K&N FILTER..
02-05-2012, 08:50 AM | #1 |
16
Rep 261
K&N FILTER..
I just replace my old air filter with a K&N filter. At the same time I did the carbon delete and I must say, I definitely felt a difference! The engine doesn't feel as lazy as it did before. Really improved acceleration! Good and cheap engine mod!!
02-06-2012, 01:36 AM | #3 |
Rep 47
02-06-2012, 10:38 AM | #7 |
92
Rep 1,456
02-06-2012, 06:14 PM | #11 |
16
Rep 261
Wow that was corny! Lol! For some reason I thought I knew how bad the acceleration was on my own car!? Just when I thought I felt my car accelerating much smoother, u guys tell me its not true. Lol! Maybe the improvement was from going from a dirty paper filter to a new one?! Keep it comin!
02-06-2012, 06:44 PM | #12 | |
208
Rep 3,175
02-07-2012, 01:21 AM | #15 |
25
Rep 473
sure is alot of intake threads posting up latly about the same things! lol
02-08-2012, 08:26 PM | #16 |
93
Rep 229
what is the shape of your K&N air filter ...i can only seem to find the cone version for my canadian 323i e90 but i know its suppose to be rectangular with a slant on one side making it almost triangular??? and if yours is like the triangle can you please tell me the part # thanks a lot
2008 E90 Wrapped Matte Black & Carbon Fiber Roof, 19" Staggered Miro 111(Satin Black), Black Housing Halo Projectors, Satin Black Grill, Blacked Out Emblems, MTX Thunder Sub with Alpine Amp, K&N Air Filter, BMS PBX
02-13-2012, 09:53 PM | #17 | |
171
Rep 1,397
03-25-2012, 05:21 AM | #19 |
Rep 106
...this goes to the "placebo effect" and the "no difference" comments...You guys might want to search for Andrews comment from AA tuning, on the K&N filter and the effect it had on the "dyno" test. Maybe you'll change your minds. Something about the development of the Stage 2 AA tune.
03-25-2012, 08:30 AM | #21 |
21
Rep 270
I did my charcoal delete yesterday and K&N drop-in. I'm unsure if they're any noticeable gains, but I would say that airflow to the engine increases. At low RPM, the charcoal delete forces the engine to work a tad bit harder until it gets to higher RPMs. Without it, it seems to breathe much easier.
After changing it out, I noticed a small but noticeable decrease in lag when revving it. |
03-25-2012, 12:32 PM | #22 |
213
Rep 1,782
The only thing I noticed when I did It was that the engine got a little bit louder.
Koni special active red, eibach pro-kit springs, Remus exhaust, stage 3 intake manifold,Stage 2 AA tune, BMW Short shift kit. Silicon intake pipe. M3 control arms front, M3 rear. ECS trailing arm with whiteline bushings. Purple powerflex subframe bushings. Yellow power flex upper shock mounts. Single mass flywheel OE weight.
