How the N52 tick develops
02-03-2012, 05:47 PM | #1 |
My other ride is a Bianchi Infinito
96
Rep 2,767
There are thousands of articles on this issue, but none really cover my question...
For those of you who have had the head and/or lifters replaced how did it start? I bought my car in April of 2011, looking at the previous owners records I see he replaced the lifters on January 2011 for the ticking issue. It's only been 5,000 miles since then and I've been on the lookout for this issue. Only happened 2 times. Once, a few months ago, but it was very faint. Again, tonight, but tonight was a very loud and noticeable tick. I noticed it while moving my car from my driveway and it was screaming loud (the tick) I drove around the block to see what happens and it persisted. Seeing as how rare this happens what do you suggest I do? My 4/50,000 warranty ends 2/20 (2 weeks) then my CPO kicks in. I don't know whether I should waste my time bringing it in when it won't be happening or wait for it to be more often. I'm assuming CPO does cover this? |
02-03-2012, 06:15 PM | #3 |
96
Rep 2,767
02-03-2012, 09:31 PM | #4 |
37
Rep 608
When I had short commutes to the train station my car would tick... Now that my commutes are 20-30 mins of highway driving I haven't heard it upon start up. Others have had similar experiences... If I start city driving and short commutes it will tick for the first 5-10 minutes of driving... Honestly no worries about long term reliability, but others have replaced lifters and cylinder head with mixed results... I had lifters replaced and it quieted it down...
There is a TSB about the tick, so your dealer should do it. I believe they replace lifters then the cylinder head in that order... |
02-03-2012, 09:35 PM | #5 | |
151
Rep 2,638
02-04-2012, 11:39 AM | #6 | |
96
Rep 2,767
02-04-2012, 11:44 AM | #8 |
***** noob
1370
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
had ticking for 6 years and car drives the same as day 1..... dont worry about it and just drive your car
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
02-04-2012, 11:48 AM | #9 |
96
Rep 2,767
You're right a lot of people notice it and don't really care, stating that it had no long term effect, but I would like to fix it if I could under warranty once and for all.
02-04-2012, 11:54 AM | #10 |
151
Rep 2,638
02-04-2012, 12:12 PM | #11 |
***** noob
1370
Rep 10,479
its not just the 3 series that have lifter ticking/knocking sound...it appears on all n51/2 engines all across bmw lineup...IE x3, z3, 5..also on previous e46..etc
if this was a real problem then BMW would already been out of business if you wanted a quiet engine then why not buy a lexus/ toyota, you bought the bimmer and you should trust their engineers do some research on hydralic lifters and how they work most of the problem is caused by new owners coming to the forums and see these ticking threads and trolling starts one after another not flaming on you but just fyi
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) Last edited by ska///235i; 02-04-2012 at 12:30 PM.. |
02-04-2012, 12:15 PM | #12 | |
44
Rep 1,011
if you are asking how the "ticking" starts or what makes the "ticking" come alive on the N52... then the answer is i dont know.
replaced my lifters few months back (6months at most) and now after new lifter's first winter, the ticking seems to have come back and visits more frequent. best way to temporarily fix the issue seems to be adding some engine oil before starting your car. cant do it every time since you aren't supposed to over fill, but when i know its cold out side... i add a bit. as of jan 12th 2012 my "new car" warranty was over and now my CPO is the only thing left. though out of pocket for a new head replacement will be much much more costly than $50 i dont find it really really necessary to take the time to fix it as of now. Quote:
driving is poetry in motion. Last edited by krnboy817; 02-04-2012 at 12:32 PM.. |
02-04-2012, 12:22 PM | #13 | ||
96
Rep 2,767
The most essential part of a car is oil I believe, oil starvation can not be a good thing. Quote:
Come to think of it though, I had my oil changed since the lifters for the first time a month ago. Wonder if that brought the noise back from the dead. |
02-04-2012, 12:46 PM | #14 |
44
Rep 1,011
1st time: ticking appeared in the summer... around July and it was about 110 outside consistently for about 3 weeks. my service odometer read 10,000 miles until due.
lifters replaced. oil was changed. and ecu reset/reprogramed to the latest. since then maintenance at 40k miles was done. and with the oil change the ticking came back 2nd time: lifter replaced. winter been no more than 39 degrees. ticking came back after morning start. then started to tick even after 2 hrs of driving and cold starts/warm starts. here is my vid. before the replacement it was TICK TICK TICK TICK now after the replacement its TICK... TICK... TICK... wondering if this is same as your case. this is after 2hr drive ... about 110 miles of hwy driving at about 75 ~ 80 mph oh and according to TSB build date of Jan 2006 - Sept 2008 has this issues as common.
driving is poetry in motion. Last edited by krnboy817; 02-04-2012 at 06:35 PM.. |
02-04-2012, 03:19 PM | #15 | |
Rep 32
Drives: 2009 328i xDRIVE Sedan
http://www.e90post.com/forums/showpo...postcount=1310 Also, if you're not interested in going through the dealer for the engine head change/update, you can try some of the options described in this thread, like changing oil weight. http://www.e90post.com/forums/showpo...postcount=2036 Personally, given that you have 2 weeks left of CPO, I would park the car overnight at the dealer, and the next day show up and turn the car on with the SA and a mechanic present, so [hopefully] they hear the tick. By the way, I'm curious, when was your car manufactured? |
02-04-2012, 04:32 PM | #16 | |
96
Rep 2,767
My service manager replied to me this: We would have to get the car in and diagnose it. Them do a puma case and get approval to replace the head. Please let us know if you would like us to do that. Thanks He sounds more than helpful about it. I just know that the PUMA case will take forever though. |
02-04-2012, 05:15 PM | #17 |
62
Rep 1,452
When I had the ticking noise on my car, it was really loud. I don't see how any one can ignore it. It's embarrassing...
02-04-2012, 06:39 PM | #18 | |
44
Rep 1,011
best way for you is to record or take a vid when it ticks and take that to the dealer. because when you get the lifter replaced... the work order and the SA will tell you that its a 2 step process and lifter is the first part. if that solves it then its all done but seems like head replacement is what most people are having to do. and on my replacement lifters, i got guarantee for 15k miles on the work BMW did. so if i didn't have warranty the lifter related ticking issue would of been covered.
driving is poetry in motion. |
02-04-2012, 08:36 PM | #20 | |
96
Rep 2,767
02-05-2012, 11:15 AM | #21 |
38
Rep 715
I had the lifters replaced then the head. Both times I heard the loud ticking the conditions were about the same...
- Leave car in garage overnight (cold weather by California standards). - Start car in the morning and drive it out of the garage to wash or detail it. (no warm up) - Drive car back into garage a couple hours later. (no warm up) - Leave car in garage for another cold night. - First start next morning - tick, tick, tick. It didn't ramp up slowly over time. It happened suddenly. It seems to be related to cool weather, a cold start followed by one or two very short drives, more cool weather and then a cold start. OP: If I were you, I'd try a sequence like this or like others have posted on the "ticking" thread to see if you can reproduce it. If so, record it with a smart phone like another poster suggested. At the beginning or end of the recording, walk around to the back of you car to make sure you show your license plate. |
02-05-2012, 11:22 AM | #22 | |
96
Rep 2,767
