BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > DV's?
      12-01-2011, 08:34 AM   #1
3-Serious
45
Drives: AP e92 335i
DV's?
How do I know if my dv's are on the way out? I hold boost but between shifts the boost climb in sometimes shakey or delayed. Also I made a post before about hearing sputtered noise at part throttle, I wonder if the dv's are the cause of this too. I know its not the turbo or the waste gate just had them replaced. (Mods: DCI, AR dp, PROcede v5 rev 3)
      12-01-2011, 10:16 AM   #2
ModBargains.com
475
Drives: JB E92 335i
The stock diverter valves are plastic and overtime can of course break down and cause boost leaks. An upgraded diverter valve is an ideal upgrade for anyone who is running higher boost (software or tune) and a necessity if you would like greater boost response and of course to prevent boost leaks!
The Following dyno chart was completed using a 1M, ONLY changing the stock diverter valves to the Turbosmart Diverter Valves. The graph shows the stock diverter valves leak boost, especially down low where it counts. Just by switching them to the Turbosmart Diverter Valves gains in torque are realized throughout the RPM range, with gains of over 25 Ft./Lbs down low.
[img]http://www.**********s.com/images/Products/Turbosmart/BMW-Turbosmart-BOV-Dyno-Horsepower-Torque-Test.JPG[/img]
The following dyno shows manifold pressure, and how just by switching to the Turbosmart Diverter Valves boost pressure is maintained.
[img]http://www.**********s.com/images/Products/Turbosmart/BMW-Turbosmart-BOV-Dyno-Boost-Pressure-Test.JPG[/img]
      12-01-2011, 10:32 AM   #3
3-Serious
45
Drives: AP e92 335i
Thank you for the response? Anyone else have a take on this sitchuation?
      12-01-2011, 10:42 AM   #4
Chicks-Love-Bimmers
Chicks-Love-Bimmers's Avatar
68
Drives: FBO 335i
2007 E92 335i  [0.00]
I plan on upgrading my DV's as well, but from what I've read the stock one's hold boost pretty well to a certain extent. I've read stories of people never even having to replace them while running like 18 psi. I think you should be okay for now, but eventually upgrade it if you plan on going FBO.
      12-01-2011, 11:02 AM   #5
nitehawk
nitehawk's Avatar
102
Drives: e92 335i 6MT
I too am curious about this. Other than boost, what parameters can one log to ensure there are no leaks under WOT? WGDC?
      12-01-2011, 11:12 AM   #6
ar design
ar design's Avatar
297
Drives: 04 M3
I would definitively upgrade the DVs - Forge makes a really nice set as well.
-Critter
      12-01-2011, 11:16 AM   #7
3-Serious
45
Drives: AP e92 335i
Yeah I plan on going full bolt on, also on cold nights when its like 30 out I spike 18 :/ for a little bit. So maybe its time I should upgrade them. Thanks for all the input. Also when I just replace the DV's should I replace the charge pipe with it?
      12-04-2011, 04:24 PM   #8
3-Serious
45
Drives: AP e92 335i
Check out my boost between shifts. I know its hard to see but I did the best I could. Does this look like a DV problem? I let off after it bounced the second time.
      12-04-2011, 04:46 PM   #9
thebigragu99
45
Drives: 135 tuorbbo
Boost looks solid!I would log it then you would really now the truth,but from the vid it looks fine.Terry tested the stock 2008 d.v's and they held 25 psi with issues.
http://www.n54tech.com/forums/showthread.php?t=40
      12-04-2011, 04:48 PM   #10
3-Serious
45
Drives: AP e92 335i
But you see how it bounces once I throw it into 4th, but yeah I plan on logging it this week.
      12-04-2011, 04:51 PM   #11
thebigragu99
45
Drives: 135 tuorbbo
http://www.n54tech.com/forums/showthread.php?t=109
      12-04-2011, 04:52 PM   #12
thebigragu99
45
Drives: 135 tuorbbo
Yeah I see it..Which piggy you have?
      12-04-2011, 05:08 PM   #13
3-Serious
45
Drives: AP e92 335i
That was an interesting information. Thank you it now makes send why when I boosts at part throttle I hear a shutter noise its probably leaking a tiny bit at low boost, then is fine up top. Also Im running a PROcede v5. You think its doing that because I'm spiking 18 and haven't raised the max boost limit?
      12-04-2011, 06:50 PM   #14
thebigragu99
45
Drives: 135 tuorbbo
Raise it and see if it changes things then report back.
      12-04-2011, 09:20 PM   #15
3-Serious
45
Drives: AP e92 335i
Will doo.
      12-08-2011, 07:59 PM   #16
3-Serious
45
Drives: AP e92 335i
Ok well it finally stopped raining! So I adjusted the max boost limited too 19 because
sometimes I spike 18, and the same thing still happens from 3-4th the cars boost drops then jumps to 18 then back down and then back up. May do some logging tonight to see what's up it drives me crazy! I want to be able to throw it into 4th with no worries!
      02-11-2012, 11:04 PM   #17
3-Serious
45
Drives: AP e92 335i
Bringing this thread back to life, because I'm still having this problem and cant seem to figure out what it is. Every time I try and go a log it doesn't happen! But of course when I'am not logged it happens like clock work! I also notice it happens more likely when its decently cold out. My current mods are Vishnu V5 rev3 11-25maps stg3 map 1, DCI, AR Downpipes, AMS Intercooler, Vishnu charge pipe with Forge DV's. Has anyone else had this problem?
