Code "2FBC"...?
01-16-2012, 11:21 PM | #1 |
83
Rep 2,132
Drives: FBO+ N54xi
Code "2FBC"...?
Hello,
Well my car feels like i'm deff. having misfires and in the morning during cold start ups, has been acting really weird...rpm's jerking around and also car would hesitate when i start driving and give it a bit gas. I'm out of warranty and wanted to take my car somewhere tommorrow cuase it has been leaking a bit oil from the cap, so i thought let me open up my BT Cable and check for any codes, and this is the only code that came up.. BTW. I havnt had any limp modes or SES light come on or anything..So i was suprised because i even had a tech at a local bmw/benz shop say that the car is deff misfiring, but like i said no ses or limp modes...Any opionions/clues much appriciated.. 2FBC: 2FBC Fuel pressure control valve, signal Error will cause a warning light Error is not currently present Test conditions have been completed Timeout Freeze Frame Information Event 1Odometer 61840kms 38425miles PWM-Signal of mass control valve 8.59 % rail pressure 8,151.11 hPa operation mode actual value 2.00 0-n status motor control 0.00 0-n I know i have all those mods listed, but been running without any mods for the past 6+ months. Thank's.
JB4+usb | P3 Vent Boost Gauge v2 | BMS OCC | BMS DCI | AMS FMIC | AR xi CL DP's | BT Tool | Edibias/NCSExpert/INPA BMW Coding | Cyba Quad Exhaust tips | M-Tech Rear & M3 Front Bumper | Red Cyba Air Scoops | Blacklines | Vinyl Overlays | ACS Roof Spoiler | Matte Black Grilles | LED Side Mirrors | Rear Euro Fogs | etc..
01-17-2012, 08:42 AM | #2 |
Some dude
92
Rep 1,780
My thought is HPFP control is going bad. The fuel pump puts out more or less pressure/volume to the rail based on demand. The Fuel Volume Control Valve is located on the HPFP and cannot be replaced separately. Either you have a bad connection at the HPFP or the control valve on the HPFP is bad.
RRT
E92 335i/6MT with stuff and things |
01-17-2012, 09:19 AM | #3 |
161
Rep 7,377
new pump needed , you get it for free anyway.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
