Anyone Still Using Their Stock Charge Pipe And Bov With Fbo Pump Gas??
11-23-2011, 07:01 PM | #1 |
47
Rep 828
As the tittle states.I'm running fbo 93 oct with a jb4 around 15 psi and will be switching to map 6 shortly.How much power and boost are the stock bov's good for??The car is a 2008 135 i if that matters .thanks.
11-23-2011, 09:12 PM | #3 |
Mad Linux Guru On The Loose
1130
Rep 5,400
Drives: 2008 335i Sedan, 2023 M3
Stock charge pipe with Forge DVs. The stock DVs were holding up just fine. I had a great opportunity to snag the Forge DVs at a very low cost, so I went for it.
I've seen boost as high as 19.3 on Cobb S2 Aggressive (measured at the manifold). No issues on the stock charge pipe at all.
11-24-2011, 11:51 AM | #6 |
14
Rep 579
Drives: 08 AW e92 335i
Stock charge pipe and dv's @ 15.5 psi on 93 gas and have no issues. On racegas and 19psi, no issues as well.
11-24-2011, 11:52 AM | #7 |
161
Rep 7,377
there are NO issues using the stock chargepipe even at 20 psi.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
11-24-2011, 12:10 PM | #9 |
108
Rep 1,973
Drives: 2009 e92 MR "Civic" ///M3
mine kept popping off any time I would hit over 16psi, but that could've been to the addition the ER Intercooler and different piping.. so I got the ER charge pipe.
|| DCT | ESS Tune | ACM Test-pipes | AA Green Filter | Swift Spec-R Springs | Stoptech ST-40 F || || My Youtube Channel ||
11-24-2011, 12:27 PM | #10 | |
87
Rep 2,854
i tapped my stock cp, and now i'm weary of removing the nozzle for regular maintenance and cleaning due to wearing out the plastic threads that i made. |
11-24-2011, 01:01 PM | #11 |
70
Rep 2,197
Dont over tighten and you *should* be OK.
Plastic does make me nervous as hell though, it's so easy to say "well, just a little tighter should do it" and then *crack* "ohh fffuuuuuuccckkk" |
11-24-2011, 02:45 PM | #12 |
102
Rep 1,903
Drives: e92 335i 6MT
11-24-2011, 03:25 PM | #13 |
108
Rep 1,973
It keeps the stock clip, but being aluminum it fals into the groves allot nicer. Even without the clip the fitment is pretty snug, I've ran over 19psi on it with no issues at all.
11-24-2011, 03:27 PM | #14 |
32
Rep 878
I'm still on stock cp n dv. No problems so far.
08 335i | Space Gray | Burl Walnut Wood Trim | Sport pkg | Premium Pkg | LOGIC7 | Navi | Comfort Access
| COBB | Injen DCI | Active Autowerke | Sonic Tuning | E92 Lighting | ER | HKS | BMS | Ground Control | Vortex Tuning | |
11-24-2011, 04:59 PM | #15 |
69
Rep 1,137
fbo plus meth running 20psi no issues with stock pipe and dv's
2008 335i coupe AW 6AT, RB Turbos, PROcede 2.5 V5, Alpina Flash, Injen Intake, VK MW DP . Helix IC, Vishnu PnP Meth(M10 nozzel), M3 sides, OEM Aero Lip, VMR V710 Midnight Blue, LUX H8, HID Fogs, M3 front bits, D2 Coilovers, Whiteline Rear Bushing inserts, Custom M3 Steering Wheel, Cyba scoops, M2 Performance Exhaust |
11-25-2011, 01:19 AM | #16 |
80
Rep 586
Factory ones are fine, expensive ones are for the people who want it to sound like the are driving an eagle talon with a turbo
2021 Mercedes G550
2015 X5M 2020 Supra-JB4, DP 2008 M5 with muffler delete-sold 2007 650i-sold 2008 335i-JB4, DP, Meth-sold |
