Go Back   6Post.com | BMW 6-Series Forum > BMW 6 Series Forum > BMW M6 Forum (F12 / F13)
      02-11-2012, 12:47 PM   #1
southlight
Moderator / European Editor
southlight's Avatar
1494
Drives: X3M
BMW M6 Coupe (F13M) and M6 Convertible (F12M)
Size:  114.1 KBName:  P90089540_highRes.jpg
Size:  105.7 KBName:  P90089548_highRes.jpg
Vitals
  • BMW V8 Twin Scroll Twin Turbo (S63Tu) Engine
  • Displacement: 4,395cc
  • 560hp (at 6,000-7,000rpm)
  • 502 lb-ft torque (max torque from just 1500rpm)
  • Weight (coupe), unladen (DIN/EU) - 1850kg / 1925kg (4,078 / 4,243lb)
  • Weight (convertible), unladen (DIN/EU) - 1980kg / 2055 (4,364 / 4,530lb)
  • 7-speed DCT transmission (manual transmission for US also likely)
  • Active M Differential
  • Coupe average fuel consumption: 9.9 liters/100 km (28.5 mpg imperial / 23.5 US MPG)
  • Convertible average fuel consumption: 10.3 liters/100km (27.4 mpg imperial)
  • CFRP roof (carbon fiber reinforced plastic) for M6 coupe
  • Optional M carbon-ceramic brakes reduce weight by 19.4 kg (42.8 lb) and increase fade resistance - calipers gold-colored
  • Weight-to-power ratio - Coupe (3.3kg/hp, 7.3lb/hp); Convertible (3.5kg/hp, 7.7lb/hp)
  • Pictured colors: Sakhir Orange (coupe), San Marino Blue (convertible)
Performance:
  • Coupe: 0-100km (0-62mph) in 4.2 seconds (F10 M5 takes 4.4 seconds); 0-200km (0-124mph) in 12.6 seconds
  • Convertible: 0-100km (0-62mph) in 4.3 seconds; 0-200km (0-124mph) in 13.1 seconds
  • Top speed: 250kmh (155mph)
  • M-Drivers-Package increases top speed from 250km/h to 305km/h (155mph to 189mph)
PRESS RELEASE + Expand
Download Full Press Release: F12/F13 M6 Press Release
At a Glance
• New edition of the BMW M6 in Coupe and Convertible body variants; generous dose of M feeling combined with alluring design aesthetics, a luxurious aura, seating for four and innovative equipment features; high-performance sports car with superior performance attributes and extremely exclusive character; BMW M6 Coupe and BMW M6 Convertible both occupy a unique position in the premium segment of the executive class thanks to their blend of outstanding dynamics, hallmark M conceptual harmony and everyday usability; further development of both concepts breaks new ground with significantly improved efficiency, optimised controls for individualising the car set-up and a wider variety of driver assistance systems and infotainment functions available from BMW ConnectedDrive.
• Visually imposing body design with dynamically elegant lines and hallmark M athleticism provides an accurate visual showcase for the car’s high-performance properties; BMW M6 Coupe with strikingly contoured roof made from carbon fibre-reinforced plastic (CFRP); BMW M6 Convertible with high-quality soft-top boasting distinctive “fin” architecture.
• High-revving 4.4-litre V8 engine with M TwinPower Turbo technology, consisting of Twin Scroll Twin Turbo technology, cross-bank exhaust manifold, High Precision Direct Petrol Injection and VALVETRONIC fully variable valve control; hallmark M power delivery headlined by instantaneous responsiveness and a sustained wave of thrust; highest output in the segment; 412 kW/560 hp at 6,000 – 7,000 rpm, maximum torque: 680 Newton metres (502 lb-ft) from 1,500 rpm; maximum engine speed: 7,200 rpm; engine output 10 per cent higher than predecessor models, maximum torque 30 per cent higher.
• Acceleration: 0–100 km/h (62 mph) in 4.2 seconds (BMW M6 Coupe) or 4.3 seconds (BMW M6 Convertible); 0–200 km/h (124 mph) in 12.6 (13.1) seconds; electronically governed top speed: 250 km/h (155 mph) or 305 km/h (189 mph) with M Driver’s Package.
• Extraordinarily fine balance between performance and fuel consumption represents major improvement on previous models; average fuel consumption in the EU test cycle: 9.9 litres per 100 km / 28.5 mpg imp (BMW M6 Coupe) and 10.3 litres per 100 km / 27.4 mpg imp (BMW M6 Convertible); Auto Start-Stop function and further Efficient Dynamics technology as standard; fuel consumption of the respective predecessor models cut by more than 30 per cent.
• Seven-speed M Double Clutch Transmission with Drivelogic; automatic gear selection tuned to deliver optimum traction, Launch Control and Low Speed Assistance; bespoke M gear selector; newly developed M leather steering wheel with gearshift paddles.
• Power sent to the rear wheels; Active M Differential ensures fully variable distribution of drive between the rear wheels. Result is optimised traction and directional stability during dynamic lane changes and when accelerating out of corners.
• High-performance characteristics with outstanding dynamics and precisely controllable handling, thanks to hallmark M harmony in the interplay of powertrain and chassis technology, aerodynamics and weight balance; weight-to-power ratio – BMW M6 Coupe: 3.3 kg/hp (7.3 lb/hp), BMW M6 Convertible: 3.5 kg/hp (7.7 lb/hp).
• M-specific chassis with bespoke front and rear axle kinematics; M-specific Dynamic Damper Control as standard; DSC stability control incl. M Dynamic Mode; M Servotronic steering; body strengthening using special panels; lightweight compound high-performance braking system; available as an option are newly developed, globally unique M carbon-ceramic brakes with optimum resistance to fade and wear, and lower weight.
• Engine responses, M Servotronic mapping, Drivelogic shift program, DSC mode, damper characteristics and information shown on the Head-Up Display can be programmed individually; two M Drive buttons on the steering wheel can be used to store and call up individually configured car set-up options.
• Body design with classical BMW Coupe/Convertible proportions, customary sporty yet elegant BMW 6 Series looks and typical M sporting edge; special M design features provide an accurate visual representation of the car’s technical profile and performance; three-section, strikingly modelled lower air intake with aerodynamically optimised flaps; new M kidney grille with black double slats; flared wheel arches; hallmark M gills with integrated direction indicator bars; aerodynamically optimised exterior mirrors and side skirts; BMW Individual High-gloss Shadow Line; exposed reflectors below the rear lights; aerodynamically optimised rear apron with diffuser between the right and left-hand pair of twin exhaust tailpipes; 19-inch (standard) or 20-inch (optional) forged M light-alloy wheels, each with a distinctive interpretation of the familiar M double-spoke design.
• Luxurious, elegantly sweeping interior design with special M controls and styling features; newly developed M double-spoke leather steering wheel; M gear selector and car set-up controls on the model-specific centre console; exclusive M sports seats with integrated belt system (optional: M multifunction seats); Merino leather upholstery with extended features; exclusive carbon-fibre interior trim strips; illuminated door sill finishers with model lettering; M-specific instrument cluster with black-panel technology; 2-zone automatic climate control with extended features, ambient lighting.
• Adaptive LED Headlights fitted as standard, extensive range of BMW ConnectedDrive features, some unmatched by any rival: BMW Head-Up Display with M-specific information, High Beam Assistant, BMW Night Vision with pedestrian recognition, Lane Change Warning, Lane Departure Warning, rear-view camera, Surround View, Speed Limit Info, internet access, extended integration of smartphones and music players, Real-Time Traffic Information and apps for receiving web radio and using Facebook and Twitter.
• Almost all BMW 6 Series equipment options available, including Comfort Access, active seats, heated steering wheel, doors with Soft Close Automatic function, Navigation system Professional, Bang & Olufsen High- End Surround Sound System.
• Performance, fuel consumption and emissions data: BMW M6 Coupe: Acceleration [0 – 100 km/h (62 mph)]: 4.2 seconds, acceleration [0 – 200 km/h (124 mph)]: 12.6 seconds, top speed: 250 km/h (155 mph), 305 km/h (189 mph) with M Driver’s Package, average fuel consumption: 9.9 litres/100 kilometres (28.5 mpg imp), CO2 emissions: 232 g/km, exhaust standard: EU5. BMW M6 Convertible: Acceleration [0 – 100 km/h (62 mph)]: 4.3 seconds, acceleration [0 – 200 km/h (mph)]: 13.1 seconds, top speed: 250 km/h (155 mph), 305 km/h (189 mph) with M Driver’s Package), average fuel consumption: 10.3 litres/100 kilometres (27.4 mpg imp), CO2 emissions: 239 g/km, exhaust standard: EU5.
Aesthetic allure meets high performance: The new BMW M6 Coupe. The new BMW M6 Convertible.
Out of a passion for elite performance and an appreciation of exclusive style comes the allure for which M Automobiles are renowned – and which can now be experienced in two new forms. The new BMW M6 Coupe and BMW M6 Convertible offer top-class performance attributes and an ambience defined by luxury and innovative comfort features. In so doing, the high-performance sports cars developed by BMW M GmbH exude a level of poise and assurance unmatched in the premium segment of the executive class – and reflected authentically in the expressive design of the two models. The precise interplay of their high-revving V8 engine with M TwinPower Turbo technology and 412 kW/560 hp, a seven-speed M Double Clutch Transmission with Drivelogic, Active M Differential, model-specific chassis technology, an ideal weight balance and optimised aerodynamic properties serves up a particularly full-blooded M experience.
The conceptual harmony characteristic of M Automobiles also incorporates the specific features of the two models’ body structures. The new BMW M6 Coupe has a dynamically contoured, lightweight roof made from carbon fibre- reinforced plastic. The new BMW M6 Convertible, meanwhile, is fitted with a high-quality soft-top, complete with eye-catching “fin” styling and fully electronic opening mechanism. All of which allows the driver and passengers to enjoy the dynamic performance of a high-performance sports car in harmony with the natural forces of the sun and wind.
The motor sport technology in the new BMW M6 Coupe and BMW M6 Convertible paves the way for imposing performance on the race track, but also treats the driver to a captivating driving experience on everyday journeys from A to B. The BMW M6 Coupe sprints from 0 to 100 km/h (62 mph) in 4.2 seconds, the BMW M6 Convertible in 4.3 seconds. However, the dynamic character of both models is also defined by their mid-range agility, the precision of their turn-in and traction when accelerating out of corners, their precisely controllable handling under intense lateral forces and their stopping capability. The latest innovation designed to optimise the handling of the new BMW M6 Coupe and BMW M6 Convertible in highly dynamic driving situations are the M carbon-ceramic brakes, offered as an option for the first time.
Another attribute unmatched by any rival is the leap forward in efficiency that comes with the new editions of the two high-performance sports cars. The new BMW M6 Coupe records average fuel consumption of 9.9 litres per 100 kilometres (28.5 mpg imp) and CO2 emissions of 232 grams per kilometre in the EU test cycle. The equivalent values for the new BMW M6 Convertible are 10.3 l/100 km (27.4 mpg imp) and 239 g/km. Despite a 10 per cent increase in engine output and a 30 per cent jump in peak torque – to 680 Newton metres (502 lb-ft) – fuel consumption and CO2 emissions have been reduced by over 30 per cent in both cases compared with their respective predecessors.
Design: athletic aura, powerfully taut surfaces, elegant lines.
Classical proportions, the sporty yet elegant lines of the BMW 6 Series and the familiar design language of BMW M Automobiles form the foundations for the eloquent body design of the BMW M6 Coupe and BMW M6 Convertible. Powerfully taut surfaces and precise contours underline the athletic aura of the two models. In addition, a model-specific interpretation of hallmark M styling cues includes design details which are influenced directly by technical considerations – such as the cooling air required, chassis geometry and aerodynamics – and therefore further highlight the cars’ outstanding performance attributes. This is a fine example of how the ultra-dynamic character which marks out these most focused versions of the luxurious Coupe and exclusive Convertible is accurately expressed through their design.
Wide air intakes, stunningly contoured headlight units and large, smooth surfaces shape the front end of the new BMW M6 Coupe and BMW M6 Convertible. Another eye-catching element of the car’s nose is its newly designed M kidney grille, which bears an “M6” badge. The grille’s black, paired kidney grille slats take their cues from the characteristic double-spoke design of the M light-alloy wheels. The 30-millimetre increase in track width over the two cars’ respective 6 Series stablemates is complemented by powerfully flared front wheel arches, which sit flush with the wheels. This extra width offers a clear nod to the optimised roadholding of these high-performance sports cars. The three-dimensional shaping of their air intakes and race-inspired flaps designed to optimise airflow to the outer air intakes likewise underline the cars’ forward-surging, dynamic character.
An LED accent light cuts across the tops of the Adaptive LED Headlights fitted as standard on both models. Their bright white, three-dimensional LED light rings are levelled off to striking effect at the top and lower edges. Both dipped beam and main beam use both light rings. Providing the light are LED units, which are placed on a horizontal rib running through the centre of the units and feed their light into the reflectors in front of them. This ensures that the distinctive appearance of the twin circular headlights comes across clearly in every situation. The direction indicators – in the form of horizontally arranged LED units – are integrated into the headlight units below the light rings.
The familiar M athleticism of both models is also clearly visible from the side. The front side sections of the car feature familiar M gills. Their three-dimensional shaping, wide chrome frames and indicator bars – which bear the M logo – give them an extremely deep-set look. In tune with the wider wheel arches, the character lines around the gills are suitably prominent. Eye-catching creases on the likewise model-specific side skirts sweep upwards, diverting the gaze to the rear wheels. The new BMW M6 Coupe and BMW M6 Convertible are fitted with 19-inch M light-alloy wheels as standard. The forged wheels feature seven double-spokes in a two-tone finish. The optional 20-inch M light-alloy wheels, meanwhile, hint at reduced weight with their five intricate double-spokes and allow a clear line of sight through to the powerful braking system.
Broadening towards the road and incorporating horizontal lines and generous surfaces, the design of the rear end hints at the stable roadholding and powerful poise and assurance of the new BMW M6 Coupe and BMW M6 Convertible. The reflectors, positioned immediately below the L-shaped rear lights, provide an individual expression of sportiness. However, the clearest pointer to the unmistakable identity of the two high-performance sports cars are the familiar M twin exhaust tailpipes positioned to either side of the diffuser integrated into the rear apron. The form of the outer air intakes reflects the design of the front apron in their format and the contours of their surrounds.
Dynamic contours, lightweight material: the carbon fibre-reinforced plastic roof of the BMW M6 Coupe.
Like its predecessor, the roof of the new BMW M6 Coupe is made from carbon fibre-reinforced plastic as standard. The dark colouring of the roof gives the two-door car’s silhouette an extremely elongated look, which is further emphasised by a dynamic recess in the centre of the roof. The use of the lightweight material for the roof allows the car’s centre of gravity to be lowered, enhancing agility. BMW Individual High-gloss Shadow Line trim (standard) draws attention to this optimised weight balance, its dark colouring covering the side window borders (or the waistline in the case of the BMW M6 Convertible) and the base and lower section of the aerodynamically optimised M exterior mirror caps.
The exclusive looks of the new BMW 6 Series Convertible are underlined by the “fin” architecture of the high-quality soft-top roof. Projecting into the rear section, the fins accentuate the car’s dynamically sweeping silhouette. The heated, vertical glass rear window, which is situated just behind the rear seats, retracts independently of the soft-top itself. The automatic opening and closing process for the roof can be activated both at a standstill and while on the move at speeds of up to 40 km/h (25 mph) using a button on the centre console. The optional Comfort Access allows the roof to be opened or closed by pressing the remote control button on the car key. It takes the roof 19 seconds to open and 24 seconds to close again.
Customers can chose from one non-metallic and eight metallic shades (including four exclusive M finishes) for the exterior paintwork of both models. The soft-top for the new BMW M6 Convertible is available in Black and Beige, or – as an option – in Anthracite Silver effect.
The engine: high-revving V8 with M TwinPower Turbo technology.
The new BMW M6 Coupe and Convertible showcase their individual style with a raft of unique styling touches and tweaks to the character of the driving experience. But they draw the output required to serve up their inspirational performance from the same source: a high-revving V8 engine with M TwinPower Turbo technology, longitudinally mounted at the front of the car, whose power is channelled to the rear wheels via a seven-speed M Double Clutch Transmission with Drivelogic. This powertrain combines construction features taken directly from motor sport with innovations developed under the banner of Efficient Dynamics. Its globally unparalleled package of technology comprises two turbochargers working according to the twin-scroll principle (including a cross-bank exhaust manifold), High Precision Direct Petrol Injection, VALVETRONIC variable valve timing and Double-Vanos continuously variable camshaft control. The engine is also served by an extremely powerful cooling system and a wet sump oil supply optimised to work under high lateral forces.
The unmistakable, typically M performance characteristics of the 4.4-litre powerplant are defined by its lightning-quick responses and forceful, linear power delivery maintained into the higher reaches of the rev range. Indeed, peak torque of 680 Newton metres (502 lb-ft) is on tap between 1,500 and 5,750 rpm. The V8 achieves its maximum output of 412 kW/560 hp between 6,000 and 7,000 rpm and can spin on to 7,200 rpm. All of which means the rev band available in the new models to generate maximum performance is almost three times wider than that of the engine powering their predecessors.
This instantaneous and sustained power delivery is the key to unlocking the cars’ intoxicating acceleration. The new BMW M6 Coupe dashes from rest to 100 km/h (62 mph) in 4.2 seconds, while the new BMW M6 Convertible reaches the same speed just 0.1 seconds later. The top speed of both models is electronically limited to 250 km/h (155 mph). Specifying the optional M Driver’s Package raises this barrier to 305 km/h (189 mph).
The advances in engine development enshrined in M TwinPower Turbo technology are also reflected in the two new models’ significantly greater efficiency compared to their predecessors. The high operating effectiveness of the engine, the standard-fitted Auto Start-Stop function and other examples of Efficient Dynamics technology, such as Brake Energy Regeneration and the volume-controlled oil pump, help to reduce fuel consumption and emissions by around 30 per cent. The new BMW M6 Coupe cards average fuel consumption of 9.9 litres per 100 kilometres (28.5 mpg imp) in the EU test cycle and CO2 emissions of 232 grams per kilometre. The corresponding values for the new BMW M6 Convertible are 10.3 litres per 100 kilometres (27.4 mpg imp) and 239 grams per kilometre.
Harnessing the high output to dynamic effect: the seven-speed M Double Clutch Transmission with Drivelogic.
Tuned seamlessly to the performance characteristics of the V8 engine, the M Double Clutch Transmission with Drivelogic converts the powerplant’s impressive thrust extremely effectively into rapid acceleration. This capability is underpinned by the DCT design principle, which effectively combines two gearboxes in one housing – yet with virtually no size or weight penalty over a conventional manual transmission. Inside the transmission, the torque is transferred via two oil-cooled wet clutches, which are engaged alternately. This allows zero interruption in the flow of power when the driver accelerates, even during gear changes.
M DCT Drivelogic offers the driver three different shift programs, both in automated mode (D) and manual mode (S). These programs alter the transmission’s shift characteristics in terms of efficiency, shift comfort and sportiness and can be activated using the rocker switch located behind the selector lever on the centre console. Added to which, the electronics also provide a Launch Control function ensuring unbeatable acceleration from a standing start, Low Speed Assistance for easier low-speed operation and the Auto Start-Stop function for increased efficiency.
The special M gear selector is used for selecting D and S modes and for engaging reverse gear. In S mode the driver changes gears manually in a sequential format. The new BMW M6 Coupe and Convertible are also equipped as standard with a newly developed M leather steering wheel, complete with multifunction buttons and fixed gearshift paddles. In typical M configuration, the driver pulls the right-hand paddle to shift up and the left-hand paddle to shift down. The model-specific steering wheel stands out with its smaller rim diameter and a design which borrows from the double-spoke construction of the M light-alloy wheels.
Active M Differential delivers outstanding traction in dynamic driving situations.
The new BMW M6 Coupe and Convertible also impress by offering optimum traction in tricky road and weather conditions and under dynamic acceleration out of corners. Working behind the scenes to this end is an innovative variable locking differential in the rear differential. The Active M Differential allows the engine’s power to be split precisely and quickly between the left and right rear wheel according to the requirements of the driving situation at any particular moment.
An electronically controlled multi-plate limited-slip differential helps to reduce the rotational speed differences between the rear wheels, which is needed to optimise traction. The Active M Differential control unit is linked up to the DSC stability control system, allowing every driving situation to be precisely analysed and a loss of traction at one wheel to be detected at an early stage. The locking effect generated in response can be varied between 0 and 100 per cent, enabling wheel spin to be prevented on slippery surfaces, in instances where the left and right rear wheel have widely differing friction coefficients, in tight bends and when changing direction extremely dynamically. Optimising traction in this way also provides unbeatable driving stability in challenging conditions and allows impressively dynamic acceleration out of corners.
M-specific chassis technology, Dynamic Damper Control, M Servotronic, DSC with M Dynamic Mode.
The chassis of the new BMW M6 Coupe and Convertible has been developed to M specification and therefore combines outstanding performance attributes with the comfort-enhancing features drivers appreciate on an everyday basis. Like the integral rear axle, whose subframes are bolted rigidly to the body, the double-wishbone front axle boasts specific kinematics and newly developed components made from forged aluminium. Chassis mountings using large panels at the front and rear axle ensure dynamic forces are passed evenly through to the body. Through enthusiastically driven corners, this helps to noticeably reduce the roll movements triggered by bumps in the road surface. Both the construction of the chassis and its bespoke tuning for each model are defined by extensive expertise from the race track and have been optimised during extensive testing on the Nürburgring’s Nordschleife circuit.
The standard equipment of both models also includes electronically controlled dampers. The M-specific Dynamic Damper Control system adjusts damping force electrohydraulically to provide the required responses for the driving situation at hand and fulfil the wishes of the driver. A choice of three settings allows drivers to adjust the damper characteristics to their needs and preferences.
The hydraulic rack-and-pinion steering ensures unbeatable precision and a high degree of comfort. This system has a variable ratio, which enhances straightline stability and reduces the number of steering wheel turns required when parking and turning off a road. The likewise standard Servotronic speed-sensitive power assistance is specially tuned to M specification and allows drivers to choose a personal configuration with the help of three set-up options.
In addition to applying brake impulses and reducing engine output to stabilise the car, the DSC stability control system of the two high-performance sports cars also employs the services of the Anti-lock Braking System (ABS), Cornering Brake Control (CBC), Dynamic Brake Control (DBC), Brake Assistant, the Brake Drying function and Start-Off Assistant. M Dynamic Mode (MDM) can be activated to override the basic setting by pressing the DSC button. By raising the intervention thresholds of DSC, this mode makes it easier to move off on snow or loose sand with slightly spinning driven wheels. MDM mode also paves the way for the familiar M self-steering response. “DSC Off” mode can likewise be activated at the touch of a button.
An innovation designed to deliver precise handling: M carbon-ceramic brakes.
The latest version of the compound high-performance braking system helps give the new BMW M6 Coupe and Convertible outstanding stopping power. Its stand-out features include even lower weight, excellent feel and fade-free performance even under heavy loads. The diameter of the inner-vented and perforated brake disks is 400 millimetres at the front and 396 millimetres at the rear. The six-piston fixed-calliper brakes at the front axle – painted dark blue metallic and complete with the M logo – are radially bolted to the pivot bearing.
The M carbon-ceramic brakes available for the first time for the new BMW M6 Coupe and Convertible (in conjunction with 20-inch M light-alloy wheels) are without parallel worldwide and take the cars’ stopping power to another new level. The brake discs measure 410 millimetres in diameter at the front axle and 396 millimetres at the rear. Made from a new type of carbon-fibre compound ceramic, the discs boast even greater resistance to heat and combine this with significantly reduced rotating masses. The M carbon-ceramic brakes are 19.4 kg (42.8 lb) lighter than the standard-fitted items, yet the innovative material also displays exceptional resistance to wear, and the operating life of the discs is many times that of conventional equivalents. The optional M carbon-ceramic system also sees six-piston fixed-calliper brakes at the front teaming up with single-piston floating-calliper brakes at the rear. The callipers can be identified by their special gold-coloured paint finish.
Lightweight design across the board, flawless occupant protection.
An intelligent blend of materials also gives the body structure impressive strength coupled with extremely low weight, allowing it to enhance both occupant protection and handling agility. As with the use of CFRP for the roof of the new BMW M6 Coupe, the choice of materials for all other body components slots into the all-round lightweight design strategy. The doors and bonnet of the two high-performance sports cars are made from aluminium, the front side panels from thermoplastic. In addition, their boot lids and – in the case of the BMW M6 Convertible – also the roof cover are made from the glass-fibre composite material SMC (Sheet Moulding Compound). A weight-to-power ratio of 3.3 kg/hp (7.3 lb/hp) for the new BMW M6 Coupe and 3.5 kg/hp (7.7 lb/hp) for the new BMW M6 Convertible points to the significant advances that have also been made in this area over the predecessor models.
Robust load-path structures, large and precisely defined deformation zones and highly efficient restraint systems provide the basis for a high level of passive safety in both models. The safety equipment fitted as standard includes front and side airbags, side curtain head airbags for both rows of seats in the new BMW M6 Coupe, and front airbags and head-thorax side airbags integrated into the seat frames of the new BMW M6 Convertible. The soft-top model also benefits from roll-over bars made from high-strength aluminium. Positioned behind the rear head restraints, these protective bars extend automatically in fractions of a second should there be a danger of the car rolling over. Both models come with three-point inertial-reel seat belts on all seats, belt force limiters and belt tensioners for the front seats and ISOFIX child seat attachments in the rear.
Both the new BMW M6 Coupe and new BMW M6 Convertible are designed as four-seaters, and space in the rear compartment has increased substantially compared with the predecessor models. The load capacity of the new BMW M6 Coupe stands at 460 litres. The new BMW M6 Convertible, meanwhile, can carry 300 litres of luggage in the boot with the soft-top down and 350 litres with it closed. Both models can be ordered with the optional ski bag, which slides between the rear seats courtesy of the through-loading facility.
M-specific cockpit design: flawless car control, made-to-measure luxury.
Newly developed M sports seats offer the driver and front passenger optimum lateral support through quickly-taken corners, but also a high level of comfort over long distances. The lightweight seats with integrated belt system have an M-specific design headlined by extremely prominent cushion and backrest bolsters, head restraints integrated into the backrests, eye-catching stitching emphasising the segments of the seats, and an M logo embossed into the shoulder area. The M sports seats have electric height, fore/aft and backrest angle adjustment, and also come with pneumatically adjustable lumbar support, a memory function and a manually adjustable thigh support. The M sports seats are fitted with active head restraints to reduce the risk of injury in a rear-end impact.
The luxurious interior ambience of the two cars is characterised by classy materials and dynamically moulded surfaces, and the bespoke design of the cockpit and centre console – cleverly drawing on the exclusive, high-performance sports car driving experience – lends it an extra individual flair. The instrument cluster with black-panel technology features classical circular instruments in traditional BMW M style, with red needles and white illumination, as well as model-specific displays and the M logo in the rev counter. The standard-fitted control system iDrive includes an on-board monitor with an exclusive flatscreen design, while the optional Navigation system Professional brings with it a 10.2-inch version of the Control Display bordered by a high-quality, galvanised chrome frame.
Arranged around the gearshift lever on the centre console designed specially for the new BMW M6 Coupe and Convertible are the buttons allowing drivers to select their preferred settings for all the adjustable powertrain and chassis functions. The DSC mode, performance characteristics of the engine, Dynamic Damper Control mapping, M Servotronic responses and M DCT Drivelogic shift program can all be adjusted independently at the touch of a button. This allows drivers to put together a detailed set-up configuration for their car and store it by holding down one of the two M Drive buttons on the multifunction steering wheel. The two standard-fitted M Drive buttons allow the driver of the new BMW M6 Coupe and Convertible to store a dynamic-led configuration under the “M1” button, for example, and a comfort-biased set-up under “M2” – and to call up either in an instant and at any time. The settings stored on the M Drive buttons can also be configured using the iDrive menu.
As with the cars’ performance characteristics, the aural profile of the engine can also be tweaked at the touch of a button. A sound module is used to enhance the engine’s natural acoustic components and this soundtrack is then transported into the interior. The system’s digital signal processing technology exchanges data directly with the engine management and adjusts its output to the engine’s revs, the amount of torque being produced and the car’s speed over the road. This gives the driver an impressively accurate impression of how hard the engine is currently working and of the power being unleashed, and provides an even clearer window into the car’s responses on the road.
High-quality standard equipment, exclusive options: M-specific Head-Up Display, M multifunction seats, Bang & Olufsen High-End Surround Sound System.
The exclusive character of the two high-performance sports cars is underlined by the high-quality and extensive array of standard equipment they have on board – not to mention an unrivalled selection of high-tech options lending further depth to the driving experience. Standard equipment for both models includes 2-zone automatic climate control, heated seats for the driver and front passenger, fine-grain Merino leather trim with extended features, an M driver’s footrest, exclusive carbon-fibre interior trim strips, door sill strips with “M6” lettering, plus ambient light in the interior, an automatically dimming rear-view mirror and exterior mirrors (the exterior mirrors also have a folding function), Cruise Control with braking function, an alarm system and the BMW Professional radio with HiFi loudspeakers.
The range of optional driver assistance systems and mobility services available from BMW ConnectedDrive add unique touches to the two new models. The M-specific version of the Head-Up Display – which, alongside a digital speed readout and tips from the optional Speed Limit Info also shows the gear currently engaged and a multicolour rev counter symbol, complete with Shift Lights – is joined in the line-up by features including Park Distance Control, a rear-view camera, High Beam Assistant, Speed Limit Info, Lane Change Warning and Lane Departure Warning, Surround View and BMW Night Vision with pedestrian recognition. Added to which, innovative technologies optimise the integration of the Apple iPhone and other smartphones, as well as music players, and incorporate the use of internet-based services. The Apps option allows iPhone owners to receive web radio stations, for example, and display Facebook and Twitter posts on the on-board monitor. The Real-Time Traffic Information function, meanwhile, keeps the driver supplied with impressively accurate and detailed traffic bulletins.
Additional highlights of the options list include the Navigation system Professional with hard disk storage, M multifunction seats with electric backrest width adjustment, active seats, active seat ventilation, Comfort Access, a heated steering wheel, the Soft Close Automatic function for the doors, and the Bang & Olufsen High-End Surround Sound System. This audio system brings high performance into the world of in-car sound reproduction. The fully active system with digital signal processing comes with individual amplifiers for all the bass speakers, mid-range speakers and tweeters. Its centre speaker uses the Acoustic Lens Technology developed by Bang & Olufsen. As soon as the audio system is activated, the central element containing the integrated mid-range speaker pops up from the instrument panel, prompting the tweeter lens to extend out at the same time. The total of 12 loudspeakers in the new BMW M6 Convertible and 16 loudspeakers in the new BMW M6 Coupe deliver a uniquely rich and dynamic sound experience.
2013 M6 Coupe Press Launch - Sakhir Orange
2012 M6 Convertible - San Marino Blue
2013 BMW M6 Coupe (F13) Exterior - Sakhir Orange
2013 BMW M6 Convertible (F12) Exterior - San Marino Blue
2013 BMW M6 Interior
2013 BMW M6 Studio Quality Wallpapers
2012 BMW M6 Coupe World Premiere @ 2012 Geneva Motorshow
Alpine White 2013 M6 Coupe
Black Sapphire Metallic 2013 M6 Coupe
Frozen Grey 2013 M6 Coupe
Frozen Silver 2013 M6 Coupe
Sakhir Orange 2013 M6 Coupe
2013 M6 Coupe
BMW M6 Convertible at 2013 Geneva Motor Show
Additional Photos from M-Power.com
These photos are part of the promotional material for the M6 Coupe and Convertible, courtesy of M-Power.com.
2013 BMW M6 Coupe and Convertible
Specifications M6 CoupeM6 Convertible
Body
No. of doors/seats 02/0402/04
Length/width/height (mm) 4898 / 1899 / 1368 4898 / 1899 / 1368
Wheelbase (mm)28512851
Track, front/rear (mm)1630 / 1612 1630 / 1612
Ground clearance (mm)107107
Turning circle (m)12.112.1
Tank capacity (l)8080
Cooling system incl heating (l)18.518.5
Engine oil (l)8.48.4
Weight, unladen, to DIN/EU (kg)1850 / 1925 1980 / 2055
Max load to DIN (kg)500430
Max permissible weight (kg)23502410
Max axle load, front/rear (kg)1180 / 1220 1200 / 1260
Max trailer load, braked (12%)/unbraked (kg)– / –– / –
Max roof load/towbar download (kg)– / – – / –
Luggage comp capacity (l)460300 - 350
Air drag (cd x A)0.33 x 2.29 0.33 x 2.29
Engine
Configuration/No of cyls/valves V90 / 8 / 4 V90 / 8 / 4
Engine technology M TwinPower Turbo technology with cross-bank exhaust manifold, Twin Scroll Twin Turbo technology, High Precision Direct Petrol Injection, VALVETRONIC and Double-Vanos M TwinPower Turbo technology with cross-bank exhaust manifold, Twin Scroll Twin Turbo technology, High Precision Direct Petrol Injection, VALVETRONIC and Double-Vanos
Effective capacity (ccm)43954395
Bore/stroke (mm)88.3 / 89.0 88.3 / 89.0
Compression ratio (:1)1010
Fuel grade RON 98 (min 95) RON 98 (min 95)
Output (kw/hp)412 / 560 412 / 560
@6000 – 7000 6000 – 7000
Torque (Nm)680680
@1500 – 5750 1500 – 5750
Electrical system
Battery/Installation (Ah/-)105 / luggage comp 105 / luggage comp
Alternator (A/W)210 / 2926 210 / 2926
Driving dynamics and safety
Suspension, front Double track control arm with M-specific elastokinematics, small, negative steering roll radius, anti-dive Double track control arm with M-specific elastokinematics, small, negative steering roll radius, anti-dive
Suspension, rear Integral-V multi-arm axle with M-specific elastokinematics, spatial suspension with anti-squat and anti-dive Integral-V multi-arm axle with M-specific elastokinematics, spatial suspension with anti-squat and anti-dive
Brakes, front Six-piston fixed-calliper compound disc brakes Six-piston fixed-calliper compound disc brakes
Diameter (mm)400 x 36 / vented 400 x 36 / vented
Brakes, rear Single-piston floating-calliper compound disc brakes Single-piston floating-calliper compound disc brakes
Diameter (mm)396 x 24 / vented 396 x 24 / vented
Driving stability systems Standard: DSC incl. ABS, ASC and MDM (M Dynamic Mode), CBC (Cornering Brake Control), DBC (Dynamic Brake Control), Dry Braking function, Start-Off Assistant, M Dynamic Damper Control, Active M Differential, linked to ICM (Integrated Chassis Management) Standard: DSC incl. ABS, ASC and MDM (M Dynamic Mode), CBC (Cornering Brake Control), DBC (Dynamic Brake Control), Dry Braking function, Start-Off Assistant, M Dynamic Damper Control, Active M Differential, linked to ICM (Integrated Chassis Management)
Safety equipment Standard: airbags for driver and front passenger, side airbags for driver and front passenger, head airbags for front and rear seats, three-point inertia-reel seatbelts on all seats with belt latch tensioner and belt force limiter at the front, crash-activated head restraints at the front, crash sensors, Tyre Defect Indicator Standard: airbags for driver and front passenger, side airbags for driver and front passenger combined with head airbags, three-point inertia-reel seatbelts on all seats with belt latch tensioner and belt force limiter at the front, crash-activated head restraints at the front, roll-over protection system, crash sensors, Tyre Defect Indicator
Steering Hydraulic rack-and-pinion steering with M-specific Servotronic function Hydraulic rack-and-pinion steering with M-specific Servotronic function
Steering ratio, overall (:1)13,113,1
Tyres, front/rear 265/40 R19 102Y 295/35 R19 104Y 265/40 R19 102Y 295/35 R19 104Y
Rims, front/rear 9.5J x 19 LM 10.5J x 19 LM 9.5J x 19 LM 10.5J x 19 LM
BMW ConnectedDrive
Convenience Optional: BMW Assist incl. Enquiry Service, remote-control functions, Real-Time Traffic Information, BMW TeleServices, integration of mobile devices Optional: BMW Assist incl. Enquiry Service, remote-control functions, Real-Time Traffic Information, BMW TeleServices, integration of mobile devices
Infotainment Optional: internet access, BMW Online incl. Park Info, National Info, Google Local Search, News, Realtime Weather, BMW Routes, Office functions, Bluetooth Audio Streaming, Online Update Music Tracks, Apps Optional: internet access, BMW Online incl. Park Info, National Info, Google Local Search, News, Realtime Weather, BMW Routes, Office functions, Bluetooth Audio Streaming, Online Update Music Tracks, Apps
Safety Optional: High Beam Assistant, Park Distance Control, rear-view camera, Surround View incl. Top View and Side View, BMW Night Vision with pedestrian recognition, Head-Up Display, Lane Change Warning, Lane Departure Warning, Speed Limit Info, Advanced eCallOptional: High Beam Assistant, Park Distance Control, rear-view camera, Surround View incl. Top View and Side View, BMW Night Vision with pedestrian recognition, Head-Up Display, Lane Change Warning, Lane Departure Warning, Speed Limit Info, Advanced eCall
Transmission
Type of gearbox Seven-speed M Double Clutch Transmission with Drivelogic Seven-speed M Double Clutch Transmission with Drivelogic
Gear ratios (I/II/III/IV) 4.806/2.593/1.701/1.2774.806/2.593/1.701/1.277
Gear ratios (V/VI/VII/R) 1.000/0.844/0.671/4.1721.000/0.844/0.671/4.172
Final Drive31543154
Performance
Power-to-weight ratio (DIN - kg/kw)4.54.8
Output per litre (kw/l)93.793.7
Acceleration 0–100 km/h (s)4.24.3
0–1000 m (s)21.922.1
in 4th/5th gear 80–120 km/h (s)3.6 / 4.5 3.8 / 4.8
Top speed (kph)250 / 305 250 / 305
BMW EfficientDynamics
BMW EfficientDynamics standard features Brake Energy Regeneration with recuperation display, Auto Start-Stop function, intelligent lightweight construction, on-demand operation of ancillary units, flow rate-controlled power steering pump, tyres with reduced rolling resistance Brake Energy Regeneration with recuperation display, Auto Start-Stop function, intelligent lightweight construction, on-demand operation of ancillary units, flow rate-controlled power steering pump, tyres with reduced rolling resistance
Fuel consumption EU (l/100km)
Urban 1414.4
Extra-urban 7.67.9
Combined 9.910.3
CO2 232239
Emission Rating EU5EU5
2013 M6 Coupe and Convertible U.S. Pricing and Ordering Guides - http://www.6post.com/forums/showthread.php?t=688440
Want more information navigate the tabs below
      02-11-2012, 05:11 PM   #2
avsbmw
21
Drives: 07 Z4MC
wow! sign me up
      02-11-2012, 05:11 PM   #3
uhn2000
Big K...
uhn2000's Avatar
171
Drives: M3CS BX7
Predictably insane! This is what I am talking about! Beautiful!
Many fun toys... M3CS XB7 FTW!
      02-11-2012, 05:12 PM   #4
CARBON1230
CARBON1230's Avatar
Poland
158
Drives: BMW
Looks great!
And my favourite steering wheel.
      02-11-2012, 05:15 PM   #5
RedBarron
133
Drives: BMW 440i
been waiting for this! Just need to find some money falling for the sky now.
Carbon Ceramic brakes, skeet skeet. That M6 badge on the kidney grills is cheesy though.
Current: Porsche Cayman S
      02-11-2012, 05:16 PM   #6
FANBMWM
If in doubt flat out - Colin Mcrae
FANBMWM's Avatar
Poland
127
Drives: BMW M5 F10 LCI SMB M2 LCI LBB
2010 BMW 760li  [10.00]
Very beautiful
      02-11-2012, 05:17 PM   #7
Zebra99
Zebra99's Avatar
112
Drives: 2011 335is E93
My next car! I don't care how much it'll cost me or getting it slightly used, the F13 is my next machine!!
      02-11-2012, 05:17 PM   #8
MCMLXXXIX
wat
MCMLXXXIX's Avatar
235
Drives: a gr3at whit3 5hark
so crazy!!! very well done. pure M6
and now let the complaining begin...
2012 Toyota Highlander SE - PAST - 2008 e92 335i, 2006 e90 325i
      02-11-2012, 05:17 PM   #9
rev7400
rev7400's Avatar
Drives: 15' 640i, 11' X3
I'm in love with the roof design
      02-11-2012, 05:18 PM   #10
kenhamm
Want to live in Germany
kenhamm's Avatar
Drives: 2011 550i, Dark Graphite, ED
Incredible is all I can say. Need to turn in my coke bottles
11 550i - Euro Del - 30.7.10, 20 days, 2998 miles,19.2 mpg, top speed 142 mph
08 550i - Euro Del - Retired
04 545i - Euro Del - Retired
79 528i - Retired-BMWCCA member since 1979
77 320i - Retired
Flying Ace4984.50
      02-11-2012, 05:20 PM   #11
uhn2000
Big K...
uhn2000's Avatar
171
Drives: M3CS BX7
+1000 the roof is awesome!
      02-11-2012, 05:23 PM   #12
IND-Distribution
BMW obsessed
IND-Distribution's Avatar
9572
Drives: G82 M4 / G87 M2
Love everything about it!
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMYOUTUBEFACEBOOKFLICKR
      02-11-2012, 05:23 PM   #13
as7920
as7920's Avatar
597
Drives: 2023 SG/FR M4 xDrive Competiti
Beautiful. Both of them are absolutely stunning.
      02-11-2012, 05:24 PM   #14
misterbeemer
40
Drives: E92, E46 M3, E39 M5, 750Li
Now those look AMAZING! Great job BMW! Love the front bumpers and the CF roof. I wish I could afford these.
      02-11-2012, 05:24 PM   #15
M3maniac20
M3maniac20's Avatar
87
Drives: 2013 BMW 335is Coupe
Everything looks amazing. I'm blown away, but I hope that M6 logo in the grille doesn't make it to production.
2016 340i M-Sport 6-MT(on order)
2013 335is (still have)
2011.5 M3 ZCP (traded in)
      02-11-2012, 05:25 PM   #16
catalyst
Drives: X1
Are those different color brake calipers I see?
Also, the M6 grille logo needs to go
      02-11-2012, 05:25 PM   #17
M3maniac20
M3maniac20's Avatar
87
Those seats also look absolutely amazing-look like they were pulled straight out of the Range Rover Evoque.
      02-11-2012, 05:26 PM   #18
abcde
Drives: 11 E90 335i M Sport LeMansBlue
This looks sooo good!
      02-11-2012, 05:28 PM   #19
Kinder
Kinder's Avatar
France
Drives: E39 M5 / Stolen&burned down :(
What is this fucking m6 logo on the grille ?
      02-11-2012, 05:30 PM   #20
FasterM3
BMW FTW
FasterM3's Avatar
Drives: F10
AMAZING.... What a beast...
      02-11-2012, 05:30 PM   #21
Jblack4083
116
Drives: E46 ///M3 JB/CB
Now thats a sexy car.
It's also a very safe design. I feel like the rear of the E63 was much more aggressive. The front of this new M6 is more aggressive than the E63 though.
The sound module thing that amplifies sound into the cabin is something I have mixed feelings about. It says to me that the car itself is comfortable enough to please everyone when they want to travel in comfort. The noise reduction in this car must be top of the line. However some of us like that noise, that's why we buy the ///M cars and not the regular number series. That is the conflict. Maybe for an ///M3 this is unacceptable but for a GT car like the ///M6 I think it fits because it's drivers are not the same type of drivers.
      02-11-2012, 05:30 PM   #22
alpine92m3
46
Drives: 2008 AW e92 m3 coupe
+1
Tags
2011 bmw m6, 2011 m6, 2012 bmw m6, 2012 m6, 2012 m6 coupe, 2013 m6 convertible, 2013 m6 coupe, 2014 bmw m6, 2014 bmw m6 convertible, 2014 bmw m6 coupe, 2014 m6, 2014 m6 convertible, 2014 m6 coupe, bmw f12, bmw m forum, bmw m forums, bmw m6, bmw m6 forum, bmw m6 forums, bmw sakhir orange, bmw san marino blue, f12 m6, m forum, m forums, m6 coupe, m6 forum, m6 forums, m6 sakhir orange, m6 san marino blue, new bmw m6, new m6, new m6 coupe, sakhir orange bmw, sakhir orange m6, san marino blue bmw, san marino blue m6, san marino blue m6 0
6post.com
