02 sensors
12-01-2011, 11:12 PM | #3 |
Rep 6
The wideband sensors are current based, so they don't output a voltage proportional to the AFR. You either need to add an aftermarket wideband or let a tune with canbus integration handle whatever your trying to do.
12-02-2011, 10:24 AM | #4 |
441
Rep 18,331
Our front O2 sensors are widebands and the rears I believe are narrow bands. The widebands should read off in volts. Can anyone confirm this??
12-02-2011, 10:35 AM | #5 |
65
Rep 1,708
WB report current to the DME... the amount and direction determine how much oxygen is pumped or removed from the reference cell to reach stoich. the difference determines lambda. A full understanding is a little beyond my peabrain.
NB report voltage. |
12-02-2011, 10:39 AM | #6 |
441
Rep 18,331
I am thinking about installing a dyno tune lean cut off which it states it can be directly hooked up to the factory o2 sensors. So the rear sensors are NB. Does anyone know the volts of our NBs?? Thabks
12-02-2011, 10:43 AM | #7 |
65
Rep 1,708
NBs should be 0-5v. I believe 0.45v is stoich. But NB only read rich or lean... once it reports lean, its too late I would think. Go with aftermarket WB
