12-29-2011, 05:47 PM | #1 |
179
Rep 2,051
Which FMIC has the least pressure drop
I am new to the 1M and have been trying to do some HW on what mild upgrades to start with. One question i can't find data on is out of all the FMIC is which offers the least pressure drop?
I have tried searching so don't ask. Either I am searching something to direct or I need a more vague criteria. Based on what I have found the Helix one only drops .5 PSI? However on a poll of which FMIC people like it is the VK motorworks cause of the price? ETS has more streamlined ducting. If anyone has info or a link that would be great. |
12-30-2011, 12:16 AM | #3 | |
118
Rep 898
Drives: '69 GT3, GT4, 1M, 912
Generally more pressure drop = better cooling, but low pressure drop = low boost, fast spooling, etc. Looking at pressure drop only gives half the picture, unfortunately.
1M, GT4, 1969 Porsche 911 w/ 997 GT3 Cup Motor (435hp & 2,100 lbs)
12-30-2011, 10:21 AM | #4 | |
179
Rep 2,051
I guess which one offers the best of both worlds. Based on what I was reading and how I will drive he car, AMS or ETS looks like the best of both worlds. |
12-30-2011, 10:29 AM | #5 |
Rep 91
average pressure drop for intercoolers is ~2psi, however like in this diagram (quick drawing)
you will see that most of the air will go through the middle of the intercooler or where its the easiest path. this causes this section to heat up and not work as efficient. I would choose a FMIC with over engineered end tanks that prevent this from happening.
12-30-2011, 10:43 AM | #6 |
37
Rep 2,084
I remember a couple years ago the consensus was that Dinan/Spearco/Code3 had the least pressure drop. I don't know if that's still true since there are more intercoolers on the market now.
01-04-2012, 02:23 PM | #7 | |
179
Rep 2,051
Based on the image above of flow dynamics, wouldn't it be safe to say if you use a more streamlined in and exit air flow setup. Wouldn't that keep the same pressure? |
01-08-2012, 02:51 PM | #8 |
Supreme Allied Commander
3837
Rep 54,348
Drives: F80 M3
If anyone is interested in the old Spearco/Code3 FMIC, I am more than happy to post contact info to the manufacture for you to purchase one directly. We used to carry this FMIC until our contract with Code3 ran out, then Code3 went out of business and many other lower cost FMIC's came to the market.
01-24-2012, 09:45 AM | #9 |
208
Rep 1,161
There is not a linear relationship between pressure drop and cooling. An intercooler with poor laminar flow across the core will not necessarily have better cooling: there are other factors such as charge row count, fin design, and fin density, which have a bearing on the capacity of the intercooler to cool. Our tanks are CAD designed for optimal flow, and we have bull-nosed bars inside the tanks, so we can minimize pressure drop while getting the best data-logged efficiency that I have seen.
01-24-2012, 10:34 AM | #10 |
Resident Kerbalnaut
477
Rep 10,703
As others have said. Its a tough thing to figure out. Anyone whose taken a university Fluid Dynamics class can attest to it.
Pressure drop isnt the only variable, theres also, flow density, if the flow is laminar or turbulent, etc... |
01-24-2012, 10:56 AM | #11 |
3837
Rep 54,348
Drives: F80 M3
We have flow benched(Superflow bench) a bunch of FMIC's and found our custom made FMIC(internal fins for added cooling) we were running for Redline Time Attack was the most restrictive in terms of pressure drop even more so than the oem FMIC, but on the other hand it also provided the best cooling(more efficient) and made the most HP and TQ on the dyno. Lower pressure drop isn't always better.
