Throttle unresponsive, Engine acting crazy.
11-19-2011, 05:27 PM | #1 |
88
Rep 870
I am getting all sorts of errors and I'd like some help.
First I was getting 2CF7 AND 2CF6 Throttle valve potentiomenter. RPM at ide were rapidly changing 800-1100 rpm at idle. I removed JB4 and Now I get 2CFB: 2CFB Throttle valve adaptation value Error will cause a warning light Error is currently present Test conditions have not been completed Short circuit or signal interruption 2D09: 2D09 butterfly valve Error will cause a warning light Error is currently present Test conditions have not been completed Timeout Did I mess something up when I removed JB4? The throttle is completly unresponsive now. (I have no other engine/drive train mods) Solution below in the thread.
2007 E92 335i / 6MT / Monaco Blue Metallic / Gray Dakota Leather / Comfort Assist / Premium / Sport / Heated Seats / Navi / Active Steering / Active Cruise Control / Park Distance Control / Rear Sunshade / Sirius MODS PicoTray / M3 Steering Wheel / Front OEM Aero Lip / Bimmian Aluminum Pedals / CDV / Ram Air Scoops / Painted Reflectors / HID 5000k / LED Angels / M Perf. Shifter / Euro Light Switch / 8500 x50 / Center Armrest Pouch / JB4 / BT
11-19-2011, 05:31 PM | #3 |
13
Rep 377
try removing the battery connections and letting it sit overnight
2007 335i Coupe 6AT - Sports Package - Premium Package - Procede V5 Rev 2.5 - Vishnu PWM - Vishnu DCI - Vanguard Exhaust - AR Downpipes - Helix FMIC - 19" Avant Garde M6 Reps - Michelin Pilot Super Sports - Bilstein PSS10 - M3 Suspension Bits - M3 Sway - M3 Strut Brace - GP Thunder -Forge DV -15% Tint - Aero Lip
11-19-2011, 05:37 PM | #4 |
88
Rep 870
Is the 30 amp in the glove box or in the box with the DME?
Okay
11-19-2011, 05:42 PM | #5 |
Rep 476
Mine was in the glove box. However, some models have the additional fuses in the ecu area. To the right of the dme is a small black box...this was the actual relay on my car. Others have a box of five or so additional fuses. I had those exact codes and problems before I replaced the fuse.
11-19-2011, 05:57 PM | #6 | |
88
Rep 870
So you replaced a standard size fuse in the glove box correct? Not a black relay?
11-19-2011, 06:05 PM | #7 |
Rep 476
Yeah standard 30 amp fuse in glovebox was my fix. However, check the black box in the ecu area. It's small and sits just to the right of the dme. That box will either contain more fuses or the actual relay. That red fuse that you speak of is fine and not the issue. How are you determining which fuses to check?
11-19-2011, 06:18 PM | #8 | |
88
Rep 870
11-19-2011, 06:26 PM | #9 |
1750
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Just so a throttle adaptation reset followed by a dme reset. That should fix it.
11-19-2011, 07:27 PM | #10 |
Some dude
92
Rep 1,780
Interesting. Can this be done without a diagnostic tool? Such as the older Bosch 41/42 DMEs you would turn the ignition on, press the throttle all the way down, release, then wait a few seconds before restarting. Or something like that...
RRT
E92 335i/6MT with stuff and things |
11-19-2011, 07:34 PM | #11 |
88
Rep 870
Success!!!!
11-20-2011, 02:18 AM | #13 |
1750
Rep 17,960
Drives: A Lot
Thanks... glad it worked out
11-20-2011, 08:46 AM | #14 |
13
Rep 377
thats what i was gonna tell him to do, but he already removed the jb4 and wasnt sure if he had a bav tool or not
11-23-2011, 04:41 AM | #15 |
88
Rep 870
Update: So far so good, no additional problems.
11-23-2011, 03:03 PM | #16 |
1750
Rep 17,960
Drives: A Lot
01-02-2012, 10:54 AM | #17 |
88
Rep 870
Additional update:
I contacted Terry and sent my JB4 to him. My PnP harness was one of the original JB3 handmade harnesses, it was probably the cause. Terry swapped my PnP harness for a new machine made harness (at below cost) and I'm back to driving with a smile on my face.
02-03-2012, 04:01 AM | #18 |
Rep 144
My car threw that code tonight right after I installed my Kittyless DP's. I ended up disconnecting my battery for some time and problem was gone. Also my JB4 is only a few months old and the DP's are from a reputable company just in case somebody wants to use the Chinese garbage theory.
10-03-2013, 02:56 PM | #19 |
200
Rep 2,799
I may have answer to this SHITTY problem that no one seems to know or speak about! If you are getting these codes, check your chargepipe connection to the actual throttle body. If it becomes loose, you will throw these codes. If it becomes really loose, there could be a chance of the o-ring in the charge pipe getting sucked into your throttle body. If you restart the car after resetting throttle adaption and it is gone, it probably could be a boost leak. But if you keep starting the car and it is not starting up normally after the reset, take off the charge pipe and check in the butterfly of the throttle body, chances are your o-ring may have got sucked into there and is messing with the butterfly valve. The main thing to check is for a secure connection with the charge pipe and throttle body.
thanks to MGallop |
