How much boost should i be pulling with JB4 map 3 and meth
11-23-2011, 01:17 PM | #1 |
129
Rep 571
I am running JB4 map 3 with meth 70/30 DA mix. With DCI and 3" DP's
Have only hitting about 15.5 peak boost in 1st and 2nd gear, once in 3rd gear i saw 16 psi on my Rix gauge just wondering if this is normal or low, i thought i read that with meth i should be pulling about 18psi
11-23-2011, 01:26 PM | #2 | |
161
Rep 7,377
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
11-23-2011, 04:51 PM | #5 |
161
Rep 7,377
exactly , all written in the meth setup guide Stay around 17 psi first and than log.
11-23-2011, 09:34 PM | #7 |
829
Rep 3,982
Nope, the settings are not mixture related except for changes you might make yourself in response to your ignition timing quality.
2011 Alpine 335d M-Sport 12.34 @ 110.48mph
2019 i3s Terra, 2008 Black 335i Sedan. 11.11@ 129.47 mph 2008 Monaco Blue JB3 2.0 335i Coupe. 11.33 @ 132.77 mph, 60-130mph: 6.95 seconds 2023 i4 M50 11.48 @ 121.56mph, 3.43 0-60 (dragy) |
11-23-2011, 10:04 PM | #8 |
Rep 5
Well, I'm actually having the same issue. I have DCI, DPs, JB4 and WW meth + 93. I'm running 80/20 denatured alchy with 40 meth additive. However I could only see less than 16 psi peak boost. Does this sound normal ?
11-23-2011, 10:26 PM | #9 |
829
Rep 3,982
If timing is fine, raise your additive. I was running 50 for the longest time. Then switched to 55 additive. The other day I raised it to 60 additive, although it doesn't seem to have made a significant difference. I am not on the most aggressive resistor though. And on stock resistors, you may be close to be capped out. Raise it, and compare your logs. (as long as timing is good). And remember, it takes about 3 full throttle passes to see where you timing settles down to. (I cringe at the though of people that have switched tunes, at the dyno, and expect optimal results. )
11-24-2011, 10:28 AM | #10 |
Rep 170
meth additive at 30 on 93 octane is 18psi target...sounds like you either aren't registering max flow or might have a slight boost leak so you can't boost over 16psi ? did you adjust the pump pressure when you installed the meth ??
hotrod - additive 60 would be +6 psi under max flow so are you hitting 21psi ? what octane are you running ? Last edited by JBax; 11-24-2011 at 10:35 AM.. |
