2006 325i misfiring
12-04-2011, 01:08 PM | #1 |
39
Rep 160
2006 325i misfiring
Hello All,
When I turned on my car this morning, it started shaking at idle and then it threw a check engine light. Also there was some rotten egg smell. I went to Autzone and scanned for codes and I got the following: P0302 - Cylinder # 2 Misfire P1017 - Valvetronic eccentric shaft sensor I'm really hoping it's just a bad coil. The car isn't stalling. It just runs a little rough with some decrease in power. Would a misfire from a bad coil trigger the Valvetronic eccentric shaft sensor code? Thanks |
12-04-2011, 01:20 PM | #2 | |
92
Rep 1,456
Good luck though hope its minor |
12-04-2011, 01:22 PM | #3 |
92
Rep 1,456
12-04-2011, 02:09 PM | #4 | |
39
Rep 160
btw my car only has 52k miles. Thanks |
12-04-2011, 05:14 PM | #5 |
Freight Dawg
104
Rep 2,103
Get the sensor checked out. If it's going bad it may not be symptomatic yet but it might still be defective. I don't think the sensor is all that expensive.
Edit: Actually the sensor is a little pricy. It's just over $300. But if the sensor is bad it can lead to several thousand dollars in damage.
--Marcelo
'06 Arctic Metallic 325i | Sport Package | 6MT | Dinan Stage III suspension | Dinan exhaust | 330i manifold swap! Click here! | Active Autowerke tune | 135i Brake Calipers | Deiselboost caliper brackets | E46 M3 front rotors Last edited by e90pilot; 12-04-2011 at 05:23 PM.. |
12-04-2011, 06:30 PM | #6 |
POGI
143
Rep 1,096
I got mine done. Sensor is 350. Then u have to get gasket and screws. The dealership will kill you with labor. Because this sensor in inside the engine.
12-04-2011, 07:00 PM | #7 | |
39
Rep 160
How many hours of labor were you charged? It sucks because I had the valve cover gasket and screws done a few months ago for about $500 and they will have to be re-done. |
