Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY - LED License Plate Light
      05-23-2007, 10:06 PM   #1
Shinchan
LED Rules
Shinchan's Avatar
59
Drives: Sold: 335xi Coupe
First... credit goes to RikuE90 for the Idea.. and one picture from his DIY.. since, i no longer have the unmodified Plate light housing.
and the difference between my DIY and RikuE90 is that my DIY does not require extra resistor to be solder on. The only modification need is modify the plate light housing.
Same as all DIY goes, use at ur own risk... i am not responsible for ur car.... and ur attempt....
and best of all.. it STAYS ON... AND NO ERROR MESSAGE..
I have E92.. and I am not sure if E90 has the same size plate light housing.
LED Pimp...
13 Audi S4...
      05-23-2007, 10:11 PM   #2
Shinchan
LED Rules
Shinchan's Avatar
59
ITEMS AND TOOLS NEEDED:
2 LUXER 1 12 LED - can be purchase from Ebay.. the same guy who sales the Mtec stuff.
Drill Bit Grinder
Diagonal Plier
and electric drill
optional:
extra Plate light housing in case you are not comfortable modifying the original one.
LED Pimp...
13 Audi S4...
      05-23-2007, 10:20 PM   #3
Shinchan
LED Rules
Shinchan's Avatar
59
To remove the housing...
Insert flat screwdriver into the hole to the left of the plastic lens.....push to the right & pull the housing down.
Then just pull off the plugs.
this picture is taken from RikuE90 DIY instruction..... ignore the red and blue wire.
basically, the place that i circle in red need to be complete removed.
by using the diagonal plier carefully cut away as much as you can.
after you remove as much as you can, use the drill with grinder, carefully sand away any part of the plastic that still sticks out.
here is the finish product...
THE CRITICAL PART IS THAT YOU NEED TO TAKE TIME AND SAND AWAY ANY PLASTIC PART THAT STILL STICK OUT AFTER YOU CUT WITH PLIER.
THE LUXER 1 - 12 LED IS A PERFECT SIZE, NO EXTRA TO WIGGLE... IF YOU STILL HAVE EXTRA PLASTIC THAT STILL STICKS OUT THE LUXER 1 WILL NOT FIT IN PERFECTLY.
LED Pimp...
13 Audi S4...
      05-23-2007, 10:27 PM   #4
Shinchan
LED Rules
Shinchan's Avatar
59
take that LUXER 1 LED AND CAREFULLY INSERT IT INTO THE HOUSING.....
TAKE UR TIME.. IT WILL FIT... SLIDE LED INTO THE CUT PART OF THE HOUSING FIRST.. .. THERE IS A GOOD Chance you will need to move the part that i circle in red.. up a bit to slide the other end of the led into the housing..
LED Pimp...
13 Audi S4...
      05-23-2007, 10:28 PM   #5
Shinchan
LED Rules
Shinchan's Avatar
59
LED Pimp...
13 Audi S4...
      05-23-2007, 10:29 PM   #6
Shinchan
LED Rules
Shinchan's Avatar
59
see how nice they fit compare to the Luxer 1 - 6 LED.
LED Pimp...
13 Audi S4...
      05-23-2007, 10:42 PM   #7
sterns
sterns's Avatar
34
Drives: '20 SMB F83
2020 M4 F83  [0.00]
2016 F83 M4 Vert  [0.00]
Shinchan,
Nice DIY, thanks.
Does the kit include 2 sets, or do you order 2 ?
I tried the mtec guy "mtecpower" on eBay and he does not have any listed. I'll have to look elsewhere...
'20 M4 SMB Vert
      05-23-2007, 10:46 PM   #8
MWcoupe
24k GOLD
MWcoupe's Avatar
148
Drives: Mineral White M4
search www.bavauto.com . they have it 4sale
      05-23-2007, 11:57 PM   #9
Hunter399
Hunter399's Avatar
323
Drives: F90M5
So where can i buy these from?
      05-24-2007, 12:33 AM   #10
tissot
hmmmmmmmm
Hong Kong
17
Drives: F30 - 328i
2006 330i  [0.00]
2006 330i  [0.00]
2006 330i  [0.00]
Here
Thanks for the DIY Shinchan
      05-24-2007, 01:17 AM   #11
///sniper
///sniper's Avatar
No_Country
16
Drives: F30 [AW/Coral Red]
Have any shots further away?
      05-24-2007, 12:39 PM   #12
sterns
sterns's Avatar
34
Drives: '20 SMB F83
2020 M4 F83  [0.00]
I see they make an LED 24 product that comes with 2 LED 12 boards. Does anyone know if this is the same as 2 separate LED12's. I am wondering if it comes with twice the number of bulb sockets. Seems like the best kit for the license mod, and it is a lot cheaper than 2 LED12s.
Also, checked the bavauto LED12 pricing and it is a little cheaper than ebay. $18 vs. $20.
'20 M4 SMB Vert
      05-24-2007, 02:10 PM   #13
Shinchan
LED Rules
Shinchan's Avatar
59
i order another 2 sets OF 24 led from Bavauto.
For those of you who decide to order from BAVAUTO... that 24 LED is actually 2 12 LED board. and it comes with only 1 37mm festoon connector.. which means.. you are still out of luck on getting the plate light running....
plate light needs 2 37mm festoon.
if you guys can hold on.. for a day or 2... my order should arrive tomorrow. and I can also try those 12 led out in interior center console.. since.. it comes with various adapter.. including 168 base.... so that 1 12 led can use in plate.. and 1 can use in the center console...
so if you get 2 sets of 24 leds.. hopefully it works out for both 2 PLATE LIGHT AND 2 INTERIOR CENTER CONSOLE......
LED Pimp...
13 Audi S4...
      05-24-2007, 03:40 PM   #14
shragon
Moderator
shragon's Avatar
No_Country
497
Drives: BMW
nice!
might do this mod in the future.
      05-24-2007, 08:58 PM   #15
Shinchan
LED Rules
Shinchan's Avatar
59
can someone verify the plate light housing part number for E90 and E92?
LED Pimp...
13 Audi S4...
      05-24-2007, 10:25 PM   #16
ren
62
Drives: 2024 X7 M60i
Great DIY. I will definitely do this one.
Part numbers seem to be the same for both E90 and E92: 63267165646 The price is $7.37 on realoem.com and $5.52 on crownparts website.
      05-24-2007, 10:29 PM   #17
Hunter399
Hunter399's Avatar
323
Drives: F90M5
I just checked real oem
they are the same
      05-24-2007, 10:30 PM   #18
Hunter399
Hunter399's Avatar
323
Drives: F90M5
oops dident see you already posted
      05-25-2007, 07:54 AM   #19
Shinchan
LED Rules
Shinchan's Avatar
59
anyone has linky to crown parts website?
LED Pimp...
13 Audi S4...
      05-25-2007, 08:21 AM   #20
MWcoupe
24k GOLD
MWcoupe's Avatar
148
https://secure.webmakerx.net/Default....crownauto.com
      05-25-2007, 05:52 PM   #21
Shinchan
LED Rules
Shinchan's Avatar
59
alright, got good news and bad news..... for 24 LED from Bavauto...
24 LED is 2 X 12 LED panel. only 1 set of adapter for various socket.
Bad news...
the 2 X 12 Leds can only be daisy chain together... meaning one of the LED panel has a right socket connection the the adapter.. the second panel can only be relay to the first one....
Good news...
the 24 LED can be use in center console.. create a super bright 24 LED light.. that could blind ur eyes...
see this thread for picture..
http://www.e90post.com/forums/showth...60#post1006760
LED Pimp...
13 Audi S4...
      05-25-2007, 10:02 PM   #22
sterns
sterns's Avatar
34
Drives: '20 SMB F83
2020 M4 F83  [0.00]
Bavauto confirmed the LED's are Luxer1 and that LED24 has only one set of sockets, so 2 LED12's are needed for LP.
'20 M4 SMB Vert
