Is this a sign of oil filter housing leak?
12-12-2011, 05:23 PM | #1 |
93
Rep 1,794
**UPDATE**
To all those that PM'd me, this turned out to be the thermostat housing gasket. I replaced both the oil filter housing and thermostat housing gaskets this past weekend. The oil filter housing gasket looked fine while the thermostat gasket looked a little melted in spots. Hopefully this helps someone considering all of the DIYs do not even mention replacing the thermostat housing gasket. I had to disconnect the oil cooler lines in order to get to the bottom bolt on the thermostat housing. Remember to replace the o-rings on these lines if you do the same. Be prepared because this is a very messy job. There's no real clean way of doing this. Just have a bunch of towels on hand and line the floor underneath the engine with a lot of newspaper. There is also no way to remove the oil filter housing without pulling the intake manifold out a little. I did not have to remove the throttle body, charge pipe, or the electrical box on the bottom. I just removed the 6 nuts and 1 bolt and pulled the manifold out slightly. This gave me enough room to stick in a socket (w/ extension) and loosen the bolt. ------------------------------------------------------- Just trying to see if anyone can quickly identify what is going on here. It looks like oil is pooling in this crevice and then is leaking over down into the engine. Is this the oil filter housing leak or is my filter not on tight enough? It is turned a little past the green marker. Or could the O ring have torn? Last edited by bimmertt; 04-23-2012 at 06:25 PM.. |
12-12-2011, 05:42 PM | #2 |
24
Rep 1,244
Did you change the oil yourself? If so (even if not), the O-ring that sits on the cap looks like it may have been improperly seated. If it isn't in the correct groove, it can leak.
12-12-2011, 06:31 PM | #4 |
86
Rep 1,262
Is there oil on the front turbo inlet pipe? (the rectangular plastic pipe)
If it's just by the filter cap, I'd say check your filter O-rings (don't forget the little green one!)
Josh-
12-12-2011, 06:52 PM | #6 |
Rep 110
I had the oil filter housing leak. It doesn't look like it. As others said checked the cap o-ring.
/ Was mich nicht umbringt, macht mich starker /
12-12-2011, 08:47 PM | #8 |
93
Rep 1,794
I changed the oil myself about 3k miles ago. The leak is pretty much confined to the area in the picture. I checked the front turbo inlet pipe and it was clean. The o-ring also looks fine...is this the correct location?
12-13-2011, 12:46 AM | #10 |
3441
Rep 79,211
12-17-2011, 04:51 PM | #11 |
93
Rep 1,794
So I cleaned up the oil that night and re-tightened the oil filter cap. I checked today and there is already a pool of oil in that same spot. I checked the filter O ring and it appears to be in the same spot as the pic above. This is kind of a strange area for the oil to pool if it is the housing gasket, but I can't think of anything else that would cause this. Any other ideas?
12-17-2011, 06:25 PM | #12 |
866
Rep 5,450
Take the o-ring off and check it for nicks or rough spots. Also check the cap for cracks, they have been known to crack in the past, otherwise clean everything good and replace the o-ring.
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
12-18-2011, 08:51 AM | #13 | |
12
Rep 656
12-18-2011, 09:30 AM | #15 |
56
Rep 1,311
The O-ring will seal when the cap contacts the housing even if the torque is minimal. There is no need for a torque wrench for this except for avoiding over-torque by people using too much force. Just tight it until it bottoms with light wrist-power and do not use excessive force.
12-20-2011, 07:59 AM | #20 | |
12
Rep 656
12-20-2011, 09:04 AM | #21 |
2 car lengths ahead on the left
Rep 176
Had the same thing.
Had the same issue. Oil filter housing gasket was the source. I noticed it leaking when I started the engine cold w/ the hood up. Didn't leak when it was warm. Dealer replaced it as well as a couple other parts that are required by BMW for this repair under warranty.
The R
12-20-2011, 11:22 AM | #22 |
24
Rep 1,244
As was mentioned earlier, if it isn't the O-ring then the cap could have a crack in it. As for torque settings, you can also line up the green dots which assures you don't over tighten the cap (and thereby cracking it).
