Do I have a boost leak? BT log inside!
12-04-2011, 06:24 PM | #1 |
151
Rep 1,677
First off, mods are GIAC S2 FBO with stock cat-back and no meth. I did some logs last night and if I did them right, I was peaking at ~11PSI! That worried me so I went ahead and cleaned my FMIC and DVs today. I used about 1.5 gal of the cheapest gas and 2 liters of distilled water to rinse them out. I also went from using t-bolt clamps to stock Helix worm clamps.
The attached log shows a WOT run on 2nd and 3rd. It shows that I peaked at about 15.5PSI when throttle was about 100%. I know GIAC S2 peaks at about 16.5 so is this normal for it to boost 1PSI less? It's about 57 degrees outside. Also, you'll notice that boost spikes during shifts. I think that is normal but damn, ~20PSI! Now back to the question. Any chance I might have a small boost leak? |
12-04-2011, 06:34 PM | #2 |
3441
Rep 79,211
You should be logging the waste gate duty cycles.
The T Bolt clamps are BETTER then traditional worm clamps. You will see less boost in colder temps compred to hotter temps assuming GIAC follows the same load targeting as the stock DME. Boost spikes between shifts are completely normal. There isnt an actual spike of boost in the engine, its read pre throttle body. When the throttle body closes no air enters the motor therefore there is a false reading on the T map which reads boost. Perfectly normal. The most beneficial information is read from 3rd gear only FYI. You wont hit the same boost in 2nd gear compared to 3rd. Same goes for 4th. |
12-04-2011, 06:51 PM | #3 |
151
Rep 1,677
Thanks Jeff. The t-bolts are a little more tedious to tighten. I need a set of ratchet-style wrenches, plus I never gave the Helix worm clamps a chance. Helix swears they have no problems so well see.
What is the value for wastegate duty cycle using the BT tool? |
12-04-2011, 06:57 PM | #4 | |
3441
Rep 79,211
As far as T bolt clamps go, they are the best of the best. Worm clamps are prone to not only ripping silicon couplers, but they dont tighten evenly around the couplers causing boost leaks. They (worm clamps) are better suited for non boost applications. Sears is running some great sales on tools. I highly recommend their 120+ mechanics tool set. I've modded dozens of cars with a simple set like that. Worth its weight in gold. |
12-04-2011, 07:02 PM | #6 |
Rep 375
12-04-2011, 07:43 PM | #7 |
151
Rep 1,677
Come on guys. This is completely off topic. I have tools, just not the fancy ratcheting wrench. Here's two more 3rd gear pulls with WGDC logged.
