BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > Clunking noise from rear **Video Inside**
      01-31-2012, 06:08 PM   #1
Rockyca
34
Drives: 2016 340i M-Sport
I am getting a clunking noise from the rear especially when transferring loads. I can reproduce it by rocking the car back and fourth with quite a bit of force. Check out the video and let me know what you guys think.
Thanks a bunch!
Car is a 2006 323i 6mt. Has around 75k miles on it.
      01-31-2012, 06:09 PM   #2
DJ Apex
DJ Apex's Avatar
25
Drives: 2006 330i
fail link! (FIXED LINK) lol
Sounds like rear end monuts, letting the rear end move up and down when load is on and off. Or drive alxes . best bet is get it in the air and get under the car while u move the wheel with your hand..
but i may be wrong ive never played with the rear end of my e90
      02-03-2012, 10:37 PM   #3
Volasko
Volasko's Avatar
705
Drives: 06 330i E90, 18 530xe G30
Well it sounds like something is loose. Get it on a lift and start swinging that rubber mallet, not too hard of course! That noise will be easily recreated which should make it pretty easy to find the loose connection.
      02-03-2012, 11:02 PM   #4
Rockyca
34
There is something up within the differential itself. The input bearing is shot, already figured that out, and I am sure that there is something else causing excess play in there. I have a new 3.64 diff sitting in my garage that will go in tomorrow. I will update with results.
      02-04-2012, 09:01 PM   #5
larns576
Drives: 328i
my car made a similar noise whenever i shifted from R->D and D->R. The dealer said they lubed the rear diff joints and end plate and replaced some gasket. According to the Service Receipt, there seems to be a bulletin on it.
