The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > help!! misfiring. anyone know what's causing it ?
      02-12-2012, 10:29 PM   #1
E92BA
FBO + e85 335i
Drives: E92 335i
I've been misfiring. I was hoping someone might have had the same symptoms and might be able to tell me hat it is before I start buying coil packs and injectors and hope hey work.
-2007 335
-70k miles
-brand new hpfp
-most of the time only misfires when I put it on map 1 on jb4
-misfires on cylinders 4 &5
might be spark plugs ? anyone wanna give it a shot? thanks!!!!
      02-12-2012, 10:38 PM   #2
GmoBmw
GmoBmw's Avatar
34
Drives: 2007 335i
haha mine did the same thing. Changed my plugs and it went away. If its not that might wanna check your coils. but most likely its plugs.
2007 BMW 335I- JB4 G5,DCI,VRSF DPs,NT555r Drag Radials Daily Driver
      02-12-2012, 10:38 PM   #3
reiss91
Drives: tacoma
Move the coils and plugs and see if the misfire moves. Assuming you have a scanner to read them.
This should identify if a coil or plug needs to be replaced. If that doesn't help you check the carbon build up on the intake valves. Cylinder 5 is usually always the dirtiest and 70k is about time to get it done.
Keep us posted
      02-12-2012, 10:39 PM   #4
skinrock
Agent Smith
skinrock's Avatar
270
Drives: 2016 i8
2016 BMW i8  [10.00]
http://www.e90post.com/forums/showthread.php?t=631829
The i8 needs a V8 amirite?
      02-12-2012, 10:44 PM   #5
E92BA
FBO + e85 335i
Drives: E92 335i
yea I'm gonna try the spark plugs. I'm pretty sure that's it. & I wanna do the carbon build up cleaning but it's a lotta $$$
      02-14-2012, 05:08 PM   #6
335iVA
Chyeah
335iVA's Avatar
Drives: 07 335i 6MT
I had the same problem. I first noticed a misfire on Cyl. 4 when in Map 1. I moved to Map 5 and it was running for a month or so, then started misfiring on Cyl. 4 again. The only time it would not misfire was when I was running stock bypass. Changed the plugs, problem fixed. Car has been running smoothly ever since... So check the coils, change the plugs, you should be good to go. Hopefully its not your injectors, but if you are under warranty, shouldn't be a problem. Have you had the injectors replaced yet?
