M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding
      02-07-2012, 03:16 PM   #1
AlpWhite11
66
Drives: 335i
Any M5 owners see idrive option to disable in cabin active sound function?
Someone speculated in another thread that there might be an option in the new m5 idrive that allows you to disable the active in-car soundtrack feature. Any owners out there that can confirm or deny this? :
      02-07-2012, 05:50 PM   #2
clar
clar's Avatar
Singapore
142
Drives: M5
No such option unfortunately
- Frozen Grey F10 M5 DCT
- Rosso Corsa 458 Speciale Sold
- Frozen Grey E92 M3 Sold
      02-07-2012, 06:23 PM   #3
sparkyg
sparkyg's Avatar
142
Drives: work truck
I speculated and I bet it is a hidden screen option.
Very few M5's out there but I am sure someone will find a way to get into the dealer programming screens...
      02-07-2012, 10:34 PM   #4
phish_100
17
Drives: Azurite Black F10M M5
There is an article that explains the fuse you need to remove in order to disable active sound. It's impossible via iDrive.
      02-08-2012, 12:18 AM   #5
audiobahn
12
Drives: bmw
if the radio is off, does it still work?
      02-08-2012, 02:20 AM   #6
savarona
22
Drives: Ferrari F430, M5, 3.0cs, e91
Good question. I was wondering that too.
      02-09-2012, 03:09 PM   #7
E90Fleet
South Africa
1311
Drives: BMW
Yes, it works with radio on or off
BMW if you are reading, I need a job, Please.
      02-09-2012, 07:29 PM   #8
mdh
Drives: E60 M5
Here's the Automobile article that explains the Active Sound, and what fuse you need to pull to eliminate it. It's the amplifier fuse #200 rated at 40 amps. If you eliminate the active sound, you lose the entire audio system.
      02-13-2012, 12:27 PM   #9
AlpWhite11
66
Drives: 335i
That's too bad. And I'm really curious how this works with aftermarket exhaust. Guess you just keep hearing the factory sound being played in the car supplemented with the exterior sound from the aftermarket exhaust. :
      02-14-2012, 08:50 AM   #10
mdh
Drives: E60 M5
That's got to be ridiculous. I'm sure the aftermarket people will come up with a fix, although it might have to involve an ECU reflash.
      02-15-2012, 04:57 PM   #11
aajami
aajami's Avatar
430
Drives: Space Gray '09 E92 M3
If the M5 was somehow amplifying the actual sound of the engine in real time through the speakers, though would be one thing (I'd still think it was silly). But the fact that it's playing a pre-recorded sound file of the M5 doing a dyno run is utterly ridiculous.
I'm sure tuners will be able to flash this off.
'09 E92 M3: Space Gray, Black, Carbon Leather | ZTP 2MK ZPP 2MT 6FL | link 1 / link 2
Mods: M Performance exhaust | ZCP retrofit | Euro airbox | GTS DCT flash | JPN 240 ECU flash | Euro LCI taillights | CRT lip | OEM alarm retrofit | Space Gray bumper plugs | BMW Performance: Mk. II spoiler / Mk. II non-electronic steering wheel / mirror caps / front grilles / side gills / intake louvers / emblem
      02-16-2012, 03:14 PM   #12
E90Fleet
South Africa
1311
Drives: BMW
Its a completely independent system that generates and feeds the sound into the sound system. No ECU flash will disable this.
Maybe unplugging the control box, but this may bring up errors.
There are actually 2 different versions of the system depending on which sound system you have
The car is supposed to be way too quite inside without it
Search this Thread:
Advanced Search
m5post
