Brake dust - won't come off
11-22-2011, 12:04 PM | #1 |
11
Rep 269
I bought my 328i CPO. Previous owner was not as careful with the rim washing as I would have been. Does anyone have an idea about how to get the cooked on brake dust off. Lost cause? I've heard oven cleaner will do it, but I'm skeptical.
Thanks! |
11-22-2011, 09:02 PM | #5 |
68
Rep 942
use all 3 with a wheel cleaning brush. good luck.
11-23-2011, 01:28 AM | #7 |
21
Rep 780
Sonax did a good job on an old set of rims I have, might take a few passes.
Saw on the DI site they use a steamer to clean the rims, you can get a small steam gun from Costco called a 'euroflex monster steam cleaner' |
11-23-2011, 07:35 AM | #8 |
11
Rep 269
I'll try some of those things. I have a brush, and I've tried a couple of the Eagle 1 and Maguires (can't remember the name) to no avail. This stuff has been baked on for years in some of the corners of the rims.
11-23-2011, 09:17 AM | #9 |
king of the hills
92
Rep 2,915
Drives: 2011 M3 w/ESS55, 2001 540i/6
Definitely give it a try with Sonax or similar and agitate. And if that doesn't get rid of everything completely then take some clay to the wheels, that should eliminate the rest of the dust with some elbow grease.
11-23-2011, 12:14 PM | #10 |
Long Time Admirer, First Time Owner
18031
Rep 9,378
The first time I took the rims off and did the full Turkey weekend cleaning. I spent at least 2 hours per wheel with clay. I thought for sure I needed to have the rims blasted and re-painted, but I'm glad I was wrong. Now every turkey and Easter I pull the wheels, clean/clay both sides, then put 2-3 coats of Poor Boys Wheel Wax on them. In between I just wash with a bit of regualr cleaner and wipe them clean.
11-23-2011, 02:34 PM | #11 |
Rep 111
I've tried a lot of wheel cleaners and Sonax works the best at removing caked on brake dust IME.
11-28-2011, 06:21 PM | #13 |
14
Rep 396
Agreed...Sonax Full Effect, then medium grade clay with lube for the leftovers, apply 2 coats of Poor Boy's World Wheel Sealant and you should be golden.
2014 F30 M-Sport 328i, Estoril Blue, Sport Auto, Moonroof, Lighting Package, Navigation, Harman Kardon, Black Performance Grilles, Stainless Pedals.
02-28-2012, 09:56 AM | #14 |
11
Rep 269
Resurrecting a long dead thread with updates...
I bought the Sonax Extreme and finally got time/weather/inclination to do the work. I have a set of winter rims/tires so I was able to put the stockies flat on the ground. HOLY COW this stuff works. Amazing. It takes a while, though, for the chemical to start breaking down the solids. I sprayed it, let it sit for 3-4 minutes, then went after the caked on stuff with a cotton buffing pad and elbow grease. I'll have to do it again, the results so far are better than I could have imagined with a consumer grade product. Stuff is damn expensive, though... |
02-28-2012, 11:28 AM | #16 | |
70
Rep 1,324
Was: 2008 335xi sedan 6MT Black Sapphire Metallic
Is: 2014 Tesla P85D (Blue Metallic) Wife's: 2013 Infiniti G37 S sedan 6MT, Black |
02-28-2012, 01:29 PM | #17 |
11
Rep 269
As a former car wash operator, having nasty rims is antithetical to everything I stand for (when it comes to car care). I am very pleased.
02-28-2012, 02:19 PM | #18 |
97
Rep 513
Drives: 2006 325i (SOLD)
I used some Purple Power at full strength and that seemed to work pretty damn good. Spray it on, let it sit, agitate with brush, and rinse repeat as needed.
Regards,
SnyperX |
03-07-2012, 08:16 AM | #20 | |
Rep 59
I had very good results with a regular car polish. I used Meguiars Ultimate Compound and a bit of hard work and they came up brand new. You could use a cleaner polish aswell or any car polish without any risk of harming the finish and bringing them back to their new appearance. If I had to chose Id start with Meguiars paint cleaner . |
03-07-2012, 08:19 AM | #21 |
39
Rep 709
Drives: '07 335i (E93)
Sonax ftw! Great stuff.
Alpine White/Coral Red/Gray Poplar Convertible Sport/Prem/Step/Comfort/Nav/Sirius
MHD Stage 1 Flash, M-Factory Helical LSD By the way people: USE YOUR F&*#ING TURN SIGNALS! Pass the word. |
03-07-2012, 10:36 AM | #22 |
18031
Rep 9,378
before you polish/compound, use the less-aggressive clay. You may still need a light polish after claying.
"What's wrong with a kiss boy? You don't have to go diving straight for the clit" |
