01-12-2012, 05:46 PM | #1 |
BimmerPost Supporting Vendor
2895
Rep 21,660
▀▄ eas | KW Coilovers- Your #1 Source for V1, V2, V3's! -In Stock
eas is proud to be an authorized KW dealer and supply your BMW's performance suspension needs!
Variant 1 Featuring sporty handling with factory pre-set damping, the KW V1 Coilover system is ideal for customers wishing to rely on the experience of KW's engineers to set the damper setting, yet determine their own degree of lowering. In extensive driving tests KW's engineers have set the dampers for the best balance between sporty driving, comfort and safety. The user is then free to decide the best height setting for their use and preference. All KW coilovers pass stringent German TUV safety and quality testing standards. Each kit is sold TUV approved. Features: -Optimally pre-set -Sporty harmonious damping technology -"inox-line" Stainless steel technology -Individually height-adjustable -Lowering range approved by the German Technical Control Board (TÜV) -Fully finished complete solutions -High-quality component parts for long durability -Comprehensive documentation for easy use Variant 2 The KW Variant 2 coilover system is intended for the experienced driver who does not only wish to determine the individual lowering of his vehicle, but also wishes to carry out setup adjustments. The adjustable rebound damper allows adjusting the pitch and roll behavior of the vehicle and therefore the driving pleasure can be adapted to the own requirements. The rebound adjustment can be installed via an adjustment spindle at the piston rod end, as far as it is vehicle-specifically possible. The rebound damping primarily controls pitch and roll of the vehicle, especially in the low speed damping range which directly influences handling and comfort. Therefore vehicle can be adjusted to the needs of the driver, making the ride variable from comfortable to sporty and stiff, both with improved road handling. All KW coilovers pass stringent German TUV safety and quality testing standards. Each kit is sold TUV approved. Features: -Damping technology with individually adjustable rebound -"inox-line" stainless steel technology -Individually height adjustable -Adjustment parameters approved by the German Technical Control Board (TÜV) -Fully finished complete solution -High-quality components for long durability -Comprehensive documentation for easy use Variant 3 The KW coilover suspension system enables the owner to substantially lower their vehicle while retaining enough travel to handle maximum load and dynamic loads during driving. Variant 3 permits an even higher degree of customization to the suspension. Adjustable (and independent reacting) rebound and compression damping allows a truly individual performance driving setup for those technically demanding drivers. Compression dampening adjustment is conducted in the low-speed range, while the high-speed set-up, so decisive for driving comfort, has been pre set by KW engineers. Important characteristics such as safety, quality and performance are all taken into consideration with each KW coilover design. Each vehicle application is specifically designed and engineered for a proper range of motion, min/max weight loads and min/max lowering. All these requirements are met while retaining it's performance handling characteristics. Each KW coilover suspension is produced with unique stainless steel "inox-line" technology. The stainless steel construction internally and externally provides long term durability and corrosion resistance from the elements. All KW coilovers pass stringent German TUV safety and quality testing standards. Each kit is sold TUV approved. Features: - Independently adjustable damping technology - rebound and compression damping - "inox-line" stainless steel technology - Individual height adjustment - German TUV-tested adjustment parameters - High-quality components for long life - Comprehensive documentation for ease of use - Infinitely adjustable rebound damping - 14- level adjustable compression damping - Unique, independently functioning damping power adjustment *Availibility of Variants depends on Vehicle Make & Model FREE SHIPPING in the Continental United States. Ordering: Phone: You can reach us directly by calling 866.669.0705 to place your order over the phone. Payment: Credit/Debit Cards: Visa, Mastercard, Discover, PayPal, Google Checkout (available online & over phone) Other Payments: Money Order/Cashier’s Check & Bank Wire Transfer are also available. Please contact us to pay with either of these methods. Tax: All CA customers will be charged 7.75% CA Sales tax. Shipping: All orders will be shipping via UPS. If you are interested in shipping to Hawaii, Alaska, or internationally, please contact us directly, as you will be charged additional shipping fees. Hours of Operations: Monday - Friday from 9AM to 5PM PST Saturday/Sunday - Closed Retail Location/ Installation Center: Come check out our 8000 square foot facility in Anaheim, CA. We install everything we sell. Contact Info: Phone: 866.669.0705 x31 Email: kevin@europeanautosource.com Website: http://www.europeanautosource.com Feel free to contact me via PM, email, or phone if you have any questions.
Kevin S. | european auto source (eas)
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by kevin @ eas; 07-03-2018 at 12:35 PM.. |
01-25-2012, 06:48 PM | #2 |
2895
Rep 21,660
Thanks for the inquires. Come get your set installed or shipped today!!
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
01-26-2012, 11:13 AM | #4 |
2895
Rep 21,660
PM coming your way!!
04-25-2012, 06:41 PM | #6 |
303
Rep 4,002
Call us to order your KW today!
Robert T. | european auto source (eas)
email: robert@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x21 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
04-27-2012, 12:50 PM | #7 |
230
Rep 1,481
Drives: '11 M3 MW/FR - '12 M3 FO/SC
Garage List 2004 Honda Hornet [0.00]
2003 Chevrolet 2500 ... [0.00] 2011 BMW S1000RR [0.00] 2011 BMW E92 M3 [0.00] 2012 BMW E92 M3 [0.00] |
Please PM me all my options for a non-EDC E92 M3 shipped to 78261
04-27-2012, 01:30 PM | #8 |
303
Rep 4,002
PM on the way!
05-04-2012, 04:38 PM | #9 |
303
Rep 4,002
Call eas to order your KW Suspension
05-11-2012, 03:20 PM | #11 |
2895
Rep 21,660
Call today to get your KW's!! Order shipping out daily!
05-18-2012, 04:17 PM | #12 |
303
Rep 4,002
Get your KW Coilover Suspension now! Call eas to order
05-25-2012, 04:34 PM | #13 |
2895
Rep 21,660
Thanks for the inquiries!! Get your KW's today!!
06-27-2012, 06:20 PM | #14 |
2895
Rep 21,660
Get you KW coil overs today!! New orders shipping out daily!!
06-28-2012, 11:05 AM | #16 |
2895
Rep 21,660
06-29-2012, 12:22 PM | #17 |
2895
Rep 21,660
Get your KW coil overs today!! PM for special pricing
