Help? Part Number Request or DIY Removal Instructions
05-29-2007, 12:43 PM | #1 |
13
Rep 429
Hi guys,
I have a 335i E92 with no heated seats or rear sunshade. The area where that bank of buttons is normally placed is BLANK on my car. It's just a flat piece of panel trim. Does anyone know how to remove this part from the car? It's the panel directly underneath the CD/DVD drive in the vehicle, and it's the piece where the heated seat buttons would be mounted if I had heated seats. If anyone has a part number for this piece, I'd also be very appreciative. Goal here for me is a custom mounted V1 + Blinder XTreme panel integrated into the car... I will post a DIY of the whole thing if I could figure out how to get the damn piece off. I'd also like to order a "spare" since I'm pretty much going to be doing a lot of work with a drill and dremel and if I have to abandon the project, I'd like to go back to looking like stock instead of having a trashed console. |
05-29-2007, 08:19 PM | #2 |
Rep 16
You obviously haven't found www.realoem.com. It has part diagrams and part numbers for everything you neen. That switch panel has about a dozen versions depending on which options are installed. If you pick one and get a replacement, it might help you figure out how it is attached.
05-29-2007, 09:17 PM | #3 |
Rep 16
I apologize. I think your question stands. I can find any variation of the switches, but no sign of the panel they mount in, anywhere in realoem. Under the i-drive section (category 65-45), there is a panel shown that has blank and non-blank versions. I cannot find the equivalent for non-idrive. The section under heater controls shows the panel surround, but the part number is not listed.
05-30-2007, 12:28 AM | #5 |
13
Rep 429
Actually, here's the tricky part-- I did know about REALOEM, but what I should have mentioned is that I have a late 3/2007 model E92-- the one with the new quick-buttons. That means that the part listed on RealOEM actually won't fit...
I will go down to the dealership and see if their parts department can help me out. Thanks for the help though, DHarold, it's much appreciated. |
