DIY: Replacing Foglight Bulbs(aftermarket or OEM). 56k death.
10-27-2005, 09:08 PM | #1 |
missing two turbos.
574
Rep 4,859
Drives: fast around corners.
Before you do this:
1. Do it at your OWN risk. 2. MAKE SURE TO USE JACK-STANDS when you lift up your car. I didn't use it this time because I already did this before and it took me few minutes to complete. I did use extra support jacks when I did it the first time. 3. DO NOT touch the bulb with your barehand. Hold the base, never the bulb itself. 4. You might need to do extra work if you have big hands. Instruction: 1. Tools I used. 8mm socket, wrench, 2-ton jack, extra light support, aftermarket yellow foglight bulbs. Oh yeah, and small hands required. 2. Lift your car. You don't have to lift it alot if you don't have big head. 3. Get under the car, Take off all the bolts that the red arrows are indicating. Close-up pic of the 3 bolts you can't see. One of the "bolt" in the middle is actually a clip. Pull out the middle piece with minus screw driver. real easy. Close-up pic of the bolt you have to take off by the fender area. 4. Pull the air-splitter thingy off. 5. Pull the whole plastic panel off. 6. Now you'll see the foglight bulb in place. 7. Reach for it, and twist the bulb socket off the foglight housing. 8. Take the socket out, take the bulb out, replace it with new ones. 9. Place the bulbs you've taken out in a safe place if you plan on using them in the future. 10. Put the new bulb in. Put the bulb socket back in, the exact same way you took it out but reverse twist. 11. Reverse process, put everything back in, screw the bolts/clips back in. Enjoy the new bulbs. For comparison between the Luminics JDM Yellow bulbs vs OEM bulbs, please refer to this thread.
06 AW E90 330i ZPP/ZSP/Step/Expired Warranty : Prior Design Front : ACS Rear : ACS Roof : BlackLines : Simota Intake : Carbon Fiber Interior Trim : : MTEC V3 : 24% Charcoal : V1 Hardwired : Solaris Invisibulbs/LED interior : |
10-27-2005, 09:29 PM | #3 |
missing two turbos.
574
Rep 4,859
Thanks mark.
10-28-2005, 10:49 AM | #5 |
96
Rep 649
Drives: 2006 BMW 325i
great post. Thanks very much
10-31-2005, 10:08 AM | #8 |
12
Rep 456
Drives: X3 + 325xi
This is why this forum is the best!
01-19-2006, 12:30 AM | #10 |
missing two turbos.
574
Rep 4,859
No problem.
What model is my foglight? I don't quite understand that question.. Its Luminics JDM Yellow bulbs for H11 application.
01-24-2006, 05:52 PM | #11 | |
Rep 3
I WANT ASK HID FOGLIGHT FOR E90 IS H7 OR H11??? THANKS YOUR HELP |
01-24-2006, 07:06 PM | #12 |
missing two turbos.
574
Rep 4,859
JNg1, H11 works perfectly fine.
01-26-2006, 10:40 PM | #13 |
MAUI BUILT
485
Rep 7,781
Drives: 2006 330i MT
Nice wright up Lux! I may end up replacing with some ION yellows again.
Danny
Arctic/Blk Leather/Alum.Trim/MT/ZSP/Sunshades/Blk Lines/M3 Illuminated Knob/Alcantara Performance Wheel/M-E-Brake Handle/Euro Fog Switch/Koni Yellows/H&R Sport Springs/19" VMR V718's w/PS2 Tires/M-Tech Body Kit/Carbon Fiber Spoiler/Bimmian Interior Bulbs/OEM Eye Glass Tray/SSK/Alcantara Boot/Split Armrest/OEM Dual Rear Power Outlets/Rear Ashtray Delete/OEM Alum. Pedals/Osram 6000K/Brex Rings/LED Side Markers/BMS Power Box
01-26-2006, 10:42 PM | #14 | |
missing two turbos.
574
Rep 4,859
Post some pics when you do. Ion Yellows look great from what i've seen so far.
01-26-2006, 11:41 PM | #15 |
Rep 433
Looks good...thanks for the DYI pics
2006 330i Sparkling Graphite/Sport pkg/Comfort Access/Aluminum Pedals/35% LLumar tint/Blacklines/OEM Shortshift knob |
01-28-2006, 01:04 PM | #16 |
Vroom Vrrooooom
297
Rep 3,146
Drives: 330i
Nice how to....
while crawling around in that fog light space, did you see any open spaces where an HID ballast could be mounted next to the bulb?
-Dmitriy
06' BMW 330i & 03' Suzuki GSX-R600 SG | Beige Dakota | Poplar || iDrive w/MP3 | PP | SP | CWP | PDC | Comfort | Shades || 40% Tint | Black Line Tail Lights | Hardwired V1 |
01-28-2006, 03:36 PM | #17 | |
missing two turbos.
574
Rep 4,859
01-28-2006, 04:46 PM | #18 |
Vroom Vrrooooom
297
Rep 3,146
Drives: 330i
Im going to be ordering the chepo HID's for the fogs. I figure since its only 225 bucks shipped, if they break in a few years I wont care. But I need some place to mount them.
Its probably a 3x4x1 inch brick. Hopefully there is something I can either zip tie the thing to or screw it to some hidden plastic pieces.
-Dmitriy
01-28-2006, 05:13 PM | #19 | |
Chicketeh china the chinese chicken, you have?
34
Rep 790
Drives: 335ci hold out
will that bulb fit in the OEM foglight socket? If they offered that kit with 5k bulbs it'd be sick.
"In Soviet Russia car forks you!"
01-28-2006, 05:48 PM | #20 | |
missing two turbos.
574
Rep 4,859
If you can't "hang" around them there, try building a custom mount for it or use 3m double sided tape to stick it somewhere. Let us know if you go on with this install.
01-28-2006, 07:00 PM | #21 | ||
Vroom Vrrooooom
297
Rep 3,146
Drives: 330i
Here is my 3000K HID Fog Lights Thread This is the Honda Tech thread that is selling my 3000k kit for $225 shipped. Quote:
I will probably place my order tomorrow and they should arrive in a few weeks. Since you're in Cali, you can order from the first thread for 240 and get them the next day probably.
-Dmitriy
01-28-2006, 07:37 PM | #22 |
34
Rep 790
Thanks man! that's hot!
