My next mod...please help
02-02-2012, 09:26 AM | #1 |
Rep 31
I am going with the cobb access port early next week...For you guys that have that as well what other mods have you seen the most power with...should I do, exhaust, intake, downpipes etc. I am looking for the one that you have seen to make the most power for the money...let me know thanks.
BJ |
02-02-2012, 08:15 PM | #4 |
37
Rep 458
Downpipes would be great, especially if there isn't any emissions testing where you are. I'm currently running stock downpipes for emissions, but can't wait to switch back to my AR catless ones.
If emissions is an issue and you don't want to switch back and forth, you could do meth and/or an intercooler. |
02-03-2012, 09:14 AM | #6 |
37
Rep 458
Excellent, was that one of the roadside locations or did you have to go in and be put on the rollers?
Would be much easier for me to just switch out the stock exhaust to pass instead of doing the downpipes too. |
02-04-2012, 09:53 PM | #8 |
king of the hills
92
Rep 2,915
Drives: 2011 M3 w/ESS55, 2001 540i/6
Long as you go in with fully warmed up car and have O2 sims, you should probably be able to pass the emissions tests in CO with catless DP's. From what I remember, the mid cats actually do most of the work anyway once the car is running at operating temperature. Andrew can probably chime in on that better though.
02-07-2012, 01:59 PM | #10 |
king of the hills
92
Rep 2,915
BTW, this exact same question was posted in the N54 forums.
http://www.e90post.com/forums/showthread.php?t=644123 |
02-07-2012, 11:53 PM | #12 |
king of the hills
92
Rep 2,915
I believe you Vincent
02-09-2012, 01:03 PM | #13 |
Rep 31
Thanks for all the advice...The tune helped at ton!! I just got my emissions so I will probably do the downpipes because I will not have to get it done again for 2 years and odds are I will not hang on to the car for that long...I will probably do the intercooler too...Between the catless downpipes and the intercooler which one is seing more gains in power?
02-09-2012, 03:22 PM | #16 |
99
Rep 6,473
