Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > p30ff
      12-04-2011, 10:42 AM   #1
autodynamics
Lebanon
Drives: 335e92.996gt2 switzer P800.
p30ff
Hello,
3 days ago i was running my 335 at WOT,at the middle of the 4th gear the half engine appears ,i check it with the accessport ,the code is p30ff,i did a boost leak test but found nothing,after several run i realised that when i run it cold the boost hit 18.5psi and no fault codes,after the 3rd run the cat cant hit more than 11psi and the p30ff appear,any thoughts?can the wastegates do that?
Thanks in advance for any info
      12-04-2011, 01:05 PM   #2
JamesM3M5
Some dude
92
Drives: E92 335i
Yes. Bad wastegate solenoids, cracked vacuum hoses, and stuck wastegate actuator or even the wastegate shaft that runs into the body of the turbo can bind and cause underboost. I just replaced a bank 2 turbo on a 135 because the shaft that goes into the exhaust housing bound up and didn't allow the wastegate to shut.
RRT
E92 335i/6MT with stuff and things
      12-04-2011, 01:38 PM   #3
Elie335
ايلي ٣٣٥ هاهاها
Elie335's Avatar
St Pierre and Miquelon
88
Drives: Vorsteiner e92
you got it Ali
