I'm having these symptoms please help!!
12-06-2011, 10:52 AM | #1 |
38
Rep 753
Hi,
Recently I've had some bad luck with my car, it has a rough idle, it just now started hesitating on start ups, and twice when I press the gas and put it in s mode, it automatically turned on the SES light and later the limpmode. Last seek I was driving my car fast around 60 mph around a lonely road with lots of curves, out of nowhere the car starting shaking and turned on the SES light, the shaking was so bad I thought I had a flat tire! What is all this ? Could it be the dreaded hpfp? Also this seems random to me but a.c is not working as well as before these symptoms the ac is a lot warmer! |
12-06-2011, 11:04 AM | #3 |
38
Rep 753
Thanks for the quick response! Did it drive normally afterwards , I mean after the symptoms? If it's the hpfp I called bmwusa and they have like an extended warranty on the hpfp, I also saw an article that someone post that they did a recall in 2010. I'm going to see if it's covered through the BMW warranty, even though my warranty is up!
12-06-2011, 03:35 PM | #4 | |
IN THE KNOW!!!!!!!
12
Rep 431
2007 Jet Black 335i Coupe: Saddle Brown interior | ZSP | ZCP | ZPP | iPod integration. 1994 Hellrot 325is: Sport Package | PSS9 Coilover | AutoThority chip | AutoThority CF Intake | UUC pullies | Dinan HiFlo Throttle Body | UUC StrutBarbarian | UUC Evo II SSK | BMW Motorsports X Brace | Rogue Engineering DMS exhaust | Kumho Ecsta V700 R Comps | |
12-06-2011, 04:15 PM | #5 |
33
Rep 1,034
It's the fuel pump. Take it in, have it changed out, and you'll be back in action.
12-06-2011, 04:17 PM | #6 |
103
Rep 3,177
hpfp would be first guess, but it could also be spark plugs, coils, or injectors. without the codes from the ecu, we'd all be guessing. get a bavarian tech cable or borrow someone's and read the codes
12-06-2011, 04:20 PM | #7 |
153
Rep 3,730
Rule of thumb on start-up:
Fuel Pump = Long Cranks Injectors, Coils, Plugs = Rough Idle Sounds to me like a HPFP my friend, go get a new one. Which model # are you on now?
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
12-06-2011, 07:49 PM | #8 |
38
Rep 753
Model number??
I have a e92 335. Thanks guys, sounds like it's the hpfp. I'm going to take it to the dealer next Tuesday. (work and finals this week). I'll take it to the dealership to see if they fix it under the 120k warranty. Hopefully I won't have to pay anything. I really appreciate the help! I'll let you guys know what happens! |
12-06-2011, 07:52 PM | #9 | |
25
Rep 386
12-21-2011, 03:45 PM | #12 |
38
Rep 753
hey guys,
unfortunately it was not the HPFP, it was an ignition coil! :-(. Bmw dealership wanted to charge me 200 for the coil and install. I took it to a good bmw mechanic near me charged me 95. Saw how to do it online. Im going to do it myself next time replace the remaining 5. I heard from the SA at bmw, the mechanic and researching online that most likely if one goes bad the others will go bad eventually. I found a website that sells the ignition coils for 30 each, and im going to replace the spark plugs, looking at 60k miles soon. |
