ZPOST
Go Back   ZPOST > BMW Z4 Roadster and Coupe > General BMW Z4 Forum
  TireRack
      05-13-2007, 03:51 PM   #1
srhutch
srhutch's Avatar
12
Drives: Z4M & F11
Rollbar Covers
Does anybody know how to remove the rollbar covers?
Collected my Z4 yesterday along with the factory wind deflector and replacement rollbar covers.
Have looked at TIS but cannot find any information on removing.
Looks like the covers just clip onto the rollbar but if anybody could confirm I would be grateful
thanks
      05-13-2007, 04:03 PM   #2
Wondermike
Wondermike's Avatar
Drives: 2007 SLK350 Auto
I think they'll just prise apart, but if you have new ones anyway it doesn't matter. From memory, they usually break when you try and remove them.
Mike
2007 SLK350 Auto
      05-13-2007, 04:12 PM   #3
srhutch
srhutch's Avatar
12
Drives: Z4M & F11
Thanks for the quick response will give it a try next weekend.
      05-13-2007, 09:14 PM   #4
ay8306
ay8306's Avatar
Drives: 2006 Z4 3.0si
I recall a "how-to" from Z4UM on installing the wind deflector. I think that they used a putty knife to work open the covers, but as Wondermike described, you can't help but snap a few of the tabs as you go.
      05-13-2007, 11:04 PM   #5
Rick Hunter
Skull Squadron Leader
Rick Hunter's Avatar
304
Drives: '07 M Coupé & '16 435xi GCoupé
Ahhh... yes... push the magic button ---> <---
Wish I could show you pics of my rollbar, but I don't have any.
      05-14-2007, 12:51 AM   #6
srhutch
srhutch's Avatar
12
Drives: Z4M & F11
Rick
thanks for that post, I have been searching all over the net even tried a search on cached z4um site but to no avail.
Think i would have struggled without knowing about removing the seatbelt guide.
thanks Steve
      05-14-2007, 01:44 AM   #7
Rick Hunter
304
No prob, mate. That's what Z4um... er ZPOST is here for!
Good luck with your operation. And post a few pics of your ride, eh?
      05-14-2007, 09:00 AM   #8
srhutch
srhutch's Avatar
12
Drives: Z4M & F11
Will post some picks soon.
Also installing Parrot CK3200, and Dension IceLink PLus from my old E46. (Have new harness)
Could post those install picks of those if you think they maybe useful
      06-15-2007, 10:41 PM   #9
Rick Hunter
304
srhutch, did you ever manage to install your deflector? I'm curious how it went. Pics please!
      06-15-2007, 11:53 PM   #10
zednik
zednik's Avatar
Drives: 2006 Z4 3.0i
I removed the stock rollbar covers to install an OEM wind deflector and they all ended up with broken tabs. A local dealer tech tells me 90% of them die in the process. If you take them off assume they will not be able to be reinstalled.
      06-16-2007, 06:30 AM   #11
Cmick
Cmick's Avatar
Drives: 06 ///M Roadster
srhutch I'm in the process of installing the OEM deflector right now. I did this once before to add the OEM deflector to our old Zed.
Like zednick mentioned you'll break some or all of tabs in the process of removing the old covers.
First you'll have to remove the seat belt guides located outboard of each cover. There's a hard rubber cap on the top of the guide. I used a screw driver to pop the rubber caps off. Then underneath the belt there is a screw you'll have to remove to take off the bottom part of the guide. You'll need a star hex socket to remove the guide bolts (I'm not at home and don't remember exactly....I think 7mm or 8mm but can confirm on Monday) These have to be removed in order to take off the rubber molding at the bottom of each cover (part # 6 & 7 in diagram).
Use two or three putty knives (I am using two plastic types and one rather thick metal one) to open then pry apart the covers slipping them underneath the covers then (this is the hard part!) pry them open one section at the time. The plastic putty knives help open the gap to slip in the metal one. You'll have to put some muscle into it and you'll hear some of the clips snap as you do it (it's OK....that's why you got the new covers).
Be sure to get all of the broken clips out of the roll bar cover retainer (part #3on the diagram) before trying to install the new covers. I find it's best to count how many are broken then count how many I recover just to double check.
When installing the portions of the wind deflector that fit in each roll bar cover (not the center section between the covers but the little plastic sections in each cover) be sure to position them so the small hangar hooks (you'll see them if you look at the top center section of the inserts) towards the front of the car. Believe it or not they serve as hooks to hang clothes on while traveling (thank god for the old DIY or I never would have noticed).
Sorry but I'm traveling this weekend but will post pics and a short diy when finished next week. I'm sure it would make more sense if I had all of the photos ready to post but I won't complete the install before next week (it seems that I can't find black roll bar covers to replace the ///M covers so I've got to paint the silver replacements.....that's another DIY to post later).
Below are some photos of the covers I removed. You can see where some of the clips are broken. I've also added some showing on part #3 where you'll find the clips that broke off. You can also see where I've removed the seat belt guides in the photos # 3 and #4.
06 ///M Roadster
"Black Viagra"
      06-16-2007, 06:45 PM   #12
mister_roger
mister_roger's Avatar
13
Drives: 2003 Maldives Blue 2.5i
yer interior is looking a tad dusty there
2003 Maldives Blue 2.5i -- 18" M6 wheels, 12mm rear spacer, ///MZ4 front bumper conversion, Eibach lowering springs, Koni shocks, Hotchkis F/R anti-roll bars, Helene Performance air filter.
      06-17-2007, 07:57 PM   #13
Cmick
Cmick's Avatar
Work in progress......
06 ///M Roadster
"Black Viagra"
      02-15-2009, 03:54 PM   #14
BU Z4
15
Drives: Big & Small
Can I just buy the front roll bar covers to install the removeable deflector, since I think the rear covers are excatly the same?
      02-15-2009, 10:15 PM   #15
psygnosis
psygnosis's Avatar
23
Drives: '04 Z4 3.0i Sport
I believe it comes as a kit with both rollbar halves and the wind deflector.
Straightaways are for fast cars, Corners are for fast drivers.
      02-16-2009, 01:45 AM   #16
BU Z4
15
Drives: Big & Small
I already got the the 3 piecees deflector, and other hardwares except the rollbar covers, and I know that I can buy the covers seperately.
      02-16-2009, 12:26 PM   #17
Hawker 800XP
Hawker 800XP's Avatar
Drives: Z4
Search this Thread:
Advanced Search
zpost
