Procede v5 11-25 maps
12-08-2011, 10:07 PM | #1 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
11-25 v5 Aggressive (USER TUNING) BETA maps with 110 Firmware Hi guys, due to the success of the 11-01 Aggressive maps, we have officially made them non-beta. And now we have some new 11-25 Beta maps available. Very minor mapping changes. More useful is a special version of the firmware which enables the dedicated PWM Meth I/O channels so that Rev3 users no longer have to give up their speed delimiter feature. Details on the new 11-25 Beta maps below: Mapping/Firmware changes: Added 11-25: 1) A Stage 0 map has been included. This is a more conservative version of the Stage 1 map. It has lower boost targets and more top end boost taper. It is intended for those who live in extremely harsh conditions (high altitude & poor fuel quality & high temp) and find the Stage 1 map to still be too aggressive. 2) Enabled Hard Rev Limit feature (Digital Outputs -> Hard Rev Limit). For use in 6MT applications. 3) Revised ignition advance mapping for Stg1 maps. Slightly more conservative ignition advance targets above 6000rpm. 4) Revised fuel mapping for Stg3 maps. Higher Open Loop fuel values at high engine load above 5000rpm. 5) The option for Rev3 users to use the "Dedicated PWM I/0" firmware version which enables the dedicated PWM input/output channels on the Rev3 circuit board. This allows the Procede to support PWM meth AND the speed delimiter feature. Both of which are mutually exclusive on Rev2/Rev2.5 platforms. Rev3 users who are currently running PWM meth will have to revise the wiring on their harness if they want to take advantage of this special firmware version. If they do not wish to do so (and don't want to re-enable the speed delimiter feature) they can simply run the standard version of the firmware not not make any wiring changes. But for those who want to make this change and restore their speed delimiter feature, please read the "How To Enable the Rev3's Dedicated PWM I/0" guide also included in the map folder. To download the new 11-25 maps/firmware, click HERE As always, please carefully read the Read Me First file before updating to the new maps/firmware. There is new information there that will likely answer whatever question you have Cheers. shiv |
12-08-2011, 10:13 PM | #3 | |
38
Rep 1,079
"There is absolutely not reason to EVER run MAP 2 as it does not have an active methanol failsafe." |
12-09-2011, 12:42 AM | #5 |
161
Rep 7,377
because you run map 4 instead which has the failsafe and transition from map 1 to map 2.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
12-09-2011, 12:44 AM | #6 |
38
Rep 1,079
12-09-2011, 12:54 AM | #7 |
254
Rep 8,338
can't wait for my meth kit
12-09-2011, 12:54 AM | #8 |
3441
Rep 79,211
12-09-2011, 12:57 AM | #9 |
38
Rep 1,079
12-09-2011, 02:17 AM | #10 |
142
Rep 931
Good!
autotuning still off ? Map1 and map2 are the same ? tnx
BMW F82 M4 Black MHD CS Map - GTS DKG - Navi -Performance Brake RSL1 Pads - USB - DivX-DVD - Bluetooth - VoiceControl - Connect - Apps - Online - H&K - TrafficInfo - SpLimInfo - WhiteMerino- PDC - Cam - Adaptive Led - Antitheft - CP Steering- Performance ST - Adaptive CP Setup - GarageDoorOpen - Pipercross - Stock Exhaust - Mdrivers Pack - 437M Wheels
12-09-2011, 02:28 AM | #11 |
161
Rep 7,377
Autotuning is OFF , map 1 and 2 are not the same. map 2 is way more aggressive and for meth/race gas use only. Its all in the read me file.
12-09-2011, 03:46 AM | #12 |
Rep 89
Shiv,
I have pwm meth kit and rev3. But previously i have rev2 and I updated it to rev3 (just unit only). It's using rev2's harness. Do I have to change something on its harness for dedicated PWM Meth I/O channels / speed demiliter feature ? Edit: Yes, I have to (for speed delimiter). So in the future updates, everytime, there will be 2 firmwares, right ? one for standard, other for who did dedicated pwm channel update ? Last edited by garfi; 12-09-2011 at 04:17 AM.. |
12-09-2011, 05:44 AM | #13 | |
142
Rep 931
Position2 is for Meth user ? my idea is to change position1 in order to lowering the max boost from 18 to 13 (a middle ground between valet and map2)
12-09-2011, 06:58 AM | #14 |
You run 11's in a what?
Rep 45
Is this only for rev 2.5/3?
e92 335i 6MT, PROcede, DCI, AR C-less DP, Stock Exhaust 2nd Cat delete, ER FMIC, STETT CP, Tial BOV, Labonte Meth M7, CM FX400 6Puck Unsprung, 275/45/17 MT DR on 17x8.5 Kosei K1
Best 1/4 mile: |
12-09-2011, 07:50 AM | #15 | |
PSI
15
Rep 349
Does this hard rev limit feature NOT apply to us 6AT guys now? I was really looking forward to not hitting the throttle closure on the 1-2 shift and sometimes the 2-3 --- it seems to happen when running meth, being that the transmission doesn't shift as fast as it needs to.
2011 335d, M-sport, Alpine White, Nav
12-09-2011, 07:54 AM | #16 |
11
Rep 677
Does this mean, if I have no PWM, but want the Speed delimiter I don't need to do anything?
59 Corvette, 72 240Z, 73 Espada, ZXR
12-09-2011, 07:55 AM | #17 |
247
Rep 2,567
^^^ Yes, according to the readme file. If used on a REV 2, you'll get various codes thrown.
07 e92 335i - Retired
18 F80 M3CS - Retired 21 G20 330i M-Sport - Current |
12-09-2011, 08:02 AM | #18 |
11
Rep 677
I do have a rev 3 but still not installed, because I didn't do the RevII v4 harnes update. (used still version 3.2)
12-09-2011, 10:17 AM | #19 | ||
Boooooost!
Rep 73
Shiv I remember in that teaser post you had you said that new the rev limiter was going to be for MT and AT cars and that it would help the AT cars... Quote:
09 135i, A6, Monaco/Coral Red, M-Sport pkg, Premium pkg, Hi-Fi sound,
12-09-2011, 11:41 AM | #20 |
142
Rep 931
Updated my rev3 with FW110 and map 11-25
Very impressive !!! The car is fast in every gear like 11-1 but the power still high in all range of revs Very Good
12-09-2011, 02:17 PM | #21 |
Vishnu Powered
68
Rep 2,205
I'm guessing the 11/1 and these new 11/25 maps are still ONLY for rev 2.5/3 procedes?
So us rev 2 owners are stuck with the 7/... maps?
2008 335xi Sedan | Titanium Silver | Black Dakota
PROcede v5 | Vishnu Exhaust | BMS DCI | AR Catless DPs | Helix FMIC | Stett Charge w/ Tial BOV | MORR VS8s | KWv3 |
12-09-2011, 03:46 PM | #22 |
Rep 375
