Weird Engine Issue ( Update: Misfires )
12-02-2011, 12:16 PM | #1 |
68
Rep 942
Hey Guys,
need your help with a weird engine issue that I'm having. mods: Procede v4 Ur Cp/ hks bov ms Dp Today I was driving on Procede Map 2 default settings, and I hit WOT and around 3/4 rpm my engine bucked and CEL came on and is stayed on. Now the Rpms raise relatively slow and the car makes a kind of " spitting " noise like its chocking. I also listened to the engine once I got to work and it sounds like something is moving around kinda, knocking. I've already spoke to Robert at vishnu and he said to hook my CPU up to the car and pull the codes which I'll do after I get off of work but I'm going to have to leave the car here for fear of breaking something further trying to drive home. So far I have a few ideas what it could be: - Engine oil level may be low as the CEL light came on while I was switching lanes at WOT and the sound it's making is similar to a car I've heard previously that had the engine oil low. - Spark plugs engine history: Oil changed a month ago to Mobile 1 5-w30 Spark plugs changed in jan/February of this year Injectors changed/replaced in jan/feb of this year. Currently at 74,xxx miles. Thanks for any help. As I get a chance to read the codes I'll update this thread as well. Update: Pulled the codes from the procede: 11802 11703 So i know 11703 is a Misfire in Cylinder 3. I'll pull the spark plug out and check it and the coil plug tomorrow to see which one is bad. Hopefully it's just the plug. If so i'll just change all the plugs tomorrow ( Why not ). How much is a coil pack? I don't know what 11802 is though, Searched on e90 and didn't find anything. __________________
12-02-2011, 12:39 PM | #2 |
161
Rep 7,377
sounds like you missfired. Did you restart the car? Was it normal afterwards or still funky?
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
12-02-2011, 12:48 PM | #3 | |
68
Rep 942
I'll probably go back to the car after an hour and see what it's doing.
12-02-2011, 09:29 PM | #4 |
68
Rep 942
Update:
12-02-2011, 09:42 PM | #5 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
11802 translates to 2E1A (in hex) and is the code for " Ignition Monitoring Cylinder 3 Spark Duration Too Short". And since it's accompanied by a misfire cylinder 3, I'd guess that something is amiss with your cylinder 3 ignition coil. Swap it with the coil from cylinder 4 and see if the codes follow the coil. I suspect they will. If they do, just replace that coil with a new one and you should be good to go.
Shiv |
12-02-2011, 09:46 PM | #7 |
1737
Rep 17,960
Drives: A Lot
12-02-2011, 09:49 PM | #8 |
68
Rep 942
k i'll test it tomorrow. Thanks Bro.
12-02-2011, 09:49 PM | #9 |
76
Rep 1,883
Just bought one from the dealer a couple weeks ago ~$50.
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(e90post.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
12-03-2011, 06:01 PM | #11 |
68
Rep 942
Ok,
So i switched the coils 3 / 4 today. Reset AFR/Vanos adaptations VIA procede then went for a spin: - CEL light is no longer triggered, sputtering still persists but not as hard now, i can actually get on the throttle more -WOT is pointless, misfire city -Now i have 3 new codes: 11387 - Lambda probe behind catalytic converter, signal - o2 related 11388 - Lambda probe behind catalytic converter 2, signal -o2 related 12140 - Exhaust Flap ( Golf tee Mod ) So my question now is, should i ignore these codes and check the spark plug in cylinder 3 as it could be causing these issues now that i've swapped coils?
12-04-2011, 07:17 AM | #14 |
68
Rep 942
well what gets me is i've been running with my DP's hard for a month now with 0 issues. You think they would just go out the blue like that?
