Does an AA Tune mess with your computer fuel milage gauge??
11-24-2011, 07:32 PM | #1 |
705
Rep 2,605
Drives: 06 330i E90, 18 530xe G30
Has anyone with an AA tune noticed a difference between what your computer estimates as your average fuel economy vs actual fuel economy calculated by hand? Last fill up I calculated my fuel economy (km's vs. gas used since last fill up, in mpg) and compared it to what my computer estimated since I reset it last fill up. What I had calculated was 3-4 mpg less than what my computer said. Is this common or have to do with the AA tune and the throttle remap?
11-24-2011, 08:41 PM | #2 | |
253
Rep 7,089
Drives: '06 AW 330xi
The mpg in our cars is an average of multiple fill ups. It is an average off all the gas that has been run through your car from the last reset. Ie disconnecting the battery. |
11-24-2011, 09:15 PM | #3 |
705
Rep 2,605
I am a mechanical engineer, I can ensure the math is correct. I also reset the fuel consumption average at time of my fill up.
11-27-2011, 03:42 PM | #4 |
Freight Dawg
104
Rep 2,103
The MPG calculation is not an actual measure of gas mileage. I'm not sure why since the car has a fuel counter and odometer. It uses a combination of engine load, throttle position, etc to give you an estimate. It's possible that changing the fuel mapping would decrease the accuracy of the mpg calculation since the tune uses a higher fuel/air mixture.
--Marcelo
'06 Arctic Metallic 325i | Sport Package | 6MT | Dinan Stage III suspension | Dinan exhaust | 330i manifold swap! Click here! | Active Autowerke tune | 135i Brake Calipers | Deiselboost caliper brackets | E46 M3 front rotors |
11-29-2011, 12:12 PM | #6 |
Rep 123
If before the AA tune you drove like Mrs. Daisy, and still after the AA tune you’re still driving like Mrs. Daisy, then you should get a small increase in your fuel economy. But, if you drive like a bat out of hell, like I do, then your fuel economy sucks Orangutan balls!! So it pretty much depends on which side of the balls you’re sucking! It’s a no win stuation…
11-29-2011, 12:48 PM | #7 |
30
Rep 469
I've also done Manual calculations vs what the computer suggested average.
My calculations have always been within 1MPG of what the comp states.... I'm guessing the variance is due to me filling up more than the last time.. Extra clicks on the top off maybe? I thought the newer cars based the calculation on speed vs fuel flowing out of the injectors?
MODS-ST c/o- full Mtech conversion-ltbmw carbon lip/ OEM trunk lip/ performance diffuser/gloss vinyl roof/ lux8 angels/ euro air box/performance exhaust/ CCW classics/performance shifter and hand brake
performance bbk/ active xenon lights |
11-29-2011, 08:56 PM | #8 |
50
Rep 753
a side effect of an aa tune is a heavier right foot which in turn causes higher fuel consumption. the miles left to empty is not resettable like the average fuel consumption and takes into account the driving style in a longer period of time.
keep in mind that in Toronto we have switched over to winter fuels around 3-4 weeks ago which are notorious for higher fuel consumption, it will take a while for the computer to adjust to the new settings and fuel. |
11-30-2011, 05:26 PM | #9 |
705
Rep 2,605
I just added 40 L and did another calculation. My calculated average was 26.5 MPG vs. 28 MPG my computer was showing. I reset the average fuel consumption the last time I filled up so it is a little bit closer.
11-30-2011, 06:42 PM | #10 |
Caught the Bimmer-Bug
50
Rep 639
