1M HPFP Different than 335i
01-03-2012, 08:00 PM | #1 |
91
Rep 444
I have heard a couple of rumors that the 1M hpfp is better than the current one in our 135/335 regardless if you have the original or most current one.
Can anyone confirm this?
2017 Mineral White M3
Mods to COME |
01-03-2012, 09:04 PM | #2 |
161
Rep 7,377
Yes it is better apparently, should flow more as well.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
01-03-2012, 09:44 PM | #4 |
161
Rep 7,377
yes , i think actually all new pumps have the same code as the 1M, check on realoem.com
01-03-2012, 10:09 PM | #5 |
90
Rep 632
Problem is, not all N54s are running the same HPFP without problems...
Same engine not even same pump lol |
01-03-2012, 11:42 PM | #6 |
40
Rep 462
The new pump I believe is called hpep or marketing purposes or high pressure exchange pump but it's the same crap and if you get your pump changed enough you will end up with this one the problem is that the hpfp is not the only issue in the fuel system but most other component benefit when it's replaced with a new one
Irub |
01-06-2012, 10:22 PM | #7 |
273
Rep 754
The newest n54 pump is from the 1m. The part number ends in 170. I had the 933 pump for 10k miles before the long cranks started. I was not throwing any codes, but the dealer changed the pump with the 1m part without question.
01-06-2012, 10:45 PM | #9 |
Custom Powder Coater
147
Rep 2,784
How long have then been using the 1M pump?
I went from having pump issues every 2 months to not having an issue the past 4-6 months
01-07-2012, 11:05 PM | #10 |
Big Boost Addict
52
Rep 689
Tags |
fuel, fuel pump, hpfp |
