TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Jb4 issue!
      01-02-2012, 05:04 PM   #1
HoustonRed
Drives: 2007 e90 335i
Jb4 issue!
Hi everyone,
I installed jb4 today morning, everything felt great until later when I went WOT on freeway, the engine started shivering, Ses lit up and it remained that way. I exited , thought It needs time to get used to and went on to delete codes and start driving again, softly.
I went wot again on a ramp, the same issue popped again. It shakes and throws Ses light when ever I go wot. All this in map 1.
So shifted to map 0 , all\'s fine.
Tried the map 1 again with same results at wot ( Ses and engine shake)
I checked the codes
29f3 and 29ce popped up!
Some one help me! Mine is still under CPO warranty.
      01-02-2012, 05:07 PM   #2
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
3441
Originally Posted by HoustonRed View Post
Hi everyone,
I checked the codes
How old are your spark plugs?
      01-02-2012, 05:09 PM   #3
HoustonRed
Actually I am not sure! Got it CPO last sept. I have not changed them since.
      01-02-2012, 05:10 PM   #4
HoustonRed
Sept 2010 I meant*
      01-02-2012, 05:12 PM   #5
3441
You have a few options to fix your problem.
First and foremost re upload your firmware.
Either swap your coilpack 2 to 3. See if problem goes away.
And OR/ get new sparkplugs. They should be changed ever 25K.
Your one code was something fuel related but its probably nothing. The other was misfire cylinder 2.
9/10 people on used vehicles need to replace sparkplugs before a tune. In fact it should be mandatory with the amount of threads and problems.
      01-02-2012, 05:18 PM   #6
HoustonRed
I do not have the USB cable with me to do anything about the firmware. But I can change my spark plugs and see how it goes!
