TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wash, Wax, Detailing and Cosmetic protection/repairs > Help!!!!
      01-09-2012, 04:01 AM   #1
lopealle
Resident Black Guy
lopealle's Avatar
Zimbabwe
251
Drives: Lion
2006 M5  [10.00]
Help!!!!
I did a little correcting my car...which came out awesome by tthe way. I put some collinite on and that stuff is hard to remove. What can i use to break it down a little?
      01-09-2012, 07:48 AM   #2
autoaesthetica
13
Drives: A tin can on boost
If you havent already, try some QD and misting on to aid removal. Sometimes distilled COLD water misted on helps flash set the wax to make it easier.
..I suspect its probably on there just a little thick. Many people accidentally do it with the collinites.
If all else fails and you have exhausted everything to get it off, make sure the car is clean, re-apply the wax to the areas where it just wont come off - then wipe it right back off. THe solvents in the fresh wax will re-suspend the dried on stuff and allow it to be wiped right back off. Just make sure the car is clean.
      01-09-2012, 08:57 AM   #3
MuttGrunt
27
Drives: beater;)
Correct as usual. OP, for future use, ALWAYS make sure to apply wax as thin as humanly possible. Not only will you get better protection from doing so, you'll also get better durability.
There are some things in which more is more, but when it comes to wax and sealant, less truly is more.
Good luck and happy detailing!
      01-09-2012, 12:52 PM   #4
lopealle
Resident Black Guy
lopealle's Avatar
Zimbabwe
251
Drives: Lion
2006 M5  [10.00]
Funny thing is i thought i was going thin....
Thanks for the advice guys
