AR downpipes, pronounced whistling / hissing noise accelerating at 75+mph?
12-10-2011, 03:39 PM | #1 |
14
Rep 222
Wassup,
I just had my AR downpipes installed which goes down to stock exhausts. Now, i understand that there should be a noticeable turbo spooling (whooshing) sound which can be heard in normal traffic while the windows are down. My issue is that i hear a slighly higher pitched, whistling / hissing sound when im giving my car gas going 75+ mph, even when my windows are all rolled up. For all you veteran AR downpipes guys, is this considered normal? Do you guys hear the same whistling / hissing sound in the cabin while gassing it to 75+ mph on the highway with all the windows closed? or do i have a possible problem in my hands and need to take it back in to be readjusted? Updated with sound clip: Excuse the shakiness, and horrible sound quality. The windows are infact CLOSED, i know it may sound that they are open. At 00:22 - 00:25 you can hear a hissing sound when accelerating from 55-65mph the other times were just too noisy to pinpoint. Usually its more distinctive accelerating at 75+ mph. i just wanted to know if this was "normal". UPDATE 2/2/2012 Some recent recordings i did that should clear things up. Same hissing sound persists, would appreciate more feedback and what you guys think now. Sorry in advance for watching them upside down. Video 1 Video 2 Clearer sound in the first 18 seconds Video 3 This clip was taken next to a road barrier on purpose so i could amplify the sound, it was hard to capture it with my phone video recorder in the first and second video so this should clear things up. This is exactly how i hear it on the road without a barrier next to me. Thanks Update: 3/25/2012 The culprit were the V-Clamps: had them re-adjusted and seems to be the same as the sounds above but slightly lower. Update: 10/31/2012, Happy Halloween Sound is now worse again, possible V-Clamps loosened up, might need to purchase a new set, will have to ask the shop to evaluate everything. Last edited by cable96; 10-31-2012 at 10:04 AM.. |
12-10-2011, 03:42 PM | #4 |
422
Rep 8,003
Drives: '08 E90 335i, '99 E36 M3
Have you heard another car with AR downpipes to compare with?
12-10-2011, 03:43 PM | #5 |
866
Rep 5,450
I have AR Catted pipes, a little bit more turbo noise, but you have to listen to it, nothing like you are describing, the cat's proabably help a bit, but your description sounds like there could be a leak.
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
12-10-2011, 03:45 PM | #6 |
14
Rep 222
12-10-2011, 03:56 PM | #7 |
Take Off*
Rep 47
my turbo spool got alotttt louder once i installed my ar catless dps.. when lightly accelerating and then letting the throttle go you can clearly hear the turbos spool down (espiecally with windows down)..i honestly like the sound tho..lol
JB4 G5 ISO, AR DP's, ER CP, Synapse BOV, AlpineMSS HID, BMS Oil Catch Can, BMS CDV... WISHLIST--> LSD
12-10-2011, 04:13 PM | #9 |
441
Rep 18,331
If the car sounds like a helicopter then you have a exhaust leak, other than that you should definitely hear the turbos spool and nothing else...You probably will hear more rasp too for sure since your getting rid of one of the cats.
12-10-2011, 06:58 PM | #12 |
70
Rep 2,197
i heard the same noise you were describing when i was running AA catless with cobb stage 2, i switched back to stage 1 V301 and it sounded A LOT better. i know exactly what sound you're describing and it sounds like SHIT, it sounds like a huge rush of air(NOT an exhaust leak) i think it has to do with the wastegate, but idk. im hoping stage 2+ doesnt sound like that
12-11-2011, 04:07 PM | #16 |
23
Rep 647
doesn't sound normal to me...I had my ar dp's and fmic installed at the same time. But I can only hear the turbos hissing with the windows down at slow speeds. Hope you get it fixed
12-11-2011, 04:22 PM | #17 |
70
Rep 2,197
I've experimented around today and i've come to this conclusion: i think its all about wastegate stiffness/wear/software. The stage 2(linear by default right now) and stage 1 linear sounds the same(loud hiss at partial throttle/until boost comes on). Stage 1 v301 sounds awesome(no hiss) and i think its because of the wategates operation due to tune/bmw software/slop. Thats why it's normal for some and not others.
But, thats just a guess of mine. To be clear, I'm sure as shit no expert. |
12-13-2011, 11:35 AM | #18 |
14
Rep 222
Quick update, codes i see are 2x H2AD0, thats it. From what i gathered, they arent related to boost leaks or o2 sensor codes. Still working to get a cruising video, my epic 4g's video is nice but sound is bad.
12-13-2011, 05:07 PM | #22 |
Take Off*
Rep 47
normal. have the exact same sound.. its loudest in 1st gear
