bov vs dv comparative
12-08-2011, 07:13 PM | #1 |
41
Rep 307
what is the difference between blow off valve and diverter valves ??
the only thing i know that is the diverter valve is deiverting the air back into the air intake and i know that in general the car comes rich when the bov start it works to take out the air and whats better for the 335i ?? i made a search in the forum and i didn't find what i need |
12-08-2011, 07:26 PM | #2 |
68
Rep 1,943
Is all the same, just a matter of preference. U want a BOV sound disconnect the front Dv from the IC piping going into the charge pipe and there u go.
PROCEDE, PWM Vishnu Kit, AR catless DP, BMS DCI, Helix IC, P3 gauge, 25% window tint, mattblack window trim, mattblack roof wrapped. Vorstainer CSL trunk, CF wrapped interior, 18'' Forgestar F14 Matt black, quaife LSD, M3 suspension bits, Mtech front bumper). http://www.youtube.com/watch?v=b8JIB8C8HDA
12-08-2011, 07:32 PM | #4 |
3441
Rep 79,211
No difference in performance or tuning. The stock DV tend to leak which is why people upgrade. Other people upgrade to BOV simply for the sound, however, the purpose is to relieve and hold pressure better then stock DV can.
12-08-2011, 07:41 PM | #5 |
41
Rep 307
i upgraded mine to he turbo smart diverters not the dual port
but the sound is not loud enough for me if i disconnected the pipes will it be louder ?? and there is no effects if i disconnected them ? |
12-08-2011, 07:44 PM | #6 | |
68
Rep 1,943
How to test is DVs at leaking
12-08-2011, 09:06 PM | #7 |
74
Rep 1,309
12-08-2011, 09:14 PM | #8 | |
102
Rep 1,903
Drives: e92 335i 6MT
http://www.n54tech.com/forums/showthread.php?t=109 |
12-08-2011, 09:16 PM | #9 |
1086
Rep 1,912
BOV: Vents to atmosphere, makes a cool whoosh sound that some like and some hate.
DVs: Recirculate air into charge pipe instead of venting it. |
12-08-2011, 10:34 PM | #10 | |
30
Rep 238
The reason you have a diverter valve in the first place is to keep the pressure between shifts. If you "blow it off" the turbos take longer to spool up and create more pressure. If you want to test this, install a boost gauge. The boost gauge will also show you if your diverters a leaking. The BOV, however, sounds wicked cool! OP if you are one that likes bleeding edge performance, keep your diverter valves and spend your money on a boost gauge. If you like the cool sound and flashy look get a nicely built BOV. |
12-08-2011, 11:36 PM | #13 |
41
Rep 241
12-08-2011, 11:51 PM | #14 |
1086
Rep 1,912
The dump line is never under vacuum so nope, just plug the holes in the DV inlets and you are good to go. Of course there are people on here who like to spend money on expensive parts and swear up and down that your engine will detonate as soon as you do this.
12-09-2011, 07:33 AM | #16 |
166
Rep 906
Drives: 2008 535xi / 2011 Z4 35Is
There is another issue with respect to Meth users.
Switching to a BOV can eject meth mixture into engine compartment correct? |
12-09-2011, 09:35 AM | #17 |
112
Rep 4,771
12-09-2011, 10:04 AM | #18 | |
33
Rep 1,029
A boost gauge wont show you boost leak unless it is MASSIVE. You would get a CEL for boost target way before you would need to go this route. If you can log waste gate duty cycle you could identify a small leak much easier... |
12-09-2011, 10:35 AM | #19 | |
153
Rep 3,730
OP - our cars have TMAP sensors, so a BOV will not effect anything.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
