New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
      12-02-2011, 08:17 AM   #1
gapek
gapek's Avatar
Drives: X3 E83 LCI
Cruise Control Retrofit
Hi,
Any idea if Cruise Control can be retrofitted to the E89?
I asked my dealer, he said it can't be retrofited
Thanks!
      12-02-2011, 02:17 PM   #2
az34
az34's Avatar
54
Drives: 2009 z4sdrive35i 2008 x5 3.0i
forget it
rjahl996.00
      12-02-2011, 04:07 PM   #3
z4z4z4
z4z4z4's Avatar
45
Drives: 2002 M3
I had no idea current models were available without cruise control. I learn something dumb everyday.
Sold 2011 Z4, kept 2002 M3
PM for various e89 parts 4sale.
      12-02-2011, 05:01 PM   #4
az34
az34's Avatar
54
good point!
      01-08-2012, 02:18 AM   #5
siscobmw
freude am fahren ....scheiden freude...
siscobmw's Avatar
Italy
17
Drives: Z4 Sdrive30i tiefseeblau
no retrofit for the moment.....
I tried to ask to my dealer, and said no.....I don't need it , but I like to have my car with some more toy.....
Francesco
      01-08-2012, 10:56 AM   #6
Alpha_Zulu
Alpha_Zulu's Avatar
Drives: 2014 Z4 35is, Alpine White
Why would you get the car without cruise control?
      01-09-2012, 04:07 PM   #7
siscobmw
siscobmw's Avatar
Italy
17
cause I do 6 k kms per year, in the traffic jam(bleah) or around tha lake of como in the weekend, a very good place to use every single bhp of my z4 engine and low gears.....different country , different needs....
Francesco
      01-08-2013, 12:32 AM   #8
Toink
Toink's Avatar
Drives: E89 Z4 sDrive35is
Hi there from the Netherlands!
Old topic, but I just wanted to let you know that retrofitting a CC is possible on the E89.
I have an 2010 Z4 sDrive35is with nearly all options, except CC. In the Netherlands this model is not even sold without CC, but I imported mine from Germany.
Anyway. You need to replace the full set of steering column handles with the one that has a CC and of course you need a new cover because of the additional hole
It cost me about 400 dollar for the set of handles, 50 dollar for the cover and coding took 2 hours at a BMW specialist. Which parts you need exactly depends on the options you have, e.g. heated stearing wheel, rain sensor etc. Find the parts you need on realoem.com.
Stories are told that you need to replace the tacho (around 800 dollars here ). You will only need the tacho for the cruise control indicator led around the speedometer. If you have a tacho without this led, the CC still works but only displays in the small screen in the middle.
Once coded, you will have CC with brakefunction, hope this helps
Pics:
Steering wheel off:
Old and new handles next to each other:
Fitted:
Coding:
      01-09-2013, 03:19 PM   #9
ManiacGT
ManiacGT's Avatar
85
Drives: Z4 sDrive 35i
Good to know! Thanks for posting..
      01-10-2013, 08:41 AM   #10
ManiacGT
ManiacGT's Avatar
85
Toink.. Does this give you Cruise alone or Cruise with Braking also?
      01-22-2013, 01:34 AM   #11
Toink
Toink's Avatar
It's with braking, yes.
      11-24-2013, 10:28 PM   #12
chudinovvn
Drives: z4 e89 sdrive30
which details part number do i need, if i have a heated steering wheel, rain sensor and adaptive hilight?
      11-26-2013, 01:19 AM   #13
Toink
Toink's Avatar
I don't know, but if you have a look on realoem.com then you'll find out which partnumbers you need exactly. You need only two parts, handles and a coverplate.
      10-22-2014, 12:45 PM   #14
DrapJ
Drives: 2009 E89 Z4 35i
Hi Toink, I'm keen to know if you've had any issues with your Cruise Control Retrofit...? I have just bought a Z4 with most of the available extras but (for some reason) it doesn't have cruise control. I'd really like to retrofit it but have been advised that BMW say it's not possible.
Apparently "There is more to installing the component and recoding so as a result they have never released a kit. There are all sorts of software issues and potential control unit glitches so they have advised it does not work."
Given the price of the parts in question you can understand that I'd like to be fairly certain it will work before making the necessary purchases.
I would of course be keen to hear from anyone with any opinion on the matter.
Kind regards,
James
      10-29-2014, 10:04 AM   #15
anggarda
Drives: z4 35i e89
Toink.
Would you be willing to share the Coding information.
If necessary, I would be willing to pay your dealer for the information and coding changes.
Regards.
      05-23-2015, 02:39 AM   #16
jaro2k
Drives: Z4 E89
When you say CC support brakes.. how does it work? I believe there is no distance sensor on car front.. OR?
      10-17-2015, 04:00 PM   #17
joker301
Drives: e89
Hi everybody, I'm although interested in retrofitting the cruise control on my e89. Can the coding process be done with carly for bmw? Anyone a clue? Thanks in advance
      10-21-2015, 02:03 PM   #18
Tangent
298
Drives: G01, F82, E89, F25
It isn't Active Cruise Control that keeps your distance from traffic using a radar. It simply is capable of using the brakes to hold your speed when going downhill or to reduce your speed more quickly than coasting down if you change the cruise hold speed from 80 to 50 for example.
      06-14-2018, 07:17 AM   #19
bonzo11
Drives: X5
Hi,
I've done retrofit for X5 E70, but cc doesn't work. Do you need to reset car equipment in INPA pls?
Thanks
      07-27-2018, 02:34 PM   #20
DavesZed
DavesZed's Avatar
144
Drives: BMW E89 23i, 2011
Exclamation
If anyone is interested in this retro-fit I've managed to colate all the information in two Word documents (1st is the physical installation and the 2nd is the coding stages). They are mainly other peoples work but just all together with some additional information especially for the e89.
They are on my DropBox account ....
Part 1 >> https://www.dropbox.com/s/3qj1ty50rg...t%201.pdf?dl=0
Part 2 >> https://www.dropbox.com/s/ltfnhvygop...t%202.pdf?dl=0
(Part 2 now includes links to new profiles and SPDaten files as well as instructions on how to load them)
I hope that is of help to someone.
Dave
2011, E89 23i, Grey with Red leather.... relatively basic (getting less and less basic with every new retrofit)!
My Z4 E89 YouTube channel...
https://www.youtube.com/channel/UCtt...0vHFUQnoEvKB2Q
      07-28-2018, 04:10 AM   #21
Wan186
Drives: 2011 EU E89 sDrive 23i
Great! Really, thx!
      10-17-2018, 03:20 PM   #22
sjeupie
Drives: Tiefseeblau E89 Sdrive 23i wit
I have an 2010 E89 without cruise control. I had a bmw specialist read-out the car and he confirmed that cruise control was already in the software. The guy was not willing to take the risk of working with second hand parts I found on ebay and I was not willing to take the risk of insisting on that and having to pay twice, so he ordered the new parts (extra cc lever requires complete unit to be replaced) and will retrofit cruise control in two weeks time. The intervention will take a couple of hours. Costs incl labour and parts EUR 750,- in The Netherlands.
It's a lot of money but I find myself constantly checking the speedo and after about 4 hours of driving I get cramp in my right leg because of constantly backing up the throtle a notch. So it's worth it for me.
Hopefully this will help someone else too. I'll report back after the intervention.
zpost
