Vanos problems with cobb code p3100
02-07-2012, 06:49 PM | #1 |
104
Rep 1,529
Hey guys I remember seeing a couple posts about these damn vanos codes being thrown and just wanted to know if anyone has figured it out yet.
Nothing seems to be wrong with the car...everything seems to be running fine just the codes are being thrown...p3100 and p2A something. Either way wanted to know if this problem has been resolved and if it really is a threat to my car.
Space Gray l 6MT l OSG LSD w/ VAC Race Diff Cover l Cobb e30 l Morr vs8.2 l UUC SSK w/ DSSR l VSRF Catless Dps l RPI Intercooler l CDV Removed l HID AE 8000k l ETS Catback l AST 5200 w/ Vorshlag Camber Plates l ER Dual Oil Coolers l Rear Camber and Toe Arms l K&N Drop In l Solid Tranny/Diff/Subframe Bushings l Bridgestone RE-11
02-07-2012, 07:00 PM | #2 |
104
Rep 1,529
it was p2a87...vanos plausibility. do i need to change vanos solenoids?
02-07-2012, 07:22 PM | #4 |
70
Rep 2,626
I had this code along with limps even when the car was stock. changed the Vanos solenoids, and the problem disappeared.
'18 F80 M3 Comp 6MT - Stock
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar. '05 C55 AMG SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT | '07 E90 335i, PTF COBB E50, FBO, HFS4 |
02-07-2012, 07:52 PM | #5 |
104
Rep 1,529
hmmm i might try to take them out and clean them...i dont understand how these go bad
they dont get build up on them and its metal...and its not like they are electrical or anything its just a piece of metal with holes in it lol.
02-07-2012, 08:03 PM | #6 |
70
Rep 2,626
Oil flows in 'em, give it a shot
02-08-2012, 01:32 AM | #7 |
104
Rep 1,529
alright guys...so i went ahead and cleaned out my solenoids with brake cleaner...wiped everything down and reinstalled switching the bottom with the top.
conclusion is the car WOTS much better...i thought maybe it was placebo effect but it was not. i was looking for the car to run smoother as everyone said but while looking for the smoothness the car just pulled and pulled. i will give an update tomorrow after driving somemore in the daytime when the air is a little warmer.
02-08-2012, 07:18 AM | #8 |
Rep 13
2a87 is outlet-vanos jammed mechanically
I have the same fault. We replaced the solenoid and the cam sensor but the fault is still there. Friday we will replace the vanos adjustment unit. |
02-08-2012, 10:43 AM | #9 |
104
Rep 1,529
hmmm now thats interesting...hope the code does not come back on.
02-08-2012, 10:50 AM | #10 | ||
70
Rep 2,626
hopefully that will solve your problem Adem
02-08-2012, 10:54 AM | #11 |
104
Rep 1,529
lets just hope most of us dont get this problem lol. sorry for the luck adem.
04-15-2012, 04:54 PM | #13 |
169
Rep 1,247
I just got the half engine light and the P2A87 and P3100 codes . Is this something serious or not so expensive to fix? I know the P2A87 said vanos plausibility, I dont know what that means. And the P3100 had no description at all. Any help would be appreciated.
2009 E92 BMW M3.
04-15-2012, 04:58 PM | #14 |
169
Rep 1,247
Marwan, are VANOS solenoids an expensive fix? Ive just got these codes and not sure what to make of it. Or how much it would cost to repair.
2009 E92 BMW M3.
05-09-2012, 02:14 PM | #16 |
104
Rep 1,529
well the whole vanos thing seems to have gone away since ive cleaned them...its really easy to do and all i did was pull them out and clean them out with brake cleaner.
05-09-2012, 05:08 PM | #17 |
15
Rep 368
Gonna order mine today. Got half check engine light this weekend at wot. Same two codes. I think someone explained in another thread that the p3100 is an associated code that will really come as a result of the vanos code.
05-10-2012, 05:13 AM | #18 | |
263
Rep 2,563
I had the same problem when switching to COBB's stage 3 map, and replacing the vanos solenoids solved the issue. Alpina_B3_Lux
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
05-10-2012, 05:48 AM | #19 |
161
Rep 7,377
3100 is actually just the limp mode which shuts down the turbos to limit power, therefore the half engine light . Is always present with another code that actually caused it.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
07-21-2012, 02:13 PM | #22 |
Rep 374
I had the vanos code come up then had both solenoids replaced. Code popped up again and now I'm having the cam bearing ledge job done. 5 days left on factory warranty.
2008 335xi AT
Cobb AP stage 1, drop in filter, the rest stock 13.10@106.01 w/ 1.86 60' (5,800' altitude) |
