Procede Racegas logs, 10psi with Timing Drops
12-11-2011, 12:23 PM | #1 |
424
Rep 1,325
As suggested from forum members, I filled up with 100 sunco unleaded race gas mixed with my 91 octane. Octane approximately 94-95 octane.
Nearly FBO, except 2nd cats. 6mt Procede rev 2a. Ambient 58F outside. Tried both procede 7-11 and 7-29 maps. 10psi autotune off for both and 100% ign correction. Still seeing timing drops. Can we rule out the fuel now? Map 7-11 log Map 7-29 log
12-11-2011, 01:39 PM | #2 |
23
Rep 1,142
Did you reset All the adaptations before running the race gas. Go reset them and log again. If you didn't, Do you at least do a couple do WOTs to allow the ecu to adapt to race gas?
12-11-2011, 01:42 PM | #3 |
424
Rep 1,325
Yes all adaptations were reset ad a couple wot were done before logs taken.
12-11-2011, 01:45 PM | #4 |
23
Rep 1,142
I think you need to speak to shiv about this. 11 psi and your showing timing drops with race gas. Something is up. I have no idea what to even tell you and he would be the one to give you answers. I see people run 14-15 with perfect timing logs
12-11-2011, 02:05 PM | #5 |
161
Rep 7,377
you should add always CAN DBW throttle and IAT. also graph afr 1 and 2 on top of each other. Same with fuel trims.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
12-11-2011, 02:20 PM | #9 |
424
Rep 1,325
I will re-work the graphs and re-upload. Thanks for your input!
12-11-2011, 02:28 PM | #10 |
424
Rep 1,325
I will do that. It seems harder to get a hold of him. Perhaps hes traveling.
12-11-2011, 03:00 PM | #13 |
424
Rep 1,325
Re-Uploaded with CAN DBW Throttle and AFR, Fuel Trims for bank 1 and 2.
7-11 Map: 7-29 Map: Also I did a couple runs with autotune ON, 7-29 maps. 10psi & 100% ign corr start. max 12 or 13psi (I forgot)
12-11-2011, 03:19 PM | #15 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
They probably aren't. It looks like they are scaled differently in the datalog. You can confirm this is by looking at the actual value on the bottom left hand screen. To manually scale, just click on the channel and press the letter "P". Turn off autoscaling and set your desired min/mix values.
12-11-2011, 03:22 PM | #16 | |
1737
Rep 17,960
Drives: A Lot
12-11-2011, 03:28 PM | #18 |
1737
Rep 17,960
Drives: A Lot
12-11-2011, 03:39 PM | #20 |
1737
Rep 17,960
Drives: A Lot
12-11-2011, 04:36 PM | #21 |
112
Rep 4,771
There's no way you should have timing drops running a grandma configuration of the Procede lol. No one else seems to have issues.
So I'd say that you might be at the point where you aren't misfiring yet, but it might come soon. When did you last change plugs? |
12-11-2011, 06:11 PM | #22 |
424
Rep 1,325
Plugs were changed 1000 miles ago at the dealer. I've never had any misfires, prior and after new plugs.
