pbx worth it?
12-11-2011, 10:44 PM | #1 | |
Team iTouge
121
Rep 2,101
pbx worth it?
Hey I was wondering if a pbx would be worth it even if I have a mtech package with the mtech ecu? Would it be able to add a bouncing 2 step or launch control?
12-11-2011, 10:50 PM | #2 |
92
Rep 1,456
12-11-2011, 11:36 PM | #3 | |
Team iTouge
121
Rep 2,101
It adds taller gears removes the speed limiter and it extends it to 160 or so. I believe also adds accel speed
12-12-2011, 12:36 AM | #4 |
91
Rep 611
I think factory Sport or M-Tech pkg ecu only has a 155mph top speed limiter, rest should be the same as regular 328i... also same final drive.
N51- PI - PE - ESS Tuned - SSK - CDV Delete - AFE Header - B12 - Mfactory LSD
12-12-2011, 12:42 AM | #5 |
Where'd my VTEC go?
481
Rep 6,067
there are absolutely no drivetrain differences between sport/mtech and regular. just the increased speed limiter.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
12-12-2011, 01:31 AM | #6 | |
Team iTouge
121
Rep 2,101
I see other vids of 328s on youtube and it shows them shifting redline at 35, mine stops at 40 and second goes to 70 and 3rd goes to 110 I believe, what would I have to get done for a 2 step/launch control?
12-12-2011, 01:46 AM | #7 |
91
Rep 611
thats weird... taller gear usually means slower acceleration... e46 330i w shorter performance differential shaved 0.5 second on 0-60. u the first owner of the car? maybe someone swap the differential or bigger tire.
12-12-2011, 06:08 AM | #8 |
255
Rep 2,547
No idea what a bouncing 2 step is or why one would want one with a street car especuially a 328, but he PBX is absolutely worth it. I would say it is very cheap upgrade for the improved throttle response that it provides.
12-12-2011, 09:24 AM | #10 |
101
Rep 1,727
Not familiar with the mtech ecu but you can't go wrong with the PBX. Just installed mines the other day and there's no regrets whatsoever.
Hiatus |
12-12-2011, 09:35 AM | #11 |
Nate Dogg
Rep 437
From what I have read and everyone that I have spoken with it appears to just be throttle remapping. I would pass and opt for a tune that can offer more then just throttle remapping.
Search this forum and Google for more information including dyno charts, I would not rely on the "butt dyno" as it tends to be skewed. Most people aren't going to drop a few hundred dollars and report back that they do not feel a change. -Nate
2011 BMW 328i by weekend, various airplanes by week.
12-12-2011, 10:35 AM | #12 | |
50
Rep 753
12-12-2011, 11:10 AM | #13 |
205
Rep 2,770
Drives: E92 328i, E92 M3
Pretty sure OP is trolling, but I have a PBX for sale. Hit me up.
12-12-2011, 11:23 AM | #14 |
just another bmw douche bag
195
Rep 3,640
it's also been dyno'd (by me) and I've posted the dyno chart at least 4 different times. there are gains, mostly in the midrange, but don't expect big numbers. The real difference comes from the throttle mapping, which makes the car drive much better.
And just fyi, it's physically impossible for an ecu to change the gearing. It can raise shift points though. And there are gearing differences between the 6MT and the steptronic transmissions, so you may have seen another car with a different transmission. If you want a 2 step, you'll need some sort of electronic add-on. MSD makes them for mustangs and camaros, but not for BMW. I believe you would need an AEM EMS system that could be programmed by evosport to work with your BMW. http://www.evosport.com/product/aem/ |
12-12-2011, 03:01 PM | #15 | |
Team iTouge
121
Rep 2,101
yes i'm the first own but i do have bigger tires and rims, but not too much from stock. i only have 18x8.5 fronts and 18x9.5 in the rear. the stock were 17x8 front and 17x8.5 rears. but the tires are much wider than stock though 265 r 245 f could that be it?
12-12-2011, 03:03 PM | #16 | |
Team iTouge
121
Rep 2,101
to think about it, maybe you're right about the 2 step launch control on a NA stock motor. 2 step is to build up turbo boost right before you take off. but thank you, i will keep it in mind.
12-12-2011, 03:03 PM | #17 | |
Team iTouge
121
Rep 2,101
does it make a night and day difference like a JB system would?
12-12-2011, 03:05 PM | #18 | ||
Team iTouge
121
Rep 2,101
12-12-2011, 03:06 PM | #19 | |
Team iTouge
121
Rep 2,101
TROLLING? how is this trolling if i'm asking an honest question? and i'm not sure about which tuning i want yet thus is the reason i posted this topic. Thanks but i'll keep you in mind if i decide to get a pbx
12-12-2011, 03:08 PM | #20 | |
Team iTouge
121
Rep 2,101
from what i've noticed, a 6mt is worth it from the start as far as racing goes. But i got a 6mt so i'd have at least an edge in taking off if from a roll or dig. 6mt makes a huge difference from what i've witnessed. it can mean the difference on getting someone by 2 ft. or loosing by 2 ft. tuned or not, 6mt is the best IMO
12-12-2011, 03:13 PM | #21 | ||
Team iTouge
121
Rep 2,101
12-12-2011, 04:13 PM | #22 |
92
Rep 1,456
Personally about to get the AA tune. Have never tried the PBX but for me a reflash seems way better. I don't like the idea of a piggy back system. personal preference.
