6MT transmission 2500 rpm delay~~~
12-16-2011, 03:40 AM | #1 |
57
Rep 639
Drives: E92 335i
i just noticed this problem in these 2 days
every time when i step on clutch around 2400-2500 rpm, the rpm won't drops rite away, it always stay at around 2500 rpm for like 1 or 2 seconds, then drops to idle rpm. if i make the rpm goes up to over 2500 rpm, step on clutch, it will drops rite away, but the rpm won't pass 2500 rpm that smooth, it will stop at 2500 rpm a little bit. if i step on the clutch lower than 2500 rpm (like 2200 rpm), the rpm drops like normal. i have no idea wut will cause this problem. maybe the muffler delete cause that problem??(just did a straight pipe exhaust recently) the mod on my car: N55 JB4 stage 2 Berk 4 inch catless downpipe muffler delete exhaust BMS CDV BMS Clutch stop do u guys know anything about this???? thanks
cheap fast cars arent reliable reliable cheap cars arent fast and fast reliable cars ARENT CHEAP Last edited by HACKULO; 12-16-2011 at 04:00 AM.. |
12-16-2011, 04:15 AM | #2 |
161
Rep 7,377
quite strange
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
12-16-2011, 08:33 AM | #4 |
91
Rep 1,324
Drives: 335i Coupe, 6 Speed
Your also in the n54 section. I've never had this problem and I'm on n55
12-16-2011, 09:52 AM | #8 |
161
Rep 7,377
12-16-2011, 10:17 AM | #10 | |
56
Rep 1,311
12-16-2011, 11:27 AM | #12 |
422
Rep 8,003
Drives: '08 E90 335i, '99 E36 M3
12-17-2011, 06:11 AM | #14 |
57
Rep 639
Drives: E92 335i
thanks guys
cheap fast cars arent reliable reliable cheap cars arent fast and fast reliable cars ARENT CHEAP |
