help! raspy exhaust set up, can the axle back be my cure.
12-05-2011, 10:53 PM | #1 |
Rep 96
Need some input on my exhaust set up, I recently installed AR catless dps on my pre existing riss racing midpiped/stock axle back. Fully catless sounds great while cruising but just around 2800rpm I am plagued with rasp, it is especially bad while going up hills or under load. My question is I have a Remus Race axle back waiting to be installed, will this make the rasp any better or any worse? Logic tells me the rasp will just get much louderbut im hoping that this axle back will cure my rasp.
Proceed v5 rev.3, Injen dci, Evolution Racewerks charge pipe/TiAl Bov, Evolution Racewerks FMIC/ meth elbow, AR design downpipes, Riss Racing midpipes, Remus race exhaust, Evolution Racewerks carbon engine cover.
12-06-2011, 08:09 AM | #3 |
IG: cgom3z
16
Rep 153
This.
I had Straight 3inch pipes from the stock dp back, okay drone and okay rasp. As soon as a installed the AR 3inch dp for a fully catless set-up, sooo much rasp and drone I only drove my car up to 2500rpm and shifted. I drove slow for four days until I was able to put on two resonators. That took the sound back to how I had it.
IG: cgom3z
12-06-2011, 09:16 AM | #5 |
161
Rep 7,377
Resonators och high flow race cats in midpipes.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
