PROcede tuning question
11-21-2011, 07:53 PM | #1 |
17
Rep 205
Hi guys,
Call me crazy but I'm not a big fan of the power delivery vs throttle position that comes with the default maps. Seems a little rough to me even though everyone else says the power delivery is so smooth with these things. What parameter do I need to adjust so that the car feels like stock if I'm only pushing the accelerator < 30-40% or so, and then PROcede starts acting once I exceed that? I tried bumping the Boost Response setting to 50%, but still not satisfied. Maybe I need to go lower or is there another parameter? Last edited by scottro; 11-21-2011 at 08:51 PM.. |
11-21-2011, 08:38 PM | #2 |
51
Rep 923
Which maps are you running? I believe lowering the boost response further should help achieve what you are looking for. Also what are you other settings/mods?
11-21-2011, 08:51 PM | #3 |
Rep 92
11-21-2011, 08:52 PM | #4 | |
17
Rep 205
I'll try lowering it some more and see if it helps. I can tell a difference on the smoothness when I go into Map 0. I want Map 1 to feel like Map 0 until I get on the throttle a bit more. |
11-21-2011, 08:56 PM | #5 | |
17
Rep 205
New Update: Taking things a bit further, we now give the user the ability to adjust the boost onset point. So instead of having boost target start its upwards ramp at the usual 15-20% applied throttle, the user can make it so that boost onset occurs much later. The advantage of this is that some users will find it nice to have more throttle to play with before boost is demanded. This will make a car feel "SMOOTHER" since the Procede will be less sensitive to what your right foot is doing at the beginning of the throttle range. The downside is that once the boost onset threshold is crossed, there is less range to "spread out" the boost demand. Of course, different users, with different applications, will have different ideal settings. He then goes on to say that: Setting it to 50% will make the throttle point for boost onset increase to 40-45%. I've got it at 50% but it sure feels like boost is coming in before the 40-45% throttle. I'll try reducing some more and see how that feels. Thanks!! |
11-21-2011, 09:07 PM | #7 |
109
Rep 3,177
maybe switch back to the 7-29 maps and enable auto-tuning. they were more linear and smooth. the new aggressive maps are just that- aggressive. the throttle feel and torque delivery is a little more brutal than the older maps. i actually prefer the new 11-1 maps, but i know everyone's opinion differs.
11-21-2011, 09:10 PM | #8 | |
17
Rep 205
Currently it's very touchy to the throttle, I think BMW did a nice job smoothing it all out. |
11-21-2011, 09:12 PM | #9 | |
17
Rep 205
The Boost Response seems like the right parameter I need to adjust, so I'll try playing with that some more to see if I can achieve the feel I want |
11-21-2011, 09:14 PM | #10 | |
51
Rep 923
EDIT: I guess I was typing too slow. Bryce beat me to it |
11-21-2011, 09:24 PM | #11 | |
17
Rep 205
But I do like that the 11-1 maps run a bit richer, which is one reason I want to run 11-1. Also keep in mind I do like aggressive, just not ALL the time.. So I want it to only be aggressive if I'm aggressive w/ the pedal. |
11-21-2011, 09:34 PM | #12 |
Some say...
239
Rep 4,296
Drives: Fresh
Did you used to drive a honda? Seems like you are searching for something to similar to VTAK.
I have exhaust and an intake... |
11-22-2011, 09:13 AM | #16 |
35
Rep 450
scott is ur car an MT or auto? i have the same issue you do, i like having all the power on tap down low but i want a linear throttle map tp go with it. mines still @ 100% though and the throttle i feel the boost comes in too early making it STRONG down low and little difference on the last half of pedal. if you find a good "%" to set throttle @ let me know please because what i'm up against
11-22-2011, 09:22 AM | #17 |
83
Rep 2,291
My opinion is that the smoother you try to make things feel; the slower the car feels... I am sure everyone has their preference on throttle positioning though.
2jZ + RB26 + 4G63 + LS9 + N54 =
11-22-2011, 09:29 AM | #18 | |
17
Rep 205
11-22-2011, 10:43 AM | #20 | |
35
Rep 450
like a placebo "omg my car's quick" down at lower throttle angles, then at higher throttle angles you realize theres not much left btw i love your sig! if only (hopefully someday we'll have such things for the ol 54) |
11-22-2011, 11:00 AM | #21 | |
83
Rep 2,291
As far as my sig, we can all wish right
11-22-2011, 01:04 PM | #22 |
1750
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Do you guys wear cowboy boots while driving?
