      12-13-2011, 02:13 PM   #1
fmagz91
Drives: 2010 135i, 2005 325ci
Cat delete power loss??
A month ago i installed ar catless dps which was a pain in the ass.. but worth the power gains.. yesterday i got bored and went to my local welder and took the 2 remaining cats out assuming better flow=more power.. i still got the stock muffler and resi... So bottom line i almost feel like i lost power by deleting the last 2 cats. is this possible or am i just crazy?
      12-13-2011, 02:20 PM   #2
MDORPHN
291
Drives: AW 1M
You're crazy. You do not lose power from reducing backpressure in a turbocharged system.
Neil
      12-13-2011, 02:48 PM   #3
Dackelone
European Editor
Dackelone's Avatar
Germany
10528
Drives: N54 e82
Did the muffler shop use the same OE size dia pipes? Or maybe smaler ones? It might be better to just get a N55 mid pipe. ?
      12-13-2011, 02:55 PM   #4
ESC OFF
ESC OFF's Avatar
40
Drives: 1M, CaymanS, 914, 500 Abarth
Neil is correct ^^^ I was wondering the same until I did some research, Downstream of the turbine you want the least backpressure possible. The general rule of larger is better of turboback exhausts is true. If you minimize the pressure downstream of the turbine you will make the most effective use of the pressure that is being generated upstream of the turbine.
The faster you go, the better it feels
      12-13-2011, 03:55 PM   #5
1SerieStud
1SerieStud's Avatar
183
Drives: '11 VO 1M (498 of 740)
Neil
+1
      12-13-2011, 04:10 PM   #6
fmagz91
guys, im not soo much of a noob, know how it works which is why i mentioned "assumed" in the post.. if i could run open dps i would! but i was asking this for people who know more than me about the n54 exhaust sys.. they are the same size pipes i was watching him weld.. my theory was that since theres so much flow the stock muffler cant handle it on a high map and it backs it up resulting in a power loss.. i noticed good gains on the stock map vs with the cats on the stock map but when i switched it up to high boost i was almost dissapointed.. im going to do some more runs soon and doube check.. my car likes to choose the days she wants to perform so.. and using the n55 dp would be interesting, id like to look into the sizes and such.. but thanks for the feedback guys
      12-13-2011, 04:11 PM   #7
fmagz91
midpipe**
      12-14-2011, 02:46 AM   #8
NihonX
63
Drives: 2011 VO 1M
You might 'feel' a loss of low-end torque, but the high-end horsepower will sure be there.
2011 VO 1M
      12-14-2011, 07:27 AM   #9
Dackelone
European Editor
Dackelone's Avatar
Germany
10528
Drives: N54 e82
... my car likes to choose the days she wants to perform so.. and using the n55 dp would be interesting, id like to look into the sizes and such.. but thanks for the feedback guys
I just measured my N55 mid pipes. The O.D. is 58mm to 60mm depending on where you measure. Maybe you can measure your custom mids.
      12-15-2011, 01:53 AM   #10
fmagz91
ahh, i did some more runs today.. its just not the same.. its deff slower on higher boost levels. i'm just gunna get rid of that muffler
      12-15-2011, 12:57 PM   #11
Papethova
224
Drives: '08 135/ '11 1M
I definitely gained power by deleting the 2ary cats and the resonator from the mid pipe. Disclaimer... it was on the 135, the M mods are still pending
      12-19-2011, 08:52 PM   #12
fmagz91
yea, you might have gained some power but i did it the wrong way.. wen i first did the dps with cat deletes and the rest stock it was perfect.. i got bored and took the mid pipe cats out and it was too much flow for the stock muffler which robbed me of power on higher boost levels.. now i fixed the solution= straight pipes with a resi.. sounds ridiculously loud when cold but its not so bad once its warm.. and the gains are crazy..
      12-19-2011, 09:07 PM   #13
RaihaX
RaihaX's Avatar
Australia
156
Drives: 08' 135i
i swap my midpipes with resonated midpipes and my butt dyno says it has gain power.
      12-24-2011, 06:42 PM   #14
fmagz91
nice car btw, and your stock mids, were they catted and resonated to begin with?
      12-24-2011, 10:04 PM   #15
RaihaX
RaihaX's Avatar
Australia
156
Drives: 08' 135i
Yeah they are, n54 midpipes have cats and resonator.
1addicts
