BKP piggy back
12-02-2011, 06:22 AM | #1 |
Rep 2
BKP piggy back
Anyone try BKP piggy back(i think from germany).
Just uninstall my JB4(on map 3) yesterday,the feel is almost or better than my JB4 map 3 methanol. My last dyno full bolt ons with JB4 map3 peak 370bhp@5,393rpm 572nm@3,898rpm.Map 0 is 279.3bhp@4816rpm 445.4nm@3218rpm. Dont feel right because i thought stock should be 306bhp?And after 5,400 rpm my power drop but this BKP still pulling till 7,000rpm+/-. Just wanna confirm the limit of JB4,anyway BKP offer 7 days money back.i will need to dyno again to prove the graph is more flat compare with JB4 which go down hill after my peak. Last edited by TCP; 12-02-2011 at 06:38 AM.. Reason: Spelling |
12-02-2011, 06:46 AM | #2 | |
79
Rep 1,617
Performance Seats, Exhaust, Splitters, Pedals, Steering Wheel / RB Turbos / M3 CF Roof / Brembo GT BBK 355/345 / Rollcage / Forge FMIC / Quaife LSD / Öhlins Road & Track / M3 Suspension Parts / Solid Subframe Bushings / Vorshlag Camberplates / Megan Racing Toe Links / LeatherZ Gauges / Extended M3 DCT Paddles / ER Sports OC / AR OC / Aux Radiator / AR DPs / Alpina TCU / COBB Pro-Tune
12-02-2011, 06:52 AM | #3 |
161
Rep 7,377
Seems they just resell the CP-E standback
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
12-02-2011, 11:53 AM | #4 | |
Joint Chiefs of Staff
4918
Rep 115,980
On the JB4 map 3 it can make as much or as little power as you want. It all depends on how much boost you've set it for and how much methanol flow you have. Also for higher boost levels you would want to do the 15ohm mod to unlock an extra 1-2psi. Mike |
