'think' you want full force breaking, which can be jerky.
      06-04-2007, 01:14 PM   #20
lucid
lucid's Avatar
374
I don't know what you mean by "normal" driving. Normal by what standard?...Well, maybe I've judged the road conditions, and for whatever reason I want to come to an abrupt stop. Then the dumbass technology kicks in, and I'll be cursing at the car. I'm fine with these kind of interventions when safety is an issue. But clearly, in this case, safety is not an issue. And then like you are saying, with any such system, there are always problems with recognizing events, and making false interventions, which is even more annoying. The previous poster seems to be complaining about the same thing.
Anyway, I'll have to drive the thing and then I can really let it loose on the idiot who came up with the idea. BMW engineers are great with engines, suspensions, and other core systems, and that's where they should focus their energy. Stuff like this sounds purely annoying and is somewhat typical of BMW's orientation with unnecessary technologies...
      06-04-2007, 02:24 PM   #21
mofomat
mofomat's Avatar
792
I think you've jumped to some conclusions about what you think 'soft-stop' actually is, and what it feels like, otherwise you wouldn't be dwelling on things like "normal driving" and "road conditions".
The road conditions are pretty irrelevent really. It is a minor aspect of the driving experience and therefore I go back to my original point that people are getting their knickers in a twist about something which isn't a big issue.
Just to make it clear so you know what soft-stop is. When you apply the foot brake to come to a stop, in a normal car unless you ease off very slightly on the brake, the car will come to a jerky stop. Soft-stop allows you to apply the same constant brake pressure, and for the very last fraction of a second it will release the brakes allowing you to come to a smooth stop. It is hardly noticeable.
The road conditions are irrelevent. You can still come to an abrupt stop in the same way as you would without 'soft-stop'.
I find it bizarre that you are complaining about something which you haven't even experienced yet!
I tell you. You could drive it and you wouldn't even know it was there.
      06-04-2007, 02:35 PM   #22
yves
Germany
Drives: BMW Z3, BMW X5
They will have it for a reason they dont make extra costs when they could have left it out they are a company like any other trying to make as much profit as possible. I drive a 6 series often and you can easy do abrupt stops. and tested alto of BMW lately and never noticed anything trying to make it stop sofetly. just forget about you will not notice it anyways.
m3post
