Oil Level senor
12-08-2011, 08:50 PM | #1 |
Rep 169
Oil Level senor
Has anyone had a oil level sensor failure?
Here is the situation My oil level has been consistent at full since the last oil change approx 4000km until about 2 weeks ago when I installed downpipes and and a meth kit. After the dp and meth install I have been driving the car a bit harder to ensure everything is functioning correctly about 10 to 15 WOT runs. I was surprised to see that my oil level has down to 3/4 from full in the last two weeks about 800km and just yesterday to 1/2. No oil smoke, smell or visible leaks under the hood in the common areas near the oil filter housing. I go to check the oil level today and I'm back to full with out adding a drop of oil to the car. Has anyone experienced this? I don't trust this sensor anymore.
|Cobb AP / JB4 | DCI | BMS WW Meth Kit | AMS FMIC | Macht Schnell 3" DP |
12-08-2011, 08:58 PM | #2 |
74
Rep 1,543
It's most likely failed, since mine did the same. I replaced it a while back, but just like the brake sensors, you can't just replace it. The condition based system of your vehicle has to be reprogrammed for it to work, so it's not a plug and play thing. Mine is waiting till next year, when I will replace my brakes, so I can get both things reprogrammed in.
12-08-2011, 09:10 PM | #3 |
Rep 169
It's good to hear that it's likely just the sensor especially with all the discussion about oil consumption these days.
12-08-2011, 09:23 PM | #4 |
1086
Rep 1,912
The sensor is bullshit, it doesn't work. It NEVER works. It will tell you whatever it wants to.
It won't be accurate without taking the average level of three drives. If you park on an incline it will tell you that you are off by as much as a quart and stay that way until three drives later. It wont give you an accurate reading unless the car is warmed up to temp, on a level surface, not moving for a while, running, at least three consecutive times. Don't pay attention to it unless the low oil warning light comes on. You installed DPs... car was on an incline for a bit if you did it on ramps, hence the low indicated level. We need a dipstick. |
12-09-2011, 12:11 PM | #5 |
294
Rep 922
I have to somewhat agree with you. I had low oil light, put in ONE quart, warmed up the car, checked the oil level, and it showed as 3/4 full for the next 4 months. Logically, that's not accurate, but could be true. Who knows.
12-09-2011, 12:26 PM | #7 |
FREE DREAMK
162
Rep 9,321
Drives: the shiiit!
I hate it,
12-09-2011, 02:04 PM | #8 |
Rep 169
Full last night back to 3/4 today
Both measurements on level ground.
12-09-2011, 02:57 PM | #9 |
97
Rep 2,002
Maybe its barely at the point where it indicates full or 3/4? Therefor it goes either or depending on incline and how hot/cold the car is? If you have the BT tool, you should be able to reprogram it. IT worked for me with my brakes....
ESS 650 ACM-R Upgrades |
12-09-2011, 03:03 PM | #10 | |
1086
Rep 1,912
Unfortunately without a dipstick there's no way to know exactly how much is in there short of a drain-n-measure. I hate that fucking sensor. |
12-09-2011, 05:27 PM | #11 |
Some dude
92
Rep 1,780
Wow. Lots of vitriol over the loss of a dipstick. Oh the times, they are a changin'. Imagine 30 years ago how many people spewed venom when electronic controlled fuel injection was becoming increasingly popular. Reminds me of all those Roundel letters to the editor whining about every new electrical gadget and improvement from people who think the last great car BMW ever made was the 2002. Get with the times, people! Sure, a dipstick is necessary for road racing where you need to ensure you have the exact amount of oil in the crankcase to prevent starvation. But for nearly all other cars/drivers, a simple "low oil" warning from an electronic oil level sensor is all you need. You can be 2-3 quarts low on a daily drive and never starve out of oil, so 1 qt low is a perfect warning. Your engine shouldn't leak or consume excessive amounts of oil anyway.
And besides, high end racecars use electronic oil level sensors to monitor oil consumption in endurance racing. Soon, our sensors will have the same resolution and speed as those. Until then, if you're really concerned, just check your oil level via the i-Drive/BC stalk when you get gas. Engine warmed up, parked on a level surface, at idle. Simple, no oily towels thrown in the trash, no dirty hands.
RRT
E92 335i/6MT with stuff and things |
12-09-2011, 05:38 PM | #12 | |
Rep 169
I think the level sensor may only returns discreet values i.e. 1/4,1/2,3/4,etc and the true measurement is on the cusp an it's wavering back and forth.
I'll wait for an oil change and measure it out for curiosity sake. Yeah, no leaks at all everything looks good. I was just a little nervous due to the fact that I've recently increased boost levels and was a bit worried how the turbos are spooling now and any negative impacts on seals etc. but i think it was a false alarm. 1/4 to 1/2 qt in 4000 km's is ok to me. The sensor is expensive to replace.... I'd rather have a $5 dipstick. Quote:
12-09-2011, 05:49 PM | #13 |
1086
Rep 1,912
12-09-2011, 05:52 PM | #14 |
216
Rep 1,793
Drives: 06' E90 330, 20' F97 X3m
My sensor took a shit on me about a month or two ago. Naturally i just changed my oil a week before the sensor crapped out on me. So Im gonna wait til the next oil change to swap it out.
LIVE FAST..DRIVE FASTER!! |
