E92 upgrade F10 auto shift knob (aftermarket part) with working LED light
02-06-2012, 02:28 AM | #1 |
Rep 8
Found this toy over the weekend, it's an aftermarket F10 Auto shift knob, easy installation only need to connect 2 connectors to synchronize with the shift indicators. Please see the youtube video for demo and below images for wiring. I do like the look of this F10 style shift knob, but with its' shape and you actually have to press the “button” behind the knob, it does feel a bit awkward when your shift. Maybe I'll get used to it. Last edited by yoshing; 02-06-2012 at 08:04 AM.. Reason: duplicated youtube link |
02-06-2012, 08:42 AM | #2 |
40
Rep 2,431
You should replace the stock shift plate with a Manual plate and boot since you don't need the PRND indicators off the shifter anymore. The Manual plate fits the Auto shift opening.
My speeding isn't the problem. It's the Slow Folks ahead of me that cause accidents!
02-06-2012, 08:56 AM | #3 |
Mr. Nice Says Hello
636
Rep 16,662
Drives: BMW M3 | X5 xdrive 35i MSport
02-06-2012, 09:11 AM | #4 |
40
Rep 2,431
None at all. I've done it with an SMG modded shifter. It's a direct swap and not very expensive at all, (Manual Shift boot). There was a custom harness made for this application to delete the external display and direct the signal to the shifter. With what you have, worst case you could just tuck the external display out of the way inside the shift tunnel.
02-06-2012, 09:23 AM | #5 |
40
Rep 2,431
Since you're a modder, you may be interested in the LCI update for the Shift Paddles. (See pic.) This is a really nice change and I use the Paddles more this way than I did the pre-LCI versions for some reason.
02-06-2012, 09:26 AM | #6 |
Rep 8
good idea, thanks, I'll have to check this out. Time to search eBay for manual plate.
02-06-2012, 09:36 AM | #7 |
Rep 8
I always want to do that, can you pm me with details as where I can buy these paddles for a good price and how to do the wiring? Since it shift differently. Thanks
02-06-2012, 10:33 AM | #8 |
40
Rep 2,431
There's no Cheap option, but this is the set I bought. These guys are absolutely fantastic in support. I had a little problem and they sent me pictures and a video on how to correct it. They do the rewiring for a small up-charge.
http://www.ebay.com/itm/BMW-E81-E82-...14894d&vxp=mtr
03-03-2012, 10:15 PM | #9 | |
50
Rep 390
Drives: 2013 X5 3.5 Premium
Garage List 2018 Mercedes E400 ... [0.00]
2008 Porsche Cayman S [10.00] 2020 Chevrolet Subu ... [0.00] 2013 X5 Premium 3.5 [0.00] 2017 Nissan Titan SV [0.00] |
03-03-2012, 11:42 PM | #10 | |
14
Rep 394
Where and how much?
2008 Monaco Blue/Tan interior 335i sedan. Mods: AFE intake w/ scoops, AFE Exhaust, ER FMIC, Koni FSD/Eibcach Pro-Kit, Breyton Race GTS wheels w/ Continental ExtremeContact DW tires, Cusco OS strut bar. BavAuto Black/Beige seat covers w/ black floor mats, M3 rep trunk lip, eBay front splitters.
03-04-2012, 12:10 AM | #11 | |
Coding
Rep 114
interesting price at dealer.... 400 for pedals.... hmmmm.... part # 61319242983 for Paddles if some one interested..... |
03-04-2012, 06:16 AM | #12 |
40
Rep 2,431
They aren't plug and play. They won't work without modifying the wiring.
03-04-2012, 01:14 PM | #13 |
14
Rep 394
Found the shifter on Ebay: $215
03-06-2012, 04:22 PM | #14 |
50
Rep 390
Sweet. Thanks for the link. That matches the shifter in my X5.
05-17-2016, 09:44 PM | #16 | |
73
Rep 199
Thanks! |
05-21-2016, 12:20 AM | #17 |
317
Rep 1,735
I feel like the double illumination is overkill
|instagram@underground6t9| |
05-21-2016, 11:39 PM | #18 |
73
Rep 199
So, I just did it today and like you hated the redundant shift display so used an OEM boot and trim from a 335i off of Ebay. Like it a lot better
http://www.e90post.com/forums/showth...2#post19977072 |
05-22-2016, 12:19 AM | #19 | |
317
Rep 1,735
09-09-2017, 04:40 PM | #21 |
203
Rep 739
Reviving this old thread. Just ordered the 2014 updated shifter from bimmian. All good. Now, for the plate delete, just get a manual shift boot? The manual will fill the entire space I believe. Only issue is that it seems most of these manual boots are just the boot, not the plastic tray that fits into the center console. Wonder if I can't just use my current plastic tray and wrap the bot around it, thus avoiding the necessity of dealing with the current shifter display embedded in the tray, if that makes sense. The boot will just cover it. Other option is to just put a piece of black non-gloss vinyl wrap over the current display portion.
Tags |
e92, f10 shift knob, retrofit |
