PROcede v4 Rev2
12-02-2011, 06:55 AM | #1 |
Rep 2
PROcede v4 Rev2
Hello,
I have been offered a V4 PROcede Rev2 that was used on another car. Are there any limitations of going for a Rev2 rather than a Rev2.5/3? Would I also be correct in assuming I will need to buy an additional vehicle license as this is 2nd hand? Finally will I be stuck on V4 or can teh Rev2 be upgraded to V5? The cars a stock 335i UK spec. So any other things I should look out for would be much appreciated. Thanks, Pete |
12-02-2011, 07:09 AM | #2 |
161
Rep 7,377
you are stuck on V4 . to go v5 you need to purchase a new vin code license and send the box to vishnu for a reset.
While you are at it you can just get it upgraded to 2.5. Since you are stock try it as it is . Gonna be enough.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
12-02-2011, 10:10 AM | #3 |
86
Rep 1,262
Actually, If the unit was never upgraded to V5, it is not Vin-locked, so you can install it and then upgrade to V5 no problem!
Josh-
12-02-2011, 11:58 AM | #5 | |
3441
Rep 79,211
There are limitations to Rev2. All the current map updates, aggressive maps (which are faster then rev 2) and the changes to fueling and ignition advance wont be available with Rev2. For a nominal fee you can contact Vishnu and they will upgrade you to a Rev 2.5. The cost is insignificant in comparison to all the benefits and the majority would agree. www.procedetuning.com |
Tags |
procede, vishnu |
