255/35/18 Square
01-24-2012, 09:50 AM | #1 |
A family of bimmers
2748
Rep 7,742
255/35/18 Square
Im looking to put the VB3s that are 18x8.5 et 40 on my E90 LCI.
Can 255s fit with this offset? I know i can run 235s but im looking to go 20mm wider in the tires. Has anyone ran this set up? I know the staggered setup from BMW has 255s in the rear on an 8.5. Im curious if the front will clear. I have the sports package if that means anything for the xdrive. Thanks!
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills Last edited by wdeerfield; 01-24-2012 at 11:42 AM.. |
01-24-2012, 11:43 AM | #3 |
A family of bimmers
2748
Rep 7,742
Im afraid the front will rub the inside and if i use spacers it will rub the fender or poke too much. Just curious if others have ran this setup without issues and what their front et was.
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills |
02-18-2012, 02:57 AM | #6 |
91
Rep 1,324
Drives: 335i Coupe, 6 Speed
I'm on 255/35/18 fronts with an e92, 18"x9" wheel with +32mm offset and -1.1 degrees of camber. Without much camber, it'll depend on your tire choice. Some tires just run really wide.
02-20-2012, 10:57 AM | #8 |
31
Rep 595
I'm running the OEM 193M rear wheels in the front of my E92. So the wheel spec is basically 18x8.5 +37mm offset, no spacer, stock sport suspension, 255/35 Yoko AD08 (wider than most other 255/35 tires), no rubbing whatsoever.
02-20-2012, 11:27 AM | #9 | |
91
Rep 1,324
Now I'm slightly lowered on AST 5200's, running a 9" wide wheel at 32mm offset, and 255/35/18 Hankook Rs3's which tend to run super wide. -1.1 camber still and absolutely no problems with rubbing. |
02-20-2012, 11:32 AM | #10 |
31
Rep 595
^^^ Nice!!! How much room do you have inside (from tire to strut)? I've always wonder if we can get away with 9.5" wide, 275 tires, and at least -2.5° camber.
04-18-2012, 01:00 PM | #11 |
A family of bimmers
2748
Rep 7,742
bump, just looking to see if i can run a 5mm spacer upfront with 255s FRONT and REAR on 18x8.5in rim on a SEDAN
04-18-2012, 08:52 PM | #12 |
A family of bimmers
2748
Rep 7,742
no one? really? looking to buy tires and was hoping someone would chime in. not a single e90 on this site running 255s square?
04-19-2012, 08:26 AM | #13 | |
2006 330i, TSM, Black, manual, sport
878
Rep 3,699
Drives: '17 C2, GTI, Z4 3.0si Racecar
18x8.5 et33 net. I'm lowered quite a bit on c/o's so we just shaved the adjusting nut and are running stock alignment. I'm running Michelin PSS.
2017 Porsche C2 - manual of course
2015 GTI S 2008 BMW Z4 3.0si Coupe - because racecar |
04-19-2012, 10:05 AM | #14 |
A family of bimmers
2748
Rep 7,742
thank you! any pics you could share?
04-22-2012, 01:57 AM | #15 |
20
Rep 220
+1
Any e90 xi owners on this thread want to chime in? I am waiting for the new Apex 18's to be announced next week and I am eagerly looking to run square. but I need to see if a 9.5 et 35 wrapped in a 255/35 or 40 will work on a stock fit. |
